March 1st, 2023, 04:02 PM | #1 |
[motorcycle.com] - 2023 Husqvarna Norden 901 Expedition First Look
As we expected, Husqvarna announced a new Norden 901 Expedition, adding a more adventure-capable model to its lineup. Equipped with longer-travel suspension and coming standard with a number of accessories such as waterproof luggage, the Norden 901 Expedition carries an MSRP of $15,799, a $1,300 premium over the regular Norden 901.
The engine remains the same 889 cc Parallel-Twin as the regular Norden 901, sharing the same DNA as the engine from its Pierer Mobility cousin, the KTM 890 Adventure. Peak performance figures are the same 103 hp at 8,000 rpm and 73.8 lb-ft. at 6,500 rpm claimed by the regular Norden. The electronics are also similar to the base model, with cornering ABS, cornering traction control, torque control, motor slip regulation, and cruise control as standard. The Norden 901’s three ride modes, Street, Offroad, and Rain, carry over, but the Expedition also gains the customizeable Explorer mode as standard. The tubular chromium-molybdenum steel frame and steel trellis subframe are also unchanged, offering a balance between light weight and strength. Husqvarna swapped out the Norden 901’s WP APEX 43 fork for a fully adjustable 48 mm WP-XPLOR inverted fork with 9.4 mm of travel. Likewise, the WP APEX monoshock was replaced with a XPLOR shock with a progressive damping system (PDS) and adjustable preload, high and low speed compression, and rebound damping. The Expedition also comes standard with a steering damper, and the frame may be fitted with an adjustable offroad steering damper. We don’t know the Norden 901 Expedition’s seat height yet, but we expect it will be higher than the base Norden’s seat which is adjustable between 33.6 and 34.4 inches. We do know the Expedition offers 10.6 inches of ground clearance compared to the regular model’s 9.9 inches of clearance. The Norden 901 Expedition comes with spoked tubeless rims, with a 21-inch front and 18-inch rear wheel. Pirelli provides the Scorpion Rally STR tires. For improved touring capability, the Norden 901 Expedition comes with a tall windscreen, heated grips, a heated rider seat, and a set of waterproof side bags, offering 18 liters of storage per side. The 5.0 gallon fuel tank is unchanged from the Norden 901, with Husqvarna claiming the same fuel consumption of 52 mpg. Completing the package are a center stand, a heavy duty skid plate, and smart phone connectivity with turn-by-turn navigation, all previously offered as separate accessories for the regular Norden. With all the added parts, it’s no surprise that the Expedition is heavier than the base Norden, tipping the scales at a claimed 472.9 pounds (without fuel), a 23-pound weight difference. The 2023 Husqvarna Norden 901 Expedition is expected to arrive in showrooms this month. 2023 Husqvarna Norden 901 Expedition SpecificationsMSRP$15,799Engine Type2-cylinder, 4-stroke, Parallel-Twin, liquid cooled with water/oil heat exchangerDisplacement889 ccBore x Stroke90.7 mm x 68.8 mmEMSBosch EMS with RBWHorsepower103 hp at 8,000 rpm (claimed)Torque73.8 lb-ft. at 6,500 rpm (claimed)StarterElectric starterLubricationForced oil lubrication with 2 oil pumpsClutchPASC antihopping clutch, mechanically operatedTransmission6-speedChain520 X-RingFrameChromium-Molybdenum-Steel frame using the engine as stressed element, powder coatedFront Suspension48 mm WP*XPLOR-USD fully-adjustable inverted fork, 9.4 mm of travelRear suspensionWP*Xplor PDS fully adjustable monoshock, 9.4 mm of travelGround clearance10.6 inchesFront brake2x radially mounted 4 piston caliper, 320 mm discsRear brake2 piston floating caliper, 60 mm discABSBosch 9.1 MP (incl. Cornering-ABS and offroad mode, disengageable)Rake25.8°Weight472.9 pounds (without fuel, claimed)Fuel Capacity5.0 gallonsFuel Economy52 mpg (claimed)Become a Motorcycle.com insider. Get the latest motorcycle news first by subscribing to our newsletter here. The post 2023 Husqvarna Norden 901 Expedition First Look appeared first on Motorcycle.com. Click here for full story...
[roadracingworld.com] - Video: Husqvarna Launches Norden 901 Expedition Adventure Tou | Ninjette Newsbot | Motorcycling News | 0 | March 1st, 2023 11:54 AM |
[cycleworld.com] - 2023 Husqvarna Norden 901 Expedition Confirmed | Ninjette Newsbot | Motorcycling News | 0 | January 27th, 2023 04:28 AM |
[visordown.com] - Husqvarna Norden 901 Expedition leaked from dealer summit | Ninjette Newsbot | Motorcycling News | 0 | January 25th, 2023 02:17 AM |
[RideApart] - EPA Approval Supports Husqvarna Norden 901 Expedition 2023 Launch | Ninjette Newsbot | Motorcycling News | 0 | January 24th, 2023 12:24 PM |
[motorcycle.com] - 2023 Husqvarna Norden 901 Expedition Certified by EPA | Ninjette Newsbot | Motorcycling News | 0 | January 23rd, 2023 03:43 PM |
