Old December 7th, 2019, 09:28 AM   #1
06CandyThunder
06CandyThunder's Avatar
Motorcycle(s): 2006 Ninja 250
Question Return of the Carbs
I took out carbs little to no problems, cleaned it and attempted to reinstall. Turns out my airbox rubber ducts are basically hard as rocks-thats the fate of old rubber- and virtually impossible to reinstall to the carb. Tried boiling them, it worked for a sec then popped out. expletives were used.
Open to suggestions, but may buy new oem ones that are more malleable than my boulders.
Me yesterday wrestling with the ducts 😂
06CandyThunder is offline   Reply With Quote
Old December 7th, 2019, 09:41 AM   #2
Snake
Snake's Avatar
AirPods are a very good option that many people have used.
Old December 7th, 2019, 10:15 AM   #3
I was able to make my original boots work by doing the air box/battery box separation mod. Before that, the assembly kept pulling the carbs back off the boots every time I put them on.
Old December 9th, 2019, 09:16 AM   #4
dukeswift
dukeswift's Avatar
Motorcycle(s): 02 Aprilia RS70 97 Ninja 250
Fairly certain there's a solution you can soak these in to soften them up easier.
dukeswift is offline   Reply With Quote
Old December 9th, 2019, 07:07 PM   #5
Yes there IS way to restore oils back into rubber that have evaporated over time. You’ll need:
- bottle isopropyl alcohol +90%
- small 4oz bottle Oil of Wintergreen (methyl salicylate)
- small bottle glycerin
- some empty glass jars (peanut butter, jam, etc)
Pour into glass jar:
1-part Oil of Wintergreen
1-part glycerin
3-parts alcohol
Stir well and drop in your rock-hard rubber part so it’s completely submerged. Screw jar lid on and let sit for 1-4 days depending upon hardness. Shake jar regularly if you see separation. Remove rubber and wipe off excess fluid. That’s it! Soft pliable rubber just like new!!!
Note: use nitrile gloves to handle. Large doses of methyl salycilate can be poisonous.
Old December 17th, 2019, 09:29 AM   #6
06CandyThunder
thank you got it
Old December 18th, 2019, 11:24 AM   #7
MrAtom
MOTM - July '15
Danno's solution is probably more effective than mine, but I've used that cheapo silicone spray lube stuff that comes in an aerosol can with great success. Just put the parts in a Ziploc bag, blast it with the silicone stuff, enough to cover it, and soak it for maybe a weekend, maybe a week.
I'd also like to add that there are implications to using pod filters. It's a big long-standing, often not-so-civil debate about whether or not to use them. You can use the search function if you'd like to see all the moving parts of this discussion. I ride in the rain a lot, so that's reason enough for me to keep my airbox.
[superbikeplanet.com] - Pedrosa Set For Jerez Return? Or Will He Ever Return? Ninjette Newsbot Motorcycling News 0 April 23rd, 2015 10:40 AM
Need 08+ Carbs Donnyd21 Items Wanted 2 September 19th, 2014 04:38 PM
08+ carbs cuong-nutz Items Wanted 1 August 12th, 2013 10:53 PM
CR Carbs Jiggles 2008 - 2012 Ninja 250R Tech Talk 36 November 27th, 2012 12:50 PM
Carbs choneofakind Motorcycle-related 0 October 30th, 2011 05:39 PM
