#1 |
Join Date: Oct 2013 Motorcycle(s): Ninja 250R, Tiger 800 XRT Posts: 828
Headlight Connector
Looking at Eastern Beaver's connectors (http://www.easternbeaver.com/Main/El...onnectors.html), which one do I need for the stock headlights?
#2 |
You'll need one for an H7 bulb(NewGen), I didn't see any on the website. You might want to drop them an email.
If your looking for a PreGen then H4 bulb, which they have Might I ask why your looking for for one?
violente et ignorantia ZX-2R BLOG Twitter and Instagram = Ghostt_Scott I'm not here to change your mind, just to inform. ![]() |
#3 |
I want to make a splitter to hook up Photon Blasters to run off the headlight line so they don't turn on until the engine is running. I don't want to cut any stock wiring so hence the splitter.
#4 |
Hmm I was just looking at the H4 connectors, I guess the bulb plugs right into it? Didn't know that, I'll have to rethink my plan. What about the headlight relay, does that use a connector I can plug a splitter into?
#5 | |
http://faq.ninja250.org/wiki/Electrical_%26_Lighting This might help
#6 |
The relay is responsible for turning it on when the ignition is triggered, and upon investigation of my bike it would work, but it would be pretty bulky. I'll probably end up going with just a normal switched 12V source.
#7 |
EX500 full of EX250 parts
The Photon Blasters are LEDs that only draw a few watts (the H7 bulbs are 55W each, for comparison). Personally, I'd wire them in to either the accessory fuse (if the NewGen still has that) or taillight wiring (which powers every light on the bike except headlight and turn signals).
Remember that if there's a problem with any device you add to the headlight circuit which causes it to blow the fuse, you'll lose your headlight too. I'd rather not do anything to increase my chances of losing my headlight, so I avoid adding anything to its circuit. If you really want the startup delay, you should wire in a relay to trigger off the headlight circuit, but power the device from its own circuit. With a small load like these LEDs, I wouldn't even worry about it.
![]() *** Unregistered, I'm not your mom and I'm not paying for your parts, so do whatever you want with your own bike. *** |
How do I disconnect this electrical connector | Proteus | 2008 - 2012 Ninja 250R Tech Talk | 8 | November 25th, 2014 08:28 AM |
(computers) what connector is this? | Hero Danny | Off-Topic | 13 | October 16th, 2014 09:28 AM |
Help identify this connector | Maielstrom | Off-Topic | 3 | June 29th, 2012 05:17 PM |
Help finding a connector. | gadgetguy1288 | 2008 - 2012 Ninja 250R Farkles | 8 | December 2nd, 2011 10:06 PM |
What is this connector connected to? | indr | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 19th, 2011 09:38 AM |
