Old September 24th, 2013, 08:47 AM   #1
parox91
Name: Not Applicable
Motorcycle(s): 2007 Blue Ninja 250
Speed Wobbles
So my problem is speed wobbles and I suspect it's this:
-I'm missing ~3 bolts from the faring, (one of the bolts had to be drilled into to break it from the faring cause the PO decided to cross thread it pretty good)
->Any good cheap bolt kits I can invest in?
I just rode my gf's bike and she could handle all the way up to 100mph+ just fine but she has a lower aftermarket suspension from the PO.
parox91 is offline   Reply With Quote
Old September 24th, 2013, 08:51 AM   #2
/moved to pre-gen tech
Old September 24th, 2013, 08:52 AM   #3
parox91
Derp, thanks.
Old September 24th, 2013, 09:04 AM   #4
Originally Posted by parox91 View Post
-My suspension has been raised to the max seat height by the PO.
Which of these could be contributing to speed wobbles past ~92mph?..........
How did the PO achieved that?
Slow down !!!
Old September 24th, 2013, 09:11 AM   #5
parox91
Nvm, it wasn't adjusted.
Slow down !!!
I'm just keeping up with the flow of traffic (and then a smidgen)
Old September 24th, 2013, 10:48 AM   #6
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
I've had head shake for months now I suspect it's the stem bearings needing to be replaced or at least adjusted. There is an upgrade to that for ~$40 from allballs.com <-- I think that's the web address....
Mods: Offset clutch pressure plate
Old September 24th, 2013, 06:23 PM   #7
I asked because the pre-gen is not adjustable and wanted to know what he had done and how high the rear was.
The front being lower than the rear makes the steering more sensitive and less self-correcting, which in my opinion avoids steering oscillations, but until certain point.
If too much of a difference, then it can becomes dangerous unstable.
In summary, if your height difference is moderate, the cause of your the problem may be a loose steering column (bearings), telescopic tubes with excessive play, swingarm pivot with worn shaft or needle bearings, a poorly lubricated chain (with hard kinks), ........ but the main culprit frequently is the absence of handlebar weights (those dark cylinders in both ends) or a big heavy tail trunk.
Old September 24th, 2013, 09:41 PM   #8
Absence of bar weights doesn't cause headshake.
It causes buzzy grips. Same idea, different scale.
I've been without bar-end weights for somewhere around 8000-10,000 miles now. No tendencies to headhake caused by that. Now raising the tail definitely made it lighter and more sensitive to hand inputs when the front gets light over crests or bumps, but still no shake that wasn't caused by me
Old September 25th, 2013, 04:59 AM   #9
parox91
So I was talking about it with a coworker and he concluded that since my gf's bike is lower(Aftermarket parts), there's less weight on the front for it to induce speed wobbles. That and, I'm about 30lbs heavier than her.
Therefore, last night I decided to do a test as I was following my gf @ 95mph, I sat my butt further back and decided to tuck in but not putting any weight on bars/tank, and mostly on seat/pegs...
I didn't wobble but it felt as if I was going to fly off the bike if there was a headwind
Old September 25th, 2013, 05:03 AM   #10
parox91
So there isn't a magic nut/spring I can loosen to adjust the seat height?
The suspension may have been altered, I really don't have a stock ninja to compare it with; I'll put pics up this weekend of the two bikes and a reference point with measurements of the sag.
I'd do it sooner but school/work has left me with no time to myself
Old September 25th, 2013, 06:01 AM   #11
agentbad
agentbad's Avatar
I only get it when I take my hands off the bars.
Old September 25th, 2013, 08:35 AM   #12
The suspension may have been altered, I really don't have a stock ninja to compare it with.........
No, the pregens have not adjustability for that, unless the OP had replaced the original shock absorber by one that was adjustable.
Correcting that steering oscillation may take some time because you will need to change things and test the results.
These are some measurements of my stock pre-gen:
Front End Wobbles kkim 2008 - 2012 Ninja 250R Tech Talk 318 May 25th, 2015 07:01 AM
1999 Ninja 250r - When riding front wobbles/feels loose 99Ninja 1986 - 2007 Ninja 250R Tech Talk 4 August 25th, 2014 05:31 PM
Front end wobbles !!(0_o)!! 1986 - 2007 Ninja 250R Tech Talk 4 April 20th, 2013 02:45 PM
Speed wobbles on Highway Heffdan General Motorcycling Discussion 14 September 14th, 2012 10:17 PM
[crash.net - MotoGP] - Stoner: 'The wobbles have gone'. Ninjette Newsbot Motorcycling News 0 June 21st, 2008 10:32 AM
