Old August 4th, 2012, 07:14 AM   #1
Grumpy Old Biker
Grumpy Old Biker's Avatar
This CAN'T be the right owners manual!
ok lets try this again. Ever write some long essay and have your cat stroll by and step on god know what key and wipe out the whole thing??
anyhow, The more I read thru this thing, the more I think either its wrong or the boys in Thailand had a liquid lunch when they wrote it. Nothing in it is accurate.
For example...
1 - Says it a 5-spd. Mines got six.
2 - Says it holds 5 gals. I can barely get half that in there
3 - Shows a rear rack. I have a tiny seat
4 - Shows a helmet lock. umm nope
5 - Shows a fuel shut-off lever, in plain sight
mines under the plastic, takes a coin to turn, and the settings
are 'ON, OFF, PRI' wtf does that mean? No reserve? It has
an actual fuel gauge on the instrument cluster. Its set on 'ON'
6 - The illustrations/locations for the filters are inaccurate
The title says its an EX250, the manual calls it a KLR650. Can manuals be ordered or FSMs downloaded anyplace?
Thanks in advance..
Rick in CO
Grumpy Old Biker is offline   Reply With Quote
Old August 4th, 2012, 08:05 AM   #2
Whiskey
You have a KLR 650 manual.
You want
http://www.kawasaki-techinfo.net/sho...7&lang_code=EN
There is a helmet lock on the 250, lift the rear seat & hook one of the Double D rings around the hook
Old August 4th, 2012, 09:18 AM   #3
There's a downloadable link in this sticky thread at the top of the tech section:
Kawasaki Website links: Parts Diagrams, Details, Service Specs, Owners Manual
Old August 4th, 2012, 09:31 AM   #4
sombo
Newb..... on a steeek! :D
sombo's Avatar
Motorcycle(s): 2012 Harley Davidson XL883L Sportster Superlow
Also, it IS a 4.8 gallon tank. If you are only getting around 2.5 gallons in it, then you are either: a) not running it even close to empty before refilling, b) refilling it on a serious angle and therefore not truly filling it, or c) both a & b. I suggest not trusting the fuel gauge since it's widely known to be about the least accurate fuel gauge ever created. Estimate around 45mpg to start off with times 4 gallons: 4x45=180, so you shouldn't be filling up until at least 180-190 miles on a tank. The reason I used those numbers was to be a little conservative and make sure you don't end up running out of gas before getting to a filling station.
http://mefi.us/images/fuelly/sig-us/112292.png
sombo is offline   Reply With Quote
Old August 4th, 2012, 10:26 AM   #5
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Quick refueling tip: hold the nozzle up so it's just into the tank and fill by eye. Nozzles are designed to automatically shut off when fuel backs up an automotive filler tube, which bikes don't have. If you just insert the nozzle fully into the tank you'll be lucky to fill the tank half way before the auto shutoff trips.
Old August 4th, 2012, 10:50 AM   #6
Grumpy Old Biker
You want
Awesome! Thanks! I saw those and never made the connection!
Old August 4th, 2012, 11:03 AM   #7
Grumpy Old Biker
I knew I found the right site. You guys are amazing. Well this I dont get bro..I was sitting on it when it sputtered out and died. MT tank. I went n filled up a 2.5gal can and almost got all in but no way. I was on a slight incline [driveway] at the time tho.
Well my friend who sold it to me wants to go for a cruise so I am just under 1/2 tank and I will fill up on level ground and 90° verticle and see how much I can get in. will let you know.
Old August 4th, 2012, 11:07 AM   #8
sombo
sombo's Avatar
Also, like frugal said, keep the nozzle tip up near the opening of the tank. If you put the whole thing in the tank then you will never get more than half a tank full before it triggers the auto-shutoff for fueling.
Old August 4th, 2012, 12:00 PM   #9
Grumpy Old Biker
Sho nuff guys. Did what you said and at just under half I was able to get almost 3 gals in.
This threads officially laid to rest. Got lots more questions to post tho.
Thanks for the feedback all
Rick in CO
Old August 4th, 2012, 01:13 PM   #10
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
AFM #676
Supersports are for n00bs
Owners manual checho323 Motorcycle-related 3 April 11th, 2015 11:58 AM
Newgen Service manual, owners manual & tool kit Hero Danny Motorcycle-related 0 September 20th, 2014 07:29 PM
owners manual akcalhoun 2008 - 2012 Ninja 250R Tech Talk 2 August 2nd, 2012 02:35 PM
Owners Manual? hubcapbandit 1986 - 2007 Ninja 250R Tech Talk 2 July 16th, 2010 05:27 PM
250R Owners Manual AnarchoMoltov General Motorcycling Discussion 5 April 5th, 2010 08:21 PM
