August 1st, 2015, 11:35 AM | #1 |
ChocolateMilk Addict
Join Date: Mar 2015 Motorcycle(s): '05 EX-250 "Kallie" 85 KLT 110 ATC "Murdock" Posts: 329
Still got this oil leak!!
Ok guys, i think I've pinpointed it, its either right under the airbox and under the starter, or the drain bolt, meaning i probably need a new crush washer, but i cleaned the airbox area and theres oil back again, so my moneys on that spot, i hear you can drain the airbox and that should fix it, but I'm not quite sure how. Any tips and insight to this matter?
August 1st, 2015, 09:15 PM | #2 |
bump
August 1st, 2015, 10:02 PM | #3 |
Join Date: Nov 2014 Motorcycle(s): EX250, Suzuki Savage, 76 Goldwing restoration project, 71 CB350, 73 Yamaha GT1, Posts: 73
There should be a hose hanging underneath the bike right behind the engine.
Release the little spring clamp by squeezing it together and sliding it up the hose. Pull out the plug and let it drain. Replace the plug and the hose clamp. You don't want it draining oil right in front of your rear tire while riding. Check out this link. http://faq.ninja250.org/wiki/Oil_Cha...n_hose_service |
August 1st, 2015, 10:02 PM | #4 |
The air box (front right corner) has a little hose pointing down, which has a plug for draining.
August 10th, 2015, 11:54 AM | #5 |
Ok, drained the airbox but the leak still persists, any help is appreciated, there a little droplets of oil right above both oil nuts (drain and filter), and right behind th starter (under the airbox, right in front of the fat hose connecting it to the crankcase). again, any help is appreciated, tired of cleaning up oil every morning.
August 11th, 2015, 05:24 PM | #6 |
bump
August 11th, 2015, 05:49 PM | #7 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
Maybe it's time to change oil, filter, O-rings, and oil plug crush washer.
August 11th, 2015, 07:43 PM | #8 |
Fix It Till Ya Break It
Join Date: Oct 2011 Motorcycle(s): 08 250RRrrrr Posts: 623
hard to tell from the photos, i'd say wash it down with engine shampoo and check it then.
also, looks like theres a leak from the carb float bowl drain? also, R6's don't leak oil..... |
August 11th, 2015, 09:26 PM | #9 |
Lol, im 16, i WISH i could afford a R6, lol its my dream bike, anyways, thanks for all the help guys imma go with @dcj's suggestion, again, thanks
August 11th, 2015, 09:36 PM | #10 |
is your oil filled to the correct level? or is it overfilled and trying to gush out the crank breather
August 11th, 2015, 09:39 PM | #11 |
Its on the low end, with the bike standing vertically, no center/side stand. So i don't think that would be an issue, but is there any way to remedy that if it was?
August 11th, 2015, 11:56 PM | #12 |
the remedy to too much oil is to remove some oil. but if its underfilled, then it doesnt have too much oil.
Oil leak.... | skilletmo | 2008 - 2012 Ninja 250R Tech Talk | 13 | October 24th, 2014 09:31 PM |
Oil leak | Xaero | 1986 - 2007 Ninja 250R Tech Talk | 11 | November 16th, 2013 06:58 PM |
Oil Leak? | Fakker | 1986 - 2007 Ninja 250R Tech Talk | 5 | September 6th, 2013 06:38 AM |
Oil Leak | thisisbenji | 2008 - 2012 Ninja 250R Tech Talk | 10 | December 12th, 2012 06:59 PM |
Oil Leak Help | sjc88 | 1986 - 2007 Ninja 250R Tech Talk | 7 | December 29th, 2011 04:13 PM |
