March 17th, 2014, 08:18 PM | #1 |
Did my 250 become a 125 (dead cylinder)?
Problem/symptoms:
When I left for work this morning, I noticed my bike was running a bit rough. As I brought the bike to a stop sign I had to keep giving it gas to keep from dying. I turned onto the main road and instantly realized my bike couldn't deliver power; so I turned around to limp home. It was difficult to go over 40mph. Since I had just done some work on the bike I thought it was as easy as an oversight or bad part, but after some initial testing I'm concerned it may be far worse. Recent work done: - After running 2 tanks with Seafoam, I removed my carbs for a good cleaning, which included soaking main and pilot jets in B-12 chemtool. - Then I decided to change the main from #98 to #100, since I had planned to do this anyways. - I replaced the right coil with a new one from ebay. Reason for work: Cleaning carbs: Since my bike is a commuter I've never had to worry about my carbs gumming up from sitting dormant. But after sitting in pieces for two weeks while I redid my steering bearings (longest time it's ever gone without being used), something felt funny when I returned to the road. I described the problem in another thread like this: "I'm having an intermittent issue. My first assumption is that my jets may have started to clog, since I haven't done recent engine work....... For the most part everything seems normal, but sometimes when I roll on the throttle aggressively (1/2 to 3/4 throttle) before the RPM gets close too the rev limiter (guessing @ 8-10 RPM maybe) it feels like it cuts out. It doesn't feel like a lean surge, and I don't THINK it feels like a rich bogging... it's difficult to describe. Almost like it sputters and looses all power, but only a second." For reference: http://www.ninjette.org/forums/showt...615#post817615 My description was comment #15. The general consensus was that I COULD have started to gum up, but even more likely that I had moisture in the fuel. Changing main jet: My never-ending quest to find jetting perfection. Replacing right coil: The original coil wire broke when I removed it to read my plugs. Trouble-shooting: - Thinking I either got a bum replacement coil, or installed it improperly, I double-checked my work. It was good. - I verified the coil worked by sparking the plug against the case (right and left). Both sides worked. - Then I did a compression test with the following results (on a cold engine): left = 165 psi right = 125 psi (155 wet) Service manual states the usable range is 142~218 psi OR 139~213 psi. One of these must have been a mistake in the manual. - Checked oil sight glass for coolant contamination. None detected. I don't know what to do now. What are my options?
March 17th, 2014, 09:20 PM | #2 |
MOTM - Sep '18, Feb '16
You need a minimum of 125 to get anything. I would find a machine shop and pull the headm . Then while they have the head replace the pistons and rings. Have the machine shop hone the cylinder block. Get a new chain tentioner also. But photo everything as it comes apart before spending money
March 17th, 2014, 09:53 PM | #3 | |
Ballpark, what would that run me? Is it more cost effective to order another ebay engine? This was my 2nd. Do they things really just go bad all of a sudden? I've got a manual tensioner, so that part is covered.
March 18th, 2014, 07:54 AM | #4 |
When machines fail it always interest me. No idea what straw break the cammels back.
As for cost. I don't know. Couple hundred for labor o would guess. E bay engines are good at this point. But you don't know the history.
March 18th, 2014, 11:17 AM | #5 |
Join Date: Nov 2011 Motorcycle(s): 2011 red ninja 250r Posts: 94
Are you sure the spark plug still good? If the fire seems unfocused, moving around between electrode instead of shape similar on each spark, its time to replace.
Corner is what the ninjette is made for. |
March 18th, 2014, 11:39 AM | #6 |
I thought about trying a new plug for a moment too, but I don't see how this would effect the compression, as the test is done without plugs. I just double-checked the battery, which read 12.84v at the battery (off). The difference between dry and wet tests also suggests to me their isn't a great seal inside the cylinder. I don't have a ton of experience, but picked this stuff up from the last time I killed an engine. My current engine is from ebay.
March 18th, 2014, 12:07 PM | #7 |
My bike was once at the state of low compression. The valves got clogged with carbon deposit. It was really hard to start the engine, had to push start. But that was due to bad quality fuel in my country, RON 88 subsidized fuel. It lacks of detergent chemicals that was usually mixed into more expensive fuel.
March 18th, 2014, 12:15 PM | #8 | |
March 18th, 2014, 12:46 PM | #9 | |
March 18th, 2014, 01:44 PM | #10 |
Participant
When you had the plus out to do the compression check, was one spark plug appreciabably darker/sootier than the other?
When it's running, is one exhaust header cooler than the other (via touch or infrared thermometer)? Are the valve rocker clearances consistent on both cylinders? (Would the "carbon buildup on the valves" cause valve clearance to be a bit greater? I dunno...) I'd consider those easy, relatively non-invasive checks before doing the more drastic stuff. |
March 18th, 2014, 01:58 PM | #12 | |
I didn't think about checking temp on each side before removing the tank. I'd have to check the clearances, but I do those myself, and the next scheduled adjustment is in a couple-few thousand miles. I rarely see much variation though.
March 18th, 2014, 01:59 PM | #13 |
Yes, it sparks against the case (both sides do). This still wouldn't explain super low compression results though.
March 18th, 2014, 02:06 PM | #14 | |
Check the valves and look for any odd measurements. If you have been using a fuel system cleaner it's possible that you dislodged some carbon and it's holding the valve open slightly - like silent suggested. |
March 18th, 2014, 02:15 PM | #16 | |
Participant
I'm a lazy guy (economical with my effort?) and prefer trying a few easy things before tearing into carbs, heads, or the guts of an engine. And the less I have to dismantle, the less I can screw up. |
March 18th, 2014, 05:09 PM | #18 | |
The origin of the problem is almost always caused by the last work we did, directly or indirectly. The more you dig, the more problems you may create, having a really mess very soon. Compression has been bad for long time, unless you couldn't measure it properly, a head gasket suddenly failed or a valve suddenly remains semi-open. The missing explosions needs to be identified; left or right cylinder. The missing ingredient of the explosions needs to be identified: Fuel: You could drain bowls and re-check. Heat: You could switch coils and re-check. Seeing a spark means nothing, sparks may be absent when the electrodes are feeling the high pressure of the compression. The new variable in the equation is the new coil: it will be guilty until absolutely proved innocent.
March 18th, 2014, 05:21 PM | #19 |
Participant
Putting the gas tank back on and hooking it up should only take a few minutes. Then run it and try the things Hernan suggests.
March 18th, 2014, 09:51 PM | #20 | |
March 18th, 2014, 09:53 PM | #21 | |
It's been a $hity day, so now it's time for burbon and bed.
March 19th, 2014, 10:47 AM | #22 |
A couple questions I work up with this morning since all this has been running through my mind:
1) Does it appear likely that the symptoms I mentioned BEFORE I cleaned the carbs are relevant or related to the dead/weak cylinder (other than the carbon and valve theory)? I'm referring to it temporarily cutting out or sputtering mid-throttle. 2) Would a WET compression test temporarily seal the valves in the same way it does bad rings?
March 19th, 2014, 02:46 PM | #23 |
1) Yes, but only if the symptoms appeared immediately after the clean up.
2) No. More oil than the minimum necessary to seal the rings (a few drops) may damage the engine and give a false compression reading. At top dead center (TDC) position of the crackshaft, each combustion's chamber has only around 10 cc or 0.34 oz of volume.
March 23rd, 2014, 03:29 PM | #24 |
This symptom started after siting for 2 weeks while I replaced the steering bearings, and was the reason for the clean-up 2 tanks later. So I guess it was technically already there.
March 31st, 2014, 03:58 PM | #25 |
I don't have much to report yet, as I've had to focus on other aspects of life, but prepped the bike to measure valve clearances.
I just discovered a reasonably priced Valve Spring Compressor tool (Tusk), so I may be up for tackling a new level, if need be. Would I need a case separator too, or can I pull the engine apart without it?
April 29th, 2014, 11:22 PM | #26 |
It's been a while, but I just measured the valve clearances. As I understand from our discussion, I was hoping for the bad cylinder to be way out of spec., as this could explain the poor compression. Well, 3 of 4 valves on the bad side was exactly in spec, and the other was out but technically within spec. limits. So I guess in this case it's bad news.
Clearances are as follows: - Left (good compression) cylinder (Exhaust) = .010"/.254mm & .009"/.229mm (intake) = .007"/.178mm & .008"/.203mm -Right (poor compression) cylinder (Exhaust) = .010"/.254mm & .010"/.254mm (intake) = .008"/.203mm & .007"/.178mm Have we determined the rings are now the most likely cause of poor compression?
April 29th, 2014, 11:46 PM | #27 |
Removing the head and cylinder block is easy. We can walk you through it.
What brand compression tool tester are you using? Some brands are better than others. Do you know anyone with another brand to get a second verification? It's late and I have to be at work in a few hours.
April 30th, 2014, 12:10 AM | #28 |
Join Date: Mar 2013 Motorcycle(s): 08 cbr1000rr, 2008 + 2012 ninja 250, 06 zx6r (636!) track only Posts: 150
Is it possible to swap the coils?
and did you try to buy brand new spark plugs?
http://www.1000rr.net/forums/showthread.php?t=90412 http://www.8thcivic.com/forums/ http://www.facebook.com/profile.php?id=1209877267 |
April 30th, 2014, 12:28 AM | #29 |
The compression tester is from Harbor Freight. It's results have been consistent.
I do have new plugs. I have the original coils and the eBay one. The eBay one is the one I used when I discovered I lost a side. That being said, this was also before I realized my first coil wasn't really broken, but the wire just screws back in. I have that one back on now, but this is also the point I checked compression before proceeding further.
April 30th, 2014, 04:25 AM | #30 |
Which wire are you referring to?
April 30th, 2014, 05:23 AM | #31 |
I guess it is not the ring (if you refer to the piston ring). If it was, the exhaust smoke should turn white, more white than smoke comes from healthy 2 stroke engine.I still guess carbon deposit sits between the valve and the valve seat (intake and exhaust mouth).
Unfortunately I dont know any cheap method to test which valve is leaking without taking off the head. If you are willing to take off the head, you can test it by pouring gasoline/water on the cylinder dome, while the head is upside down. Or if you could somehow inject compressed air through the spark hole, without leaking back, you should be able to feel it whether it's the intake or the exhaust valve.
April 30th, 2014, 09:37 AM | #32 |
April 30th, 2014, 09:56 AM | #33 | |
I have an air compressor, and a tire valve remover. If I remove the valve from the compression tester hose, to allow air to be forced the opposite direction, and connect the air compressor to that, would that serve as my ghetto leak-down tester? I did try the homeless man's version of leak-down testing by cranking it by hand and listening, but that wasn't very effective. If my compressor idea might work, at what point do I turn the engine over to to seal the valves? Am I good as long as none of the cam lobes are compressing the buckets? I'm also assuming I'd want the cylinder at the bottom to give the most surface area possible to test... unless we're not isolating valves, but isolating which valve? All that being said, I am willing, and am psychologically preparing myself to split the case if recommended. Since my problems started, I have since acquired a big(baby) brother for my little Ninjette, so I don't have the same urgency for transportation, and can take my time to do it right. If the recommendation is to start removing the engine to proceed with major surgery, will I need to purchase a case-splitter, or is the head easily removed without? Will I need a new gasket, or is it reusable like the valve cover gasket is? I really appreciate your help guys. I was ready to give up and start parting it out, but am excited about learning/gaining a new level of experience, and getting her running again. Funds are tight, so depending on parts and tools, it may have a delay or two. In case I haven't mentioned it, remember I do have the original engine as a parts engine. Although I don't remember the numbers, the compression was poor on that engine, but this one is better on one side, and much worse on the other.
April 30th, 2014, 11:26 AM | #34 |
Join Date: Apr 2014 Motorcycle(s): Ninja 250, Yamaha RS200 (classic) Posts: A lot.
I had exactly this and it was just an ht lead working its way out of the coil. It would spark open but obviously not under compression. Check that easy glitch first and snug it all up. Since you just changed a coil its a favorite.
April 30th, 2014, 03:59 PM | #35 | |
For the tester, why dont you give a try? First you have to make sure the engine at TDC, which is right cylinder on top. Here you can test the right cylinder right away. Feel by hand whether air come through the intake port or exhaust. You can close the port by hand and feel the pressure. If you feel pressure right away as you let pressurized air into cylinder, that may be good indication if it is leaking. As the engine has 180 crank angle, the left cylinder fires when the right cylinder at BTDC at the end of power stroke. So to find left cylinder TDC, insert a screwdriver through the spark hole of the left. If you follow TDC finding method on the manual, it should be the right cylinder that is at TDC. Then you crank the engine by hand until the screwdriver stop moving up. left cylinder should be at TDC. Then you can test the compression on the left. Here may be the makeshift compression tester with air compressor looks like http://forums.g2ic.com/tegtips/engine/30.html
Corner is what the ninjette is made for. Last futzed with by silentIm; April 30th, 2014 at 04:53 PM. Reason: I mean power stroke, not compression stroke |
April 30th, 2014, 04:45 PM | #36 |
Thanks; you make it sound easy, and not so intimidating.
April 30th, 2014, 04:58 PM | #37 |
Well I just put out the concept. I assume you already drain the coolant and remove the coolant tank, remove all the bodywork and fuel tank, remove the kleen air system, and remove the carb right?
Beside, the step by step guide is already covered in DIY guides over the internet and the workshop manual.
April 30th, 2014, 05:01 PM | #38 | |
May 4th, 2014, 05:16 PM | #39 |
Board Member
How did this end up?
May 4th, 2014, 05:19 PM | #40 |
Pending... I'm cleaning up the garage, as I don't have the space I need to work productively. I got tired of stepping over stuff and twisting every time I need a new tool.
2006 Ninja 125... Only running on one cylinder? | SV_Hadder | 1986 - 2007 Ninja 250R Tech Talk | 8 | February 7th, 2011 10:31 AM |
