Old December 16th, 2011, 08:12 PM   #41
Originally Posted by whatitstrue View Post
If the bike has been riden recently and starts back up after it stalls I doubt it s a fuel delivery problem. Sounds more like its not properly warmed or inproper fuel/air ratio?
believe me, that's possible. When I got mine, it worked fine for 2 days (albeit with a funky idle) and then stopped working completely the third day because so much crud had clogged up in the carbs.
OP, if the bike is back up and running currently, maybe taking the carbs completely off to clean them isn't 100% necessary. Try just running some SeaFoam (or other carb cleaner) through with your next tank of gas. It certainly won't hurt anything, even if it's not necessary. It's a good idea to run some carb cleaner through every few tanks anyways.
Old December 16th, 2011, 10:37 PM   #42
Skippii
Milkshake Drinker
Skippii's Avatar
Thumbs up
Originally Posted by flynjay View Post
I thought the "choke" on the ninja's was an enriching circut and not a traditional butterfly choke.
Technically, a traditional choke uses a "choke valve" which is a sliding perforated tube used to throttle the air intake (not gas) at low velocities, while butterfly valves are traditionally used to choke off the airflow at higher throttle openings. The symbol for a choke circuit is the butterfly valve, and this has been extended to use on enricher circuits, and even to idle speed adjustment on fuel injected bikes by Ducati. If any of that makes sense to you, remember that applying full throttle technically means completely restricting the intake and stalling the engine.
"What a sweetheart."- ninja_sleeper to me
Old December 20th, 2011, 02:05 PM   #43
exploring/carolina
exploring/carolina's Avatar
Here is the air box mod if you have to remove the carb:
http://www.ninjette.org/forums/showt...x+modification
exploring/carolina is offline   Reply With Quote
Won't stay running after warming up skrymir69 1986 - 2007 Ninja 250R Tech Talk 31 May 1st, 2014 07:24 PM
Bike Won't Stay Running - Looking For Ideas aharnak 1986 - 2007 Ninja 250R Tech Talk 13 May 26th, 2013 01:23 PM
Bike won't stay running...HELP!! Pretzel 1986 - 2007 Ninja 250R Tech Talk 7 July 6th, 2012 07:22 PM
Won't idle or stay running haze5736 1986 - 2007 Ninja 250R Tech Talk 10 March 25th, 2012 12:49 PM
Bike won't idle/stay running after carb removal CmichRider 1986 - 2007 Ninja 250R Tech Talk 6 August 11th, 2011 01:26 PM
