Old July 8th, 2012, 05:09 PM   #1
red5
red5's Avatar
Motorcycle(s): 09 ninja 15.256
$20 temp gauge
I was bummed that Kawi replaced the temp gauge with a fuel gauge for the new gens and was about to buy a Koso unit. After searching a bit I found this unit instead.
Temp Gauge
It actually has two channels so I bought a second temp probe so I could display both oil and water temps.
Probe
Drilled an extra oil plug and put it in place of the pre gen drain plug.
A 1/8 brass plug fits well in place of the stock over temp sensor.
After drilling the plugs, I glued in the probes with hi-temp epoxy.
Here is a shot of the gauge itself. You can set a couple of dip switches on the back to display the oil or the water temp or you can alternate between the two every 5 seconds or so. There is a light sensor on the face of the gauge so you can also switch between the two sensors by shining a flashlight on the display.
We will see how well it holds up but the quality looks better than your standard Chinese fare. For less than $20 I took a chance.
"We're not always doing business, but we're always open."
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." Carl Sagan
Last futzed with by red5; July 8th, 2012 at 09:51 PM.
red5 is offline   Reply With Quote
Old July 9th, 2012, 06:21 AM   #2
Nice!
Old July 9th, 2012, 08:59 AM   #3
Klondike1020
Intrepid Adventurer
Klondike1020's Avatar
Very cool mod. How does it switch between coolant and oil temps? And is the entire unit self contained or does it run off of your 12v on yOur bike?
Old July 9th, 2012, 09:49 AM   #4
red5
red5's Avatar
There are dip switches on the back of the gauge. You can display one or the other all of the time or you can have it automatically switch between the two at about 5 sec intervals.
You can also manually switch from one to the other with a flashlight. There is light sensor just above the display and if you shine the light for a few seconds you can go from one to the other.
Its 12V wired to the ignition.
New here, question about temp gauge Neps 2008 - 2012 Ninja 250R Tech Talk 6 June 30th, 2014 04:39 PM
Analog temp gauge for $15 almost40 2008 - 2012 Ninja 250R Farkles 19 December 8th, 2011 09:46 AM
Water Temp Gauge etiainen 2008 - 2012 Ninja 250R Farkles 5 November 4th, 2011 04:30 PM
Daytona Temp Gauge wellcraft General Motorcycling Discussion 0 January 26th, 2010 07:24 PM
New Temp. gauge needs a temp gauge! headshrink 2008 - 2012 Ninja 250R Tech Talk 2 July 16th, 2009 09:33 AM
