Old August 14th, 2011, 09:01 PM   #1
Highalltheway
Highalltheway's Avatar
Motorcycle(s): 2011 ninja 250 special edition
Hot bodies under tail install
Well I decided to eliminate my rear fender with a hot bodies smoke under tail. I downloaded the directions from the site and it shows some trimming on the battery box ?? Is this correct sounds like a pain. Anyone have some experience with this install?
Highalltheway is offline   Reply With Quote
Old August 14th, 2011, 11:47 PM   #2
link to instructions? i did not trim my battery box.
Old August 15th, 2011, 08:32 PM   #3
ws6lt4
Motorcycle(s): 2005 zx6r, 2009 250R
I just put one on my girlfriends 250 a few weeks back and I thought it was a pain in the ass. You will need 4 arms to get the whole thing buttoned up once al the trimming is done... don't know about you, but I was only born with 2 arms.
Took me about 4-5 hours, about 1 hour of that was me drinking beer and scratching my head.
All you really need to do, is take the whole tail apart and cut some off both sides of the battery box flap. Dry fit the whole mess about 5 times to make sure you get everything right (guarantees bj from the gf)... I rate this job a six-pack.
I've replaced a 4.3 v6 vortec with a 5.3 v8 vortec, took 3 days... I rate that job about job at 3 cases.
ws6lt4 is offline   Reply With Quote
Old August 15th, 2011, 08:35 PM   #4
ws6lt4
What they are calling the "battery box", is just the plastic undertail that is on the bike when stock. You are just trimming it slightly and laying the Hotbodies undertail right over it.
Old August 15th, 2011, 10:06 PM   #5
they don't have you remove the old undertail anymore?
Old August 16th, 2011, 02:47 PM   #6
Highalltheway
Under tail PDF
http://www.google.com/url?sa=t&sourc...OAebkyMO4HGNdQ
Old August 16th, 2011, 02:56 PM   #7
Highalltheway
Old August 16th, 2011, 02:57 PM   #8
austinm911
You have to trim the mud flap, because you put the undertail over it.
Underbodies is a pain in the ass to install. It looks awesome but its just way too much effort to get it on.
Getting the license plate on was tricky for me as well.
austinm911 is offline   Reply With Quote
Old August 16th, 2011, 03:01 PM   #9
Highalltheway
I'm trying to post a link to the pdf, but won't let me. Ive purchased a vertical bracket so I won't be using the under tail to mount plate. Will be using led license plate bolts.
Hot Bodies Fender Eliminator Kit Ricke115 2008 - 2012 Ninja 250R Farkles 10 May 12th, 2012 07:36 PM
for those with the hot bodies undertail greatwhiteninja 2008 - 2012 Ninja 250R Farkles 8 October 7th, 2011 02:21 PM
Hot Bodies LED Undertail dyeclan 2008 - 2012 Ninja 250R Farkles 0 April 1st, 2009 03:53 PM
