October 6th, 2015, 01:11 PM | #1 |
Join Date: Jun 2015 Motorcycle(s): 2012 Ninja 250R Posts: 46
Chain & Sprocket?
I'm confused, and worried. I have a '12 250. Recently, probabbly right around 1k miles ago, i put him in the shop, got new tires, had a new sprocket and new chain put on and all was well. We had to do a little adjusting because we were riding crooked for a bit, but we got it handled and everything was torqued tight and all was well again. Rode about 5-600 miles, then tightened the chain, like normal. All was STILL well. I rode him to work yesterday. noticed i heard what sounded like the chain jump ONCE on my way to work, didn't think anything of it because we have a rocky road, i figured it was a rock hitting something, rode fine. Rode home, round trip about 75 miles. Heard the chain making racket on the way in. So when i got home my boyfriend and i checked it out. The chain was EXTREMELY loose. He says like loose to the point of it not being able to be tightened. We looked on the chain, at every link, for any marks or signs of stretching or anything abnormal. nothing was off. Can someone help?? I'm at a loss. and terribly sad that i can't ride my bike in the gorgeous weather. Also, sorry for the ridiculous long post, just wanted to include as much as possible. |
October 6th, 2015, 01:39 PM | #2 |
My first question is how many links is the chain? If the correct amount of links it should be adjustable.
Count the links, and also what gears did the shop put on, how many teeth? Pictures of the adjustment?
October 6th, 2015, 02:04 PM | #3 |
Not sure about how many teeth, It was correct before this happened though.
It's geared 14/45? It's geared stock still, we just put new sprockets on it. |
October 6th, 2015, 02:28 PM | #4 |
Yes that's the OEM gearing, so now you need to count the links, if too many, then that's why your chain is already at the maximum adjustment.
October 6th, 2015, 02:37 PM | #5 |
I'm not sure, when i had the shop put it on they said they cut it down to be right. The chain fit perfect for a while, and when we tightened it, it was very minimal. After we tightened it after that, it was great until recently.
October 6th, 2015, 02:41 PM | #6 |
OEM length is 106 links, since they cut it, I would take the time to verify it.
After that I would bring it back to the shop, and have them check it out, a new chain shouldn't stretch that much.
October 6th, 2015, 02:44 PM | #7 |
Okie dokie. I'll check it out tonight.. That atleast gives me somewhere to start.
My dad told me to check that my rear axle didn't move forward.... but we will see.... |
October 6th, 2015, 03:53 PM | #8 |
Track Clown
MOTM - Sep '15
pictures are worth a thousand words in this situation.
October 6th, 2015, 07:29 PM | #9 |
I'll get some pictures in the morning. My boyfriend and i worked on it some this evening. We tightened the chair, got everything tightened up and situated. He took it on a little test ride. About a mile. Came back, the chain was LOOSE. Like 2 inches of slack. :/
October 6th, 2015, 07:38 PM | #10 |
Track Clown
MOTM - Sep '15
October 8th, 2015, 09:11 AM | #11 |
Not gonna provide pictures, but that's just because we found the issues.
Volar chains are no bueno. I got the phone call from the shop and they told me the chain is just stretching as soon as any tension is put on it. DID here we come. |
October 8th, 2015, 03:55 PM | #12 |
Good choice.
October 8th, 2015, 04:26 PM | #13 |
Didn't the shop put the chain on? Didn't they supply the chain?
October 9th, 2015, 09:32 AM | #14 |
The shop did put the chain and sprockets on, but we supplied the chain and sprocket set. We made a decision to buy the chain and sprocket set online, got a decent deal, but didn't realize the poor quality due to the lack of reviews. All in all, a $50 lesson. Nothing to break the bank, and no injuries, Thankfully!
July 8th, 2016, 07:25 PM | #15 |
Join Date: Aug 2015 Motorcycle(s): 2017 Ninja 300 Posts: 24
July 9th, 2016, 12:04 AM | #16 | |
Certified looney toon
MOTM Jul '13, Jul '14
Understand, Unregistered? (Click quote to see the code.)
July 9th, 2016, 07:35 PM | #17 |
Track Clown
MOTM - Sep '15
hahahaha
July 10th, 2016, 01:49 PM | #18 |
Gotcha. I accidentally piss off so many complete strangers that I've lost track of it, but I rarely post here, so I was confused.
Getting a new chain and sprocket | kittyslasher | 2008 - 2012 Ninja 250R Tech Talk | 10 | December 9th, 2013 12:55 AM |
New chain & sprocket suggestions! | hawker1693 | 2008 - 2012 Ninja 250R Tech Talk | 12 | September 23rd, 2013 07:30 AM |
Chain and Sprocket Discoveries... | ExpatJohnny | 2008 - 2012 Ninja 250R Tech Talk | 10 | January 25th, 2012 10:02 AM |
Racing: Tires & Chain/Sprocket setup... | Order | Ninjettes At Speed | 30 | March 4th, 2011 11:26 AM |
Gold chain and sprocket?? | Tintkng | 2008 - 2012 Ninja 250R Farkles | 15 | March 29th, 2010 01:31 PM |
