Old June 16th, 2012, 02:58 AM   #1
GiGs
Kickstand switch...Pre-Gen CDI
So i'll start off by saying that the wiring harness is not even on the frame and that I haven't ridden the bike in exactly 1 year since today
Just a few questions for those who have done this mod :
1. Does the clutch switch still work
2. Does the gear switch work (i.e can you accidentally start it in gear)
3. Is there a way to get the kickstand switch working again
Number 3 is my main concern as I will (eventually) be passing on the Ninja, most likely to a 1st time rider.
I searched around and didn't get far but I remember when this mod was new nobody attempted to get the kickstand switch working again...if I remember correctly there was some talk about something involving 12v, the CDI and the kickstand switch
Has anybody attempted anything as of yet or should I start looking through the wiring diagram for a solution.
many thanks !
GiGs is offline   Reply With Quote
Old June 16th, 2012, 06:52 AM   #2
I don't think there is much danger as the stand will kick up and back if it scrapes. That said, I need to know where the kickstand switch connects on the pregen harness. I didn't even see a kickstand switch in the pregen parts diagram (checked "Stands," "Frame Fittings," "Wiring Harness," etc), but I certainly see them for sale and intend to buy one (mine doesn't have one).
Last futzed with by CZroe; June 16th, 2012 at 08:12 AM.
Old June 16th, 2012, 07:25 AM   #3
lgk
its under the electro bracket category
http://www.bikebandit.com/houseofmot...49469#sch68480
looks like 27010a
Old June 16th, 2012, 07:41 AM   #4
looks like 27010a
Thanks. Wow. That doesn't help me visualize where it goes and how it attaches at all. I guess I'll need to find someone with a stock pregen or just make sure it is bypassed.
Old June 16th, 2012, 07:50 AM   #5
lgk
i figured you would get a good laugh out of that diagram.
Old June 16th, 2012, 11:43 PM   #6
GiGs
That is partially true, i've never scraped it with it bypassed but I did see (and hear of) a few horror stories of people going down because of it.
Generally they were the type of people who just jump on the bike and pin it....then the first left corner they see
Like I said, i'm only concerned about the next owners safety as it will almost certainly be a first time rider.
Anybody have any ideas ?
thanks guys
Old June 17th, 2012, 08:16 AM   #7
lgk
can you take some pictures of your kick stand with it up and down?
you said the harness was out but do you see these wires
Old June 17th, 2012, 10:34 PM   #8
GiGs
The stands not on the frame at the moment and the switch has long since been removed after I bridged the 2 wires.
The wires that connect to the kickstand switch are exactly what you showed (green and black)...
thanks
Old June 18th, 2012, 04:19 AM   #9
lgk
its good the wires are there.
the kickstand switch is directly actuated by the kickstand so it should not be too hard to figure out how it mounts.
Old June 18th, 2012, 05:04 AM   #10
Is it shared with the center stand or is that one not detected due to automatically folding up when moving forward?
New-gen engine in Pre-gen frame. Oil leak under exhaust ports. AFazakerley 2008 - 2012 Ninja 250R Tech Talk 11 June 5th, 2016 02:03 PM
Swapped New gen forks onto pregen, kept old gen ignition switch. thumper64 1986 - 2007 Ninja 250R Tech Talk 4 March 31st, 2014 07:05 PM
Pre-gen kickstand on new-gen? ramykandil 2008 - 2012 Ninja 250R Tech Talk 9 July 3rd, 2013 08:35 PM
Pre Gen thermostatic Switch FvnnyL3tt3r1ng Items Wanted 1 May 20th, 2013 09:19 AM
Pre-gen (2007 and older) and "new pre-gen" (2008-2012) frames kjohng General Motorcycling Discussion 5 February 27th, 2013 10:03 AM
