Old July 5th, 2012, 04:40 PM   #1
ninja_thresh_hold
ninjette.org *********
ninja_thresh_hold's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250r (忍者 250r; sold!) 2001 zx6r
What pistons to use...
Hey guys, this winter, my project is fuel injecting my ninja 250 and putting a turbo on, but im wanting to run high boost,so what forged pistons do you recomend?
ninja_thresh_hold is offline   Reply With Quote
Old July 5th, 2012, 04:47 PM   #2
bdavison
Wartown, USA
bdavison's Avatar
Old July 5th, 2012, 04:52 PM   #3
im curious to see the reviews from your user title...
Old July 5th, 2012, 05:25 PM   #4
lgk
just get some custom je pistons
whats your definition of high boost?
Old July 5th, 2012, 05:37 PM   #5
why not just go with high compression pistons instead of boost
Old July 5th, 2012, 05:46 PM   #6
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
JE All the way.
Old July 5th, 2012, 07:55 PM   #7
greg737
Motorcycle(s): -
The lesson awaiting you, as I understand it, is that it's not the engine's top end strength; pistons, rods, etc., that will limit your quest... instead, it's the bottom end that is a grenade.
Here's a quote from the Wiki of another EX-250 website:
Mike Norman at G Force built race motors adhering to production AFM rules, meaning stock exhaust, airbox, and carbs. These developed enough horsepower to easily overwhelm the rather fragile EX250 bottom end. After destroying a large number of cranks and bearings, he eventually (nearly) perfected the process. But they were still small bombs waiting to go off. There is an inherent limit to what you can pump through a Ninja 250, and from hundreds, if not thousands, of dyno runs, we know that number is in the high 30s of rear wheel HP.
good sticky in Huntsville?
Old July 6th, 2012, 06:56 AM   #8
pomartin
pomartin's Avatar
Motorcycle(s): 08 Ninja 250R (FI)
no pain no gain... besides tunning bikes is fun, no matter what happens
but seriously... turbo on 250... why not just get stronger bike.. but not because it originaly have more power, but couse engine is stronger and it will last longer if you put turbo on it...
just my opinion... have fun
pomartin is offline   Reply With Quote
Old July 6th, 2012, 07:42 AM   #9
650 engine.
Posted via Mobile Device
Old July 6th, 2012, 01:23 PM   #10
pomartin
pomartin's Avatar
it fits ?
Old July 6th, 2012, 03:02 PM   #11
dirty nasty
Motorcycle(s): 2000 Kwak Ninja 250 and 1998 Yamaha YZ400F
It probably could. The chassis, suspension and brakes couldn't keep up though.
I've always thought a KX 250 swap would be cool. It shouldn't be too overly powerful. However, that project will be for when I'm rich and have far too much time on my hands.
dirty nasty is offline   Reply With Quote
Old July 6th, 2012, 07:08 PM   #12
Racer x
Racer x's Avatar
I have put this engine through more than anyone. Racing land speed ,drag racing . Nitrous use with methanol . You name it I have done it . Zero bottom end problems.
Just Sayin
Old July 6th, 2012, 07:39 PM   #13
lgk
Just Sayin
did you end up building a different clutch for the slipping problems?
Old July 7th, 2012, 02:18 AM   #14
Racer x
Racer x's Avatar
Barnett carbon fiber disc and Barnett springs. It should hold 60 hp .
Brake caliper pistons not retracting heffree 1986 - 2007 Ninja 250R Tech Talk 5 April 11th, 2014 08:17 PM
Movement of both pistons. Joule General Motorcycling Discussion 16 July 7th, 2012 12:49 PM
Help! Need opinions on pistons... Skippii 1986 - 2007 Ninja 250R Tech Talk 16 March 1st, 2012 02:17 PM
Brake caliper pistons JamesNZ 2008 - 2012 Ninja 250R Tech Talk 19 January 22nd, 2012 09:47 PM
Michigan Riders, Detroit Pistons... ScorpionNinja Off-Topic 0 October 2nd, 2009 01:14 PM
