Old July 1st, 2012, 05:39 PM   #1
Ninjettepgh
Motorcycle(s): 06 Ninja 250
Exclamation Losing power, top speed is ~70 at 9,000rpm, WHAT'S GOING ON???
Hello all
Disclaimer: I am an extreme newbie and this is my first bike so please talk to me like i'm an idiot!
The Problem:
Lately I've started to lose power on my bike especially at high speeds. I've also realized it kinda...hmm..."sputters"? Almost like its hesitating. Nothing toooo major but definitely not normal. I've read of other forums that say their ninjas go 80-90.....what?! I'm on my last gear at 9,000rpms and i feel like its not wanting to go beyond 70-75 haha.
Background Info:
I ride all year round...and it's Pittsburgh, so the bike has certainly taken a beating since I bought last september. I'm by no means mechanically inclined, but I have managed to replace the clutch cable, change the oil, air filter to a KN filter, brakes, and put on a 2 brothers exhaust. But, the thought of cleaning and syncing (what's that mean?) the carbs frighten me. I'm ridiculously poor so taking it to a shop to clean the carbs is out of the question. Also, i did replace spark plugs a couple months ago and didn't have the gap tool, but assumed it was spaced accordingly already? I know, i'm stupid. Would that little tiny detail cause this?
I try to keep up on maintenance but again, i'm not the most savy motorcyclist.
PLEASE, any advice would be appreciated. I'm probably missing some info, but ask questions, i'll try to respond. I feel so dumb
Ninjettepgh is offline   Reply With Quote
Old July 1st, 2012, 05:45 PM   #2
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Originally Posted by PGHninjette View Post
Hello all
The Problem:
Background Info:
PLEASE, any advice would be appreciated. I'm probably missing some info, but ask questions, i'll try to respond. I feel so dumb :confused:
You are way above my level of mechanical know how.
You might wanna check the thingy that makes the bike go faster. Maybe it isn't adjusted right.
Old July 1st, 2012, 05:58 PM   #3
Ninjettepgh
haha! "the thingy that makes the bike go faster..."???
And don't let that stuff deceive you, I've only been able to change all those things because of Youtube and forums on this site.
Old July 1st, 2012, 06:23 PM   #4
THE BIG SITT
THE BIG SITT's Avatar
I'd check the air filter
THE BIG SITT is offline   Reply With Quote
Old July 1st, 2012, 06:38 PM   #5
Ninjettepgh
I just changed the air filter to the K&N one literally 2 days ago. What could I have done wrong?
I took the stock foam one out, broke the white frame and took it out, put the K&N one on the air box cover, tightened with the clamps and put it back in...
Old July 1st, 2012, 06:55 PM   #6
Coolbpf
Limp Noodle
Coolbpf's Avatar
Motorcycle(s): 2006 Ninja 250, Fastest Red money can buy
I was going to say the same thing. I replaced mine and wow what a difference. Does your bike idle at 1.5-2k rpms? And when i'm in 6th gear I get my ninja to go 70 at about 9k rpms too... So It's not really all that bad. The people who are going 80-90 are redlining every one of the gears up to 6th... But just riding normally 9k at 70 mph sounds pretty good to me for a 250!
Coolbpf is offline   Reply With Quote
Old July 1st, 2012, 07:36 PM   #7
Ninjettepgh
Ok I feel better about that but... I still feel like it was going faster before... And the whole sputtering thing?...
Old July 1st, 2012, 08:36 PM   #8
Yasko
Texas Newbie
Yasko's Avatar
Motorcycle(s): 07 Ninja EX250, 07 FZ6
With the 15t front, my 07 runs 80mph at 9krpm sitting up. I'm 5'10" 180lbs.
My bike will top out at 92mph on my gps.
Yasko is offline   Reply With Quote
Old July 1st, 2012, 08:55 PM   #9
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
You need to re jet your carbs.
You've replaced your air filter with one that flows more air, and added an aftermarket exhaust, which also flows more air. So you've got all this extra air going through the motor, but no more fuel, meaning your running lean. These bikes are already jetted on the lean side from the factory to make the EPA happy.
Anyway you need to re jet your carbs, or just put the stock air filter and exhaust back on. Good luck
Old July 1st, 2012, 09:02 PM   #10
Ninjettepgh
And I assume rejetting the carbs are a PITA?
Old July 1st, 2012, 09:19 PM   #11
DaBlue1
DaBlue1's Avatar
Does it sputter like it's starving for fuel? or does it feel more like a surge or hesitation?
What is the condition of your chain? How many miles on it?
Old July 1st, 2012, 09:22 PM   #12
Ninjettepgh
More like a hesitation and that it's holding back....
And the chain to be honest is ...well, should probably be changed. Would this really contribute to this problem? I don't know how many miles are on the chain but the bike itself is on 12,xxx.
Also... Would the gap spacing contribute to this?...
Thanks guys
Old July 1st, 2012, 09:37 PM   #13
ninja_thresh_hold
ninjette.org *********
ninja_thresh_hold's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250r (忍者 250r; sold!) 2001 zx6r
id do a jet kit, im not sure if it would make it gain top speed, but it sure as hell cant hurt.
ninja_thresh_hold is offline   Reply With Quote
Old July 1st, 2012, 09:39 PM   #14
DaBlue1
DaBlue1's Avatar
....the chain to be honest is ...well, should probably be changed. Would this really contribute to this problem?
Yeap! You may want to pay attention to the condition of the sprockets as well.
I doubt the gap in the plugs is causing your issue your describe, but get a spark plug gapper just to double check the gap and for future plug changes.
When was the last valve adjustment done? At 12k miles, you are due for one.
It also wouldn't hurt to put some Seafoam or Star Tron Fuel Treatment in the fuel tank to help clean the carbs a little.
Old July 1st, 2012, 10:11 PM   #15
ninjamunky85
Que Buenos Son!!!
MOTM - Nov '14
Yes and no. If you've ever taken the carbs off to clean them then replacing the jets is easy. Getting the correct jetting however, is not easy. There is no set formula for which jets to use. Each bike is different, so it's really just a trial and error process. It's easier if you have access to a dyno, so you can see the air/fuel ratio through the RPM range.
This is why I've kept the exhaust stock on my bike. It's not worth the trouble for the small gain in performance on the 250.
BTW, my bike still pulls hard at 90 in 5th gear. I'm running a 15/42 sprocket setup.
Old July 1st, 2012, 11:53 PM   #16
its late. i'm reading this in my living room. i laughed for about 5 minutes after reading your post. the neighbors started banging on the wall so i figured i would congratulate you. you woke up my neighbors
Old July 2nd, 2012, 04:54 AM   #17
Ninjettepgh
So...the conclusion is i should probably get a jet kit?
anyone have a good resource and teaching a complete newby on how to do this?
Thanks
Old July 2nd, 2012, 05:00 AM   #18
7oxSin
MSF Coach!
7oxSin's Avatar
Motorcycle(s): 2003 ninja 250
i rebuilt the carbs on my first 250 12 times and could never get it right, when it comes to re jetting and syncing ur carbs i would pay a shop 60 bucks. also what rpms are you shifting at? ive got my 03 ninja 250 up to about 103 mph and the only thing i have on it is a full muzzy.
Hey Unregistered wanna ride the dragon? Ninjette group ride! May 16th-20th
Join the Ride!!http://www.ninjette.org/forums/group.php?groupid=35
7oxSin is offline   Reply With Quote
Old July 2nd, 2012, 05:08 AM   #19
Ninjettepgh
$60?! That's it?
I'm shifting around 6-7 for 1st gear,
2nd and 3rd about 7ish
and 4th and 5th around 9
anymore than that and i feel like im pushing it too much...but then again...im a complete idiot on this stuff
Old July 2nd, 2012, 05:17 AM   #20
7oxSin
MSF Coach!
7oxSin's Avatar
$60?! That's it?
u can take ur ninja up to 12k when u shift, if u shift too low like ur doing u will not have any where to go when u are in ur top gear, and that will result in a very low top speed. just dont take it past 12 cuz they ****ed up and put the redline at 14 when it needed to be at 12. and 60$ is what a local shop quoted me, if u go to a dealer they will rape u like always.
Old July 2nd, 2012, 06:16 AM   #21
Mocha Man
Blue Shell magnet
Mocha Man's Avatar
Motorcycle(s): 1997 Ninja 250
My answer is "yes!" Unless you cut the battery holder from the air box, getting it back into the frame is nearly impossible. Other than that, though, syncing the carbs just takes a good eye and lots of patience. It's really not all too difficult to do, though.
Mocha Man is offline   Reply With Quote
Old July 2nd, 2012, 06:32 AM   #22
ninjamunky85
Que Buenos Son!!!
MOTM - Nov '14
As long as your not redlining it for extended periods of time you aren't hurting anything. It's the ninjette, it's meant to be revved, that's part of the fun.
Peak HP doesn't come until about 12.5k RPM's so if your going for max speed, that's where you should be shifting.
Old July 2nd, 2012, 06:48 AM   #23
flynjay
flynjay's Avatar
Hello all
The Problem:
Background Info:
When was the last time you adjusted the valves?
Old July 2nd, 2012, 07:11 AM   #24
pfft lolwut?? They originally had the limiter cut in at 15000 then in 95ish they changed the limiter to 14500 because of oil delivery when held at high rpms for extended periods of time, aka loooong straights at tracks. The new bikes have a 13500 rpm red line, and I'm not sure when the limiter cuts in. But what I'm trying to say here is idk where you pulled 12000 from, but unless you're holding the bike at redline for and hour at a time, don't worry about revving the crap out of the engine once it's fully warmed up. The power band of a stock bike peaks around 12500, so rev it when needed.
Posted via Mobile Device
Old July 2nd, 2012, 04:29 PM   #25
7oxSin
MSF Coach!
7oxSin's Avatar
i was told by a bike mechanic that also races 250s in a little function down at the track that you shouldn't take the 1st gen 250s past 12k when shifting because it was bad for the bike. he then said that they put 14k red line on the tachometer but should have put the red line at 12k. ive known this guy for 4 years, he has been racing for at least 10 years and has been a motorcycle mechanic for alot longer then that. so i take his word as fact not to mention there seems to be other members who share this point of view,
ninjamunky85
Old July 2nd, 2012, 05:02 PM   #26
my 6th gear will take me from 35mph to bouuncing off the rev limiter (12.7k) in 6th which with my gearing is 102mph.
Old July 2nd, 2012, 06:55 PM   #27
dirty nasty
Motorcycle(s): 2000 Kwak Ninja 250 and 1998 Yamaha YZ400F
Wait. You bought an aftermarket pipe and introduced more air into the bike by installing K&N filters and didn't even re-jet? If you want a machine that you can reliably ride every day then I'd recommend going back to the stock setup. If you insist on keeping your setup for street use, then I insist you call up some of these companies about jetting. Look up Dyno Jet. They make a Stage 1 and 3 kit designed to work with modified intake and exhaust systems.
You need a feeler gauge to gap your plus. In my experience they've always been gapped correctly from the dealer. However, DO NOT TRUST THIS EVER! Check the gap every single time on every single plug you change.
I second checking your valve clearances. It can't hurt.
Cleaning the carbs is easy. It's just a matter of paying attention, reading good sources of info, and taking your time. Jetting is trial and error. If you have K&N filters with no air box, then removing them is easy. If you have the stock airbox in place, you need to pull the rear wheel off, pull out all the rear fenders, then pull the airbox out through the rear of the bike. Then, cut the battery tray off, being careful not to cut into the intake side of the airbox. Put it all back together. Now when you go to pull your carbs off all you need to do is remove the battery and 2 bolts and peel the airbox back instead of taking the bike half-way apart.
dirty nasty is offline   Reply With Quote
Old July 3rd, 2012, 12:20 PM   #28
JLinde1339
Fighterer in Training
JLinde1339's Avatar
Motorcycle(s): 2001 Ninja 250R
The hesitation its definitely a lean condition. I have the same filter with 110 mains and stock exhaust. Airbox delete. I thot my chain was causing the hesitation. It wasn't. Cheap and dirty fix? I ran duct tape around the aire filter to restrict the air intake. Practically have it covered. Cut about 4 half-inch slits in the tape on each side. Problem solved.
JLinde1339 is offline   Reply With Quote
Old July 3rd, 2012, 12:39 PM   #29
ahhahahaha
next someone is going to say just run with the choke on
Old July 3rd, 2012, 01:10 PM   #30
JLinde1339
JLinde1339's Avatar
That didn't work either.
Old July 3rd, 2012, 01:54 PM   #31
Kevin2109
KThanksBye
Kevin2109's Avatar
Motorcycle(s): 2006 zx636r
hahahahahahahahahahahahahaha
----> My Youtube! <----
Old July 3rd, 2012, 02:12 PM   #32
dirty nasty
I've seen people do similar modifications to Honda CBs with the Keihin CV carbs with the heavy aluminum "puck" slides to increase vacuum in order for them to work with the airbox removed. However, their mods appeared to be much cleaner than "wrapping duct tape around it".
I think that it's just much easier to use the stock setup than re-jetting for a street machine. Think about it, why? The bike can already very easily exceed the speed limit in stock form. Quicker than most cages to boot. Why do you need to make it unreliable, more complicated, more expensive, for such little gain that you can't legally use? It just blows my mind that people spend such great money on modifying their machines, yet you never see them at the track. You do usually see them pulled over getting arrested for street racing though!
Old July 3rd, 2012, 02:17 PM   #33
Kevin2109
KThanksBye
Kevin2109's Avatar
Duct tape is fine for diagnosing a problem, not the fix. That would be like wearing a ton of make up to hide your herpes, you still have herpes!
Then why ever buy a 600 or a 1000? Why not just have a ruckus? (which are badass btw) Why have a bigger house then you need? Its human nature to not leave **** alone, its fun, and gives us something to do. I modded the living **** out of my street 250 but sadly never took it to the track. My 636 puts down more power then 4 stock 250's, I love it on the street and on the track.
Old July 3rd, 2012, 03:26 PM   #34
is there something you forgot to tell me, kevin
Old July 3rd, 2012, 03:29 PM   #35
Kevin2109
KThanksBye
Kevin2109's Avatar
yolo
Old July 3rd, 2012, 05:12 PM   #36
dirty nasty
You're missing the point. If it ain't broke, don't break it with stupid modifications that won't help you whatsoever on the street. Or at least take the necessary steps so you don't get what we've got here.
Last futzed with by dirty nasty; July 3rd, 2012 at 08:40 PM.
Old July 3rd, 2012, 07:48 PM   #37
TBC
TBC's Avatar
Motorcycle(s): 2004 Ninja 250F
Off topic, but OP - join us over in the Pittsburgh thread .
TBC is offline   Reply With Quote
Old July 5th, 2012, 01:07 PM   #38
JLinde1339
JLinde1339's Avatar
Did I not say it was a quick and dirty fix? Pretty sure I did...
...Cheap and dirty fix? I ran duct tape around the aire filter...
Oh look, I did. I even left the OE-style 'aire' swypo that my phone thinks is a word. So, what's the issue again?
Old July 5th, 2012, 05:00 PM   #39
issue is; thats not a fix. its a crutch to kinda get it close to what it should be. the fix is to do it correctly.
Old July 5th, 2012, 05:53 PM   #40
JLinde1339
JLinde1339's Avatar
I offered a solution to the OPs problem. I had the same symptoms, and offered what I did to remedy it so it would run the way I wanted it to. I have yet to read a 'correct' solution to the problem. Ideally, I would fab a fiberglass shield to put around the filter, with a vent like on a bbq grill to control the flow for varying atmospheric conditions. Or I could keep buying bigger jets and hope that thru trial and error, I eventually come across the right size. Would those be correct ways to solve the problem? Maybe. But the weather's awesome, and I want to get out and ride. Not tear down, rebuild, test, wash, rinse ,repeat. Zzzzzzzzzz.... So if anyone has a solution, post up. I'm all ears. I'm not crazy about duct tape on my filter myself, but it did the trick. And until I have the time and resources for a more permanent solution, thats how I'll be riding.
Losing power at full throttle trugracie 2008 - 2012 Ninja 250R Tech Talk 27 April 12th, 2014 06:43 PM
Losing braking power randomwalk101 2008 - 2012 Ninja 250R Tech Talk 21 December 25th, 2011 10:11 AM
losing power on the road :( onizthegnome 2008 - 2012 Ninja 250R Tech Talk 17 October 25th, 2011 10:19 AM
Losing Power stewy832 1986 - 2007 Ninja 250R Tech Talk 14 July 9th, 2011 04:33 PM
[superbikeplanet.com] - Checa's Ducati Losing Top Speed Battle At Monza Ninjette Newsbot Motorcycling News 0 May 6th, 2011 12:00 PM
