Old September 27th, 2015, 11:55 AM   #1
Sharkride
Sharkride's Avatar
Motorcycle(s): 2010 ninja 250
Tyga full exhaust system?
Hey. Seen a full exhaust system for $300 by tyga. They claim a hp gain of 4 which for seems like a lot but not impossible. Would this system preform like a slip on on does the headers actually show and improvement
Never rode a motorcycle but own 2
Sharkride is offline   Reply With Quote
Old September 27th, 2015, 12:13 PM   #2
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
Have extra jets handy? You're gonna need to rejet as well. You will see a significant increase with a full system though.
Old September 27th, 2015, 12:17 PM   #3
Typically a full system has larger header pipe diameter and possibly smoother bends.
That usually shifts the powerband upward at the expense of low-end and some mid-range, but ultimately it does produce more peak power.
There are exceptions though. You'd have to study a dyno chart of the specific pipe and compare it to a stock dyno chart to see exactly what is happening where.
Old September 27th, 2015, 01:00 PM   #4
Sharkride
Sharkride's Avatar
So when tyga showed the exhaust dyno and said they didn't reject is that bull...
Old September 29th, 2015, 03:49 PM   #5
Sharkride
Sharkride's Avatar
What happens if I don't rejet? Can I counter the need for jets if I left the snorkel in?
Old October 4th, 2015, 02:57 AM   #6
DmbShn41
Wannabe Reborn
DmbShn41's Avatar
Not exactly. Larger exhaust means more flow, which means it needs a little more air which means it needs a little more fuel.
DynoJet and FactoryPro make kits that have everything you need in them to rejet. I recommend the Factory Pro as it has a couple of jet sizes, new needles, and e-clips to properly shim the needle. Really not all that bad, plenty of DIY and resources here to refer to.
But honestly, if you go full exhaust, you need to rejet. Otherwise the bike will not perform at its peak potential aka no 4hp gain. Maybe even a HP loss.
Old October 4th, 2015, 06:14 AM   #7
Ghostt
Ghostt's Avatar
The engine is just an air pump, more air in, the more air out, and vice versa.
With more air, your gonna need more fuel to maintain the air/fuel ratio at optimal performance 14.7 to 1.
Jet changes can be a best guess if not using an exhaust gas analyzer, but without that your back to best guess.
Fortunately the Ninjette has been around for awhile, and others have done modifications over the years. Which means someone has already done the hard work, and has the information your needing.
A word of caution, the most common mistake is over compensating, way too rich. Making changes to the jetting is best done in small steps, and one at a time, jets, needles etc.....
violente et ignorantia
ZX-2R BLOG
Old October 6th, 2015, 07:10 PM   #8
Sharkride
Sharkride's Avatar
Yeah I'm fine with doing what someone else has done and it works. I think the main thing that has me on the wire about rejetting. Is that I have this bike and it's my first and just want to ride. Not even close plus we are moving next mont. so I might not have this thing ready until the end of the year
FS: TYGA full exhaust CF can josefmd Motorcycle-related 12 May 2nd, 2013 05:38 PM
New pics, Clip-ons and Tyga full System w; MGP Growler WolfgangCG 2008 - 2012 Ninja 250R Tech Talk 23 November 20th, 2012 10:08 PM
tyga slip on exhaust system thisdudematt 2008 - 2012 Ninja 250R Tech Talk 6 August 16th, 2012 02:15 AM
Tyga full exhaust leak issue 675Raisinator 2008 - 2012 Ninja 250R Tech Talk 11 March 27th, 2012 12:32 PM
Tyga vs AreaP full system 675Raisinator Ninjettes At Speed 20 February 8th, 2012 09:12 AM
