Old May 21st, 2009, 04:02 PM   #1
pantera
pantera's Avatar
Motorcycle(s): 2016 Kawasaki Vulcan 900 Custom / 2017 Kawasaki Ninja 300
Gas gauge fix
On my Kawasaki vn 900 custom there is a fix for the inaccurate gas gauge by putting certain resistors in the wire harness.Wonder if this would work on the Ninja?
pantera is offline   Reply With Quote
Old May 21st, 2009, 05:42 PM   #2
HKr1
IC2(SW)
HKr1's Avatar
On the 250r:
Full is 4-10 Ohms
Empty is 90-100 Ohms
Looking at that pic, kinda looks like a 620 ohms & 2200 ohms in series for 2820 ohms. Also looking at that pic, its in parallel with the fuel sender. So lets say the 250r is:
Full @ 5 ohms
Empty @ 95 ohms
With these resistors added:
Full would be 4.9 Ohms
Empty would be 91.9 ohms
So it would come off empty a little bit more than normal.
Old May 21st, 2009, 06:01 PM   #3
pantera
pantera's Avatar
260 is the ohms they are trying to achieve on that thread.I just ended up bending the float arm on my vn 900 and fixed the problem.I am no where near electronically inclined enough to experiment with resistors.I wish when I filled the tank on the Ninja though it would actually read full.
Old May 21st, 2009, 07:23 PM   #4
HKr1
IC2(SW)
HKr1's Avatar
I finally got to click on the pic and make it bigger, before I was getting invalid link.
Anyway looks like Red/Red/Brown for 220 ohms & Yellow/Violet/Black for 470. That added together would be 690 ohms. If they were trying for 260, one Red/Blue/Black would have been nice.
But still, 470 wouldnt change the full resistance much. Empty with 470 & 95 would be 79 ohms. That would be a big diff, dont think it would show empty.
If you were to use 260 ohms, that would make it 69.
Your 900 is probably a different empty resistance than the 250r. I think the ZRX1200 is close to 500.
Whats wrong with the gauge anyway, not showing full or empty??
Old May 21st, 2009, 08:28 PM   #5
krazygluon
Parking Lot Qualified
Motorcycle(s): '09 Ninja 250
Meh, my problem with the guage isn't the full/empty markers...its the complete nonlinearity of the needle as it moves from full to empty.
But seeing as that's a tank geometry problem, not an electronics problem, I can deal.
krazygluon is offline   Reply With Quote
Old May 22nd, 2009, 01:36 AM   #6
pantera
pantera's Avatar
Gauge does not show full when the tank is filled and reads empty after just 150 miles.At 150 miles on the trip and the gauge reading empty it took 3 gallons to fill the tank back up.
Old May 22nd, 2009, 01:44 AM   #7
I take it the bike is not under warranty?
Old May 22nd, 2009, 01:57 AM   #8
pantera
pantera's Avatar
No ,the bike is no longer under warranty.How many miles can you travel on a full tank before the gauge reads empty?
Old May 22nd, 2009, 02:10 AM   #9
roughly 160-180.
Old May 22nd, 2009, 07:34 AM   #10
HKr1
IC2(SW)
HKr1's Avatar
Think check the float resistance @ full, and go from there
That might be the total they were looking for over all. That 470 & a 500 sender would be kinda close @ 242.
Old May 31st, 2009, 11:21 AM   #11
pantera
pantera's Avatar
Someone on another site just told me Kawasaki has a new updated gas gauge for these bikes.Any one else know anything about this?
Old March 24th, 2012, 08:37 PM   #12
GiGs
I realize this thread is a little (3 years) old... BUT I *may* have discovered a fix to all those who have the problem with the fuel gauge indicating the wrong status.
I want to make it clear that I do NOT have this problem.
IF YOU CANNOT SOLDER DO NOT ATTEMPT THIS !!!!
This is a picture of the back of my fuel gauge:
Notice the burnt plastic / hot glue ? That means those resistors are getting quite hot, hot enough (eventually) to possibly fail completely or go bad and give an inaccurate reading (which would give you a false reading on your fuel gauge !).
The ohm's should read as follows:
NOTE : You will need to cut 1 leg of the 47 ohm resistor to get a proper reading, otherwise it will give you a reading of the coil inside (which is 22 ohms with the resistor connected). IF YOU CANNOT SOLDER DO NOT ATTEMPT THIS !!!!
With that said, if your readings are not correct...the resistors will need to be replaced. From some super quick calculations, they are 3 watt's each, have an accuracy rating of +/- 5% (see the gold band at the end of the resistors..) and are metal film resistors.
You must buy the exact same ohm resistor if you want to have an accurate reading. The type i.e metal film is not "especially" important, the wattage can be higher (which will give off less heat) but CANNOT be any lower otherwise you risk burning it to a crisp.
For those measuring or replacing who are wondering, resistors DO NOT have a polarity i.e a positive + or a negative -. They can be installed OR measured either way, just make sure to set your multimeter to Ω or 200 Ω before you start measuring
Bear in mind that this is only going out on a guess as I have no other proof minus the bunt glue/plastic mix on the resistor....
If your willing to try this, great...please let me know the results.
Be warned, it's a big job (my bike is completely apart so it was very easy for me but that's a whole other story). I am not and will not be held responsible for anything you screw up.
That was just a quick post, if more detail is needed let me know i'll try to check back here.
GiGs is offline   Reply With Quote
Old March 25th, 2012, 02:19 AM   #13
Mine reads empty before it is sometimes and not empty when it is empty others, so I doubt my inaccuracy is caused by this.
Gas gauge Bblock 2008 - 2012 Ninja 250R Tech Talk 6 August 7th, 2013 09:05 AM
Gas Gauge Stingray1000 1986 - 2007 Ninja 250R Tech Talk 3 May 16th, 2012 05:36 PM
Gas Gauge gilmorec61 2008 - 2012 Ninja 250R Tech Talk 3 January 19th, 2012 03:19 PM
Fuel/Speedo gauge fix ninja250 2008 - 2012 Ninja 250R Tech Talk 8 September 11th, 2011 08:07 AM
Noob and gas gauge BlackDynamite 2008 - 2012 Ninja 250R Tech Talk 4 October 2nd, 2010 07:40 PM
