June 16th, 2012, 02:58 AM | #1 |
Join Date: Sep 2010 Motorcycle(s): 2008 Kawasaki Ninja 250r Posts: 139
Kickstand switch...Pre-Gen CDI
So i'll start off by saying that the wiring harness is not even on the frame and that I haven't ridden the bike in exactly 1 year since today
Just a few questions for those who have done this mod : 1. Does the clutch switch still work 2. Does the gear switch work (i.e can you accidentally start it in gear) 3. Is there a way to get the kickstand switch working again Number 3 is my main concern as I will (eventually) be passing on the Ninja, most likely to a 1st time rider. I searched around and didn't get far but I remember when this mod was new nobody attempted to get the kickstand switch working again...if I remember correctly there was some talk about something involving 12v, the CDI and the kickstand switch Has anybody attempted anything as of yet or should I start looking through the wiring diagram for a solution. many thanks ! |
June 16th, 2012, 06:52 AM | #2 |
I don't think there is much danger as the stand will kick up and back if it scrapes. That said, I need to know where the kickstand switch connects on the pregen harness. I didn't even see a kickstand switch in the pregen parts diagram (checked "Stands," "Frame Fittings," "Wiring Harness," etc), but I certainly see them for sale and intend to buy one (mine doesn't have one).
Last futzed with by CZroe; June 16th, 2012 at 08:12 AM. |
June 16th, 2012, 07:25 AM | #3 |
its under the electro bracket category
http://www.bikebandit.com/houseofmot...49469#sch68480 looks like 27010a |
June 16th, 2012, 07:41 AM | #4 | |
June 16th, 2012, 07:50 AM | #5 |
i figured you would get a good laugh out of that diagram.
June 16th, 2012, 11:43 PM | #6 | |
Generally they were the type of people who just jump on the bike and pin it....then the first left corner they see Like I said, i'm only concerned about the next owners safety as it will almost certainly be a first time rider. Anybody have any ideas ? thanks guys |
June 17th, 2012, 08:16 AM | #7 |
can you take some pictures of your kick stand with it up and down?
you said the harness was out but do you see these wires |
June 17th, 2012, 10:34 PM | #8 |
The stands not on the frame at the moment and the switch has long since been removed after I bridged the 2 wires.
The wires that connect to the kickstand switch are exactly what you showed (green and black)... thanks |
June 18th, 2012, 04:19 AM | #9 |
its good the wires are there.
the kickstand switch is directly actuated by the kickstand so it should not be too hard to figure out how it mounts. |
June 18th, 2012, 05:04 AM | #10 |
New-gen engine in Pre-gen frame. Oil leak under exhaust ports. | AFazakerley | 2008 - 2012 Ninja 250R Tech Talk | 11 | June 5th, 2016 02:03 PM |
Swapped New gen forks onto pregen, kept old gen ignition switch. | thumper64 | 1986 - 2007 Ninja 250R Tech Talk | 4 | March 31st, 2014 07:05 PM |
Pre-gen kickstand on new-gen? | ramykandil | 2008 - 2012 Ninja 250R Tech Talk | 9 | July 3rd, 2013 08:35 PM |
Pre Gen thermostatic Switch | FvnnyL3tt3r1ng | Items Wanted | 1 | May 20th, 2013 09:19 AM |
Pre-gen (2007 and older) and "new pre-gen" (2008-2012) frames | kjohng | General Motorcycling Discussion | 5 | February 27th, 2013 10:03 AM |
