Old November 2nd, 2013, 10:25 PM   #1
itslocfoo
itslocfoo's Avatar
Unhappy Ninja 250 problems
I recently bought a used bike it has a lot of problems/issues, and one of them is the idle. it idles at 1k then after a rev it would go up to 3k-4k and stays there.
when i try to adjust the idle up it would quickly go over 2k. If I try to lower it bike sometimes would just turn off.
I was told that my jets are dirty and needed to be clean. I took my bike a part, and i looked in side the carbs. All Jets were clean and all holes were clear. Now i just don't know what's wrong with my bike. help?
and also there were two item that I did not know where it came from. after putting the bike back together i found it. I will add the pictures.
File Type: jpg 1391921_10151885157727239_673876033_n.jpg (134.1 KB, 14 views)
File Type: jpg 1457506_10151885157607239_1310851878_n.jpg (129.8 KB, 14 views)
Last futzed with by itslocfoo; November 2nd, 2013 at 10:28 PM. Reason: Also
itslocfoo is offline   Reply With Quote
Old November 3rd, 2013, 05:51 AM   #2
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
Well I can't tell you where that bolt came from but check over what you took apart again. Those bolts are usually grouped together with the same markings on the head.
The spring is a strap for your intake lid I believe to help keep them seated on the carbs.
Mods: Offset clutch pressure plate
Old November 3rd, 2013, 08:15 AM   #3
itslocfoo
itslocfoo's Avatar
I checked over everything I can't find the hole of where it came from.
Where is that? Do you have a picture of the intake lid?
Old November 3rd, 2013, 08:17 AM   #4
FvnnyL3tt3r1ng
Its right under the gas tank where the carbs face back.
Old November 3rd, 2013, 08:46 AM   #5
itslocfoo
itslocfoo's Avatar
You mean around the big tubes?
Old November 3rd, 2013, 09:03 AM   #6
No, the spring is a spring clamp. That makes sure that your carb boots (from the air box) are snugged onto your carbs.
Look at those two rubber parts that attach to your carbs. One of them is missing the spring clamp. That explains the crappy idle without dirty carbs. You're getting unfiltered air sucked in there because the boots aren't dealing onto the carbs.
Old November 3rd, 2013, 09:08 AM   #7
The strap for your intake lid and battery is a rubber strap that's about 1.25" wide and about 0.25" thick with a little metal hook at one end and a rubber loop on the other.
Old November 3rd, 2013, 09:21 AM   #8
itslocfoo
itslocfoo's Avatar
Thanks I'll take a look when I am home
Old November 3rd, 2013, 10:39 AM   #9
FvnnyL3tt3r1ng
Thats what I meant chone. Don't know why I called it the strap.
Old November 3rd, 2013, 01:01 PM   #10
Dragone
Dragone's Avatar
Motorcycle(s): '86 VFR 750, '90 ZX7, '92 KZ1000, '05 ninja 500, '05 6RR, '06 10R, '07 ninja 250
^ +1
But how could you have an extra bolt??? lol
Dragone is offline   Reply With Quote
Old November 3rd, 2013, 03:04 PM   #11
itslocfoo
itslocfoo's Avatar
Originally Posted by Dragone View Post
^ +1
hahah yeah! where did it come from?
Old November 6th, 2013, 11:15 AM   #12
Lychee
sail away
Lychee's Avatar
what size socket fits on it and how long is it?
Old November 6th, 2013, 12:59 PM   #13
it looks like a 12 or 14 flanged hex head in about 10x50mm. theres a few of those bolts on the bike... check the following locations:
voltage regulator/rectifier mounting bolt
swingarm axle adjuster
forward top engine bracket mount bolt
top triple, fork clamp bolt (92002: BOLT,10X32)
01 250 problems KingQ2u 1986 - 2007 Ninja 250R Tech Talk 5 June 27th, 2014 03:44 PM
Ninja 250 DIY clip ons caused problems...NEED HELP jaybro40 2008 - 2012 Ninja 250R Tech Talk 26 January 3rd, 2013 03:55 PM
03 Ninja 250 Engine problems SabreValkyrn 1986 - 2007 Ninja 250R Tech Talk 12 October 3rd, 2012 11:42 PM
93 Ninja Problems Dimsum_The 1986 - 2007 Ninja 250R Tech Talk 4 April 9th, 2012 10:27 AM
carb problems 1996 ninja 250 mr.jake 1986 - 2007 Ninja 250R Tech Talk 17 February 15th, 2011 08:54 AM
