Old April 12th, 2011, 08:41 AM   #1
Ragnar1x
Motorcycle(s): CBR 600 F4i, 06 250R
Common Problems with Ninja 250r
Hi Everyone,
I'm new to this forum. I currently own a honda cbr. I am looking into a first motorcycle for my girlfriend. She really likes the Ninja 250r (me too, from what I've seen its a mean little machine).
So my question is to you guys, Is there any common problems I should be aware of when looking at used 250Rs? I am going tomorrow to check out an 06 with about 2000 miles on it. Outside the normal wear and tear, is there anything specific I should ask the seller?
Thanks in advance.
Ragnar1x is offline   Reply With Quote
Old April 12th, 2011, 09:08 AM   #2
shiftdrift06
Motorcycle(s): None
Just check for common things on a bike when you buy used.
The first link is general info on the 250, and the second is service schedule. You can go down the list as you check the bike.
http://faq.ninja250.org/wiki/New_Riders
http://faq.ninja250.org/wiki/Service_Schedule
Edit:
Check to see if it has modifications, if it does ask if it has been properly jetted.
I see you said the bike only has 2000 miles. Ask if the bike has been properly broken in?
Also, it is crucial that the Valves been adjusted! They should have been when the bike was broken in.
shiftdrift06 is offline   Reply With Quote
Old April 12th, 2011, 09:27 AM   #3
Ragnar1x
Whats the harm if they haven't been adjusted at 500 miles? Is it too late to do it now? Is the damage already done if they haven't been adjusted?
It sounds like there is nothing special I should look for in the 250R aside from typical things when buying used.
EDIT: Another thing; I've ridden a 500R once, and the fairings rattled like it was their job. Is this typical or perhaps there was some loose bolts on that bike?
Old April 12th, 2011, 10:45 AM   #4
JeffM
Mr. 988
JeffM's Avatar
Motorcycle(s): One
Another place to look for common issues: http://faq.ninja250.org/wiki/Troubleshooting
"I'm the one that's got to die when it's time for me to die, so let me live my life, the way I want to" - Jimi Hendrix
Cancer
JeffM is offline   Reply With Quote
Old April 12th, 2011, 12:35 PM   #5
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Rattles aren't normal on the 250, at least not the pregens I'm familiar with. The only time mine rattled was when something was improperly loose. Main issues to look out for stem from neglect and improper storage. Carbs get gummy, plugs need changing, tires dryrot, chain ignored, sludge in the tank, that sort of thing. Before starting, make sure it has fresh gas and has a good oil level. Check for binding in the throttle cable and for fraying at the top end of the clutch cable. Damage from drops can be fairly expensive to repair as undamaged fairings are hideously expensive and have been for a while. Look inside the tank for rust. If it's been stored outside pull the seat and check for wasp nests.
Old April 12th, 2011, 12:41 PM   #6
Ragnar1x
Carbs!! Thank you, I knew I was forgetting something. I've been riding fuel injected bikes for a while now.
Thanks everyone for the links. I'll let you know how it goes. With any luck I'll be bringing home an '06 250 this weekend.
Old April 12th, 2011, 01:01 PM   #7
JeffM
Mr. 988
JeffM's Avatar
Motorcycle(s): One
Except for the pretty common clutch lever buzz.
Jeff
Cancer
Old April 12th, 2011, 01:17 PM   #8
speedgsx98
Motorcycle(s): 250 ninja 2002, 2008 ZX10-R
Well, finessing the choke really takes some time to learn. Make sure you brief her on using it. Otherwise, if she bogs the throttle taking off from wither too much or not enough choke, it could cause her to make a mistake. Also, as long as the bike runs and you take it for a ride, it should be fine for the most part.
Good luck!
90 EX250 Ninja, 92 FZR600, 86 CR125, 77 GS750, 73 RD350, 86 CR250, RD350 in SRX250 frame, 75 RD350, 99 RM125, 99 GSXR750, 07 Reflex, 02 250 Ninja, 02 GSXR1k, 08 ZX10R, 07 250 Ninja, 05 250 ninja
speedgsx98 is offline   Reply With Quote
Old April 12th, 2011, 07:19 PM   #9
shiftdrift06
Motorcycle(s): None
I think you will be okay if the valves aren't adjusted. But prolong/high rpm use can cause the valves to melt. Symptoms would include bike not idling right and bike dying when pulling in the clutch while coming to a stop. It also a PITA to adjust them while the engine is in, lol.
Old April 12th, 2011, 08:11 PM   #10
Yasko
Texas Newbie
Yasko's Avatar
Motorcycle(s): 07 Ninja EX250, 07 FZ6
The most common problem is people asking why not a 650...
Yasko is offline   Reply With Quote
Old April 19th, 2011, 11:53 AM   #11
Ragnar1x
So, I picked up the 06 250R. I was wrong about the mileage, there are 7000 miles on it. I think I like seeing that number better than 2000. At least I know it was used, rather than just sitting in someones garage for 5 years.
The bike is very clean, looks very nice. Its black with gray accents.
I feel like it has a little hesitation at the low end. It could be that I'm just used to my 600, but I think it could be smoother. I haven't yet looked at a typical power curve for these bikes, but under 5k rpm feels sluggish, above that and you can tell the bike wants to move.
I'm going to give it a typical tune-up. Clean the air filter, change the oil, clean the plugs(the PO ran only 93 or higher, I'm expecting some carbon build up on the plugs), clean/sync the carbs, etc...
All in all, it seems like a nice bike. I'm hoping she will be putting her first miles on it this weekend.
Old April 19th, 2011, 12:43 PM   #12
make sure the valves have been adjusted/checked. you're due.
clean the carbs and when doing so, shim the needles... it will make the power delivery down low a lot smoother.
Old April 25th, 2011, 03:28 PM   #13
coondog
coondog's Avatar
Motorcycle(s): 2005 ninja 250 street fighter, 2008 street fighter ninja 500, 2001 nsr 125
checking the valves wasn't an issue with 2k miles but with 7k former owner really didn't give a s**t i guess. you can adjust the clutch lever to where you want the friction zone, and the pre-gens were made to rev up and keep revved up, that was a complaint about them. just rev the bike up KNOWING it loves it before taking off and you won't have anything near a bog down again. the bike bike loves running at 9k rpm+, all day long. 11k rpm @ 90 mph is it's "zone" great luck, hope you can keep up with her when she's an experienced ninja 250 rider, happy trails.
coondog is offline   Reply With Quote
Old May 31st, 2011, 12:30 PM   #14
seanski41
Motorcycle(s): 2007 Ninja 250R
Jeff
My '07 250 rattles like crazy when you hit around 9k RPM's ... can you explain the clutch lever buzz?
seanski41 is offline   Reply With Quote
Old May 31st, 2011, 12:43 PM   #15
http://www.ninjette.org/forums/showt...h+lever+rattle
Old May 31st, 2011, 01:02 PM   #16
seanski41
Thanks much ^
What are the most common mods for racing? Ausoi Ninjettes At Speed 3 September 24th, 2012 08:34 AM
Having sum problems with Ninja 250R 09 nat1ve 2008 - 2012 Ninja 250R Tech Talk 13 November 12th, 2010 09:59 AM
Ninja 250r 2009 - first 300 miles impressions/problems hackeron 2008 - 2012 Ninja 250R Tech Talk 7 September 12th, 2010 10:20 PM
RPM problems on 2010 ninja 250r Spencer M 2008 - 2012 Ninja 250R Tech Talk 8 June 1st, 2010 04:59 AM
What does a border collie have in common with a Ninja OldGuy Off-Topic 5 April 7th, 2009 11:58 AM
