Old January 27th, 2016, 09:56 AM   #1
peperino
Motorcycle(s): 250R
Newgen vs pregen handlebar
Are these interchangeable? I'm on the market for a right one for my '12 and I see the pregen are much cheaper
Thanks
peperino is offline   Reply With Quote
Old February 6th, 2016, 09:25 PM   #2
Bump for more info (I believe they are different)
Old February 7th, 2016, 07:40 AM   #3
Ghostt
Ghostt's Avatar
They are very different unfortunately, PreGen uses a two piece set-up, riser and bars are separate, NewGen is one piece.
Here's the models the NewGen fit, hope this helps you out.
2008 EX250J8F Ninja 250R HANDLEBAR (J8F)
2009 EX250J9F Ninja 250R HANDLEBAR (J9F-JAFA)
2009 EX250J9FA Ninja 250R HANDLEBAR (J9F-JAFA)
2010 EX250JAF Ninja 250R HANDLEBAR (J9F-JAFA)
2010 EX250JAFA Ninja 250R HANDLEBAR (J9F-JAFA)
2011 EX250JBF Ninja 250R HANDLEBAR
2011 EX250JBFA Ninja 250R HANDLEBAR
2012 EX250JCF Ninja 250R HANDLEBAR
2012 EX250JCFA Ninja 250R HANDLEBAR
2013 EX300ADF Ninja 300 HANDLEBAR
2013 EX300ADFA Ninja 300 HANDLEBAR
2013 EX300BDF Ninja 300 (Canadian) HANDLEBAR
2013 EX300BDFA Ninja 300 ABS HANDLEBAR
2014 EX300AEF Ninja 300 HANDLEBAR
2014 EX300AEFA Ninja 300 HANDLEBAR
2014 EX300AES Ninja 300 HANDLEBAR
2014 EX300AESA Ninja 300 SE HANDLEBAR
2014 EX300BEF Ninja 300 ABS HANDLEBAR
2014 EX300BEFA Ninja 300 ABS SE HANDLEBAR
2014 EX300BES Ninja 300 ABS HANDLEBAR
2014 EX300BESA Ninja 300 ABS SE HANDLEBAR
2015 EX300AFF Ninja 300 HANDLEBAR
2015 EX300AFFA Ninja 300 SE HANDLEBAR
2015 EX300AFS Ninja 300 HANDLEBAR
2015 EX300AFSA Ninja 300 SE HANDLEBAR
2015 EX300BFF Ninja 300 ABS HANDLEBAR
2015 EX300BFFA Ninja 300 ABS SE HANDLEBAR
2015 EX300BFS Ninja 300 ABS HANDLEBAR
2015 EX300BFSA Ninja 300 ABS SE HANDLEBAR
violente et ignorantia
ZX-2R BLOG
Old February 7th, 2016, 07:55 AM   #4
peperino
Motorcycle(s): 250R
Besides the two piece difference, do the holes match to use one or the other? I'm guessing no but that's my original question
Old February 7th, 2016, 08:18 AM   #5
Even if they do, the fork tube diameter's are different. Pre gen has a 36mm fork tube while the new gen fork tube is 37mm
Old February 7th, 2016, 08:25 AM   #6
peperino
Motorcycle(s): 250R
Oh right, the handlebar sits on top of it. Clearly they won't cross fit.
Thanks
Old February 9th, 2016, 12:55 PM   #7
Yamahawk
Chaplain
Yamahawk's Avatar
Motorcycle(s): 75 RD350 race bike, 82 XZ550RJ Vision, 81 XV920RH, 89 VTR250 Interceptor race bike, 06 Concours, 86 EX250E1
Thanks
I have an 86 EX250 which has 35mm forks, and I swapped some 36mm forks onto it to fit a 17" front wheel. Being 1mm difference, which is only .020" radius, i found that the 86 handlebars were a tight fit, but with a small amount of sanding the paint off the inside of the handlebars at the fork caps, they both fit. You may want to get a set and try them, not sure if they bolt up the same, but the 86-87's were the same, or close enough to fit the 88-07 fork upper triple tree with a little sanding of the paint inside where the tube fits.
God chose what the world thinks foolish to shame the wise,what the world thinks as weak to shame the strong,what is despised in the world,what is nothing,to set aside what is regarded as something
Yamahawk is offline   Reply With Quote
Old February 9th, 2016, 02:55 PM   #8
taz
taz's Avatar
MOTM - May '17
As for the bolt holes for mounting them, they are just a little diffrent length apart, just enough to not let them swap.
Newgen Ignition on pregen help. Hasersys 1986 - 2007 Ninja 250R Farkles 5 November 11th, 2015 04:22 PM
Newgen exhaust on pregen? !!(0_o)!! 1986 - 2007 Ninja 250R Tech Talk 26 April 16th, 2013 08:26 PM
pregen engine in newgen? alex.s 2008 - 2012 Ninja 250R Tech Talk 6 October 19th, 2012 11:09 PM
Are the newgen and pregen cranks the same? n4mwd 2008 - 2012 Ninja 250R Tech Talk 2 July 26th, 2012 12:27 PM
Pregen vs. Newgen ambudriver General Motorcycling Discussion 7 May 7th, 2011 07:36 PM
