March 24th, 2012, 05:55 AM | #1 | |
AU model has different gearing? Why?
I noticed this while perusing the service manual:
March 24th, 2012, 06:25 AM | #2 |
Average elevation may have something to do with it. The U.S. average elevation is 2500 ft and Austalia's is 1,082 ft.
March 24th, 2012, 07:58 AM | #3 |
Interesting theory but, in the same section, it mentions understandable specification differences for many other regions and countries (exhaust, for example) but no other with differing sprocket gear ratio. Is AU's elevation really so different from every other place it's sold? Strange.
March 24th, 2012, 12:40 PM | #4 |
Is it because the AU model is FI and that makes more torque? what about the UK or EU version?
March 24th, 2012, 01:19 PM | #5 |
Join Date: Feb 2012 Motorcycle(s): '10 Ninja 250 Racer Posts: 95
AU model is carb
#77 |
March 24th, 2012, 02:17 PM | #6 |
So, where's the reverse?
Having different gear ratios in cars for different regions is something manufacturers have been doing for a while so I'm not surprised to see it with motorcycles. The US and Canadian version of the 250R gets the same gear ratio while the AU, EU and UK versions are the same. I assume the reason behind the differences is most likely traditional market preferences and needs.
March 24th, 2012, 05:41 PM | #7 |
Regardless of the reason that the AU bikes have 14/43 gears, if I were in AU, I would be swapping to 14/45 or 14/47 pronto
March 24th, 2012, 06:47 PM | #8 |
Not to mention that they sell less E10 gas than the U.S. does. That may give them a little boost as well.
March 24th, 2012, 07:40 PM | #9 | |
May 10th, 2012, 06:26 PM | #10 |
Join Date: Jan 2012 Motorcycle(s): Green 2012 Ninja 250SE and a Yamaha fino scooter (my wife's really) Posts: 355
Thailand spec has the same 14/43 and it is FI
Be safe ride smart .....a dumb rider is a dead rider |
May 12th, 2012, 07:24 AM | #12 | ||
Join Date: Sep 2010 Motorcycle(s): 2008 Kawasaki Ninja 250r Posts: 139
AU Ninja owner here ....
As kavo correctly said AU model bikes are carbed.... Quote:
I can't tell you the real reason why the gearing is different (top secret)...but it does involve kangaroos... |
March 18th, 2013, 11:15 PM | #13 | |
The A Team
Join Date: Aug 2012 Motorcycle(s): Z50, CB125, RZ500, MC22, R3. Posts: 394
I'd read on here that 45 is standard not realizing that our Au bikes are geared too high from factory (could be strict emission/noise laws) Bought Ninja 250 race bike, did two track days on it, struggles to pull its 14/43 gearing, Local bike shop listed 43 as standard in the aftermarket catalogue Couldn't work out why. Ordered 45, hopefully its better or I'll try a 47. |
March 19th, 2013, 12:06 AM | #14 | |
Join Date: Jan 2012 Motorcycle(s): 2012 ninja 250r se Posts: 435
carbs are tuned with different jets im going to a 15t front sprocket to outrun kangaroos and drop bears it pulls 14 - 43 gearing very well and have toped out a fair few times cruising the bush roads. why going to 15t AUSSIE IS CARBY AUSSIE IS CARBY AUSSIE IS CARBY AUSSIE IS CARBY AUSSIE IS CARBY AUSSIE IS CARBY |
March 19th, 2013, 01:02 AM | #15 |
The A Team
Bet its a slug with a 15T front.
March 19th, 2013, 02:56 AM | #16 |
Join Date: Mar 2012 Motorcycle(s): Ninja 250r 2010 SE Posts: 573
Gigs is correct. its not because of emissions. We have 1 less catalytic converter. Nor hills. we have plenty, ever heard of the blue mountains.
It is because of the laws in Australia. This motorcycle is marketed for a learner rider. it is called lams. Someone who is new to riding. Hence they lower the gearing to give a more useable first gear and easy take off. |
March 19th, 2013, 06:44 AM | #17 | |
I hope you like your bike more after gearing changes. |
March 19th, 2013, 07:01 AM | #18 |
14/45 drops your speed by about 7km in each gear my friend. I have changed from 14/43 to 14/45.
You get 54 km in first a bit under 75 km in second. 3rd only goes to 103 km and fourth goes to about 125km. Instead of 60,80,110,138. Changing gear at 13k Hope this helps. |
March 19th, 2013, 07:09 AM | #19 |
Well, yeah. ^^
But he said he's looking for more pull, not higher speed. To me, I read that as wanting quicker roll-on to blast out of turns. Besides, these bikes are horsepower limited to right around 100 mph anyways. You'd be surprised. I thought it would be too. It definitely is compared to 14/47, but the trade-off is you can pull for longer. So if you ride a lot of long sweepers, 15/45 will let you pull the whole way past apex. The trade off is that for tight back roads you need to enter turns at really high rpm's to get the pull you want. Really the only place you notice the tall gearing is when you do roll-ons and expect it to move. Now the guys who run 15/42 for fuel economy, idk how they do that. 15/45 is as high as I'll ever go |
March 19th, 2013, 07:23 AM | #20 |
I wasn't referring to you chris. I know you know whats going on.
The notice in take off and acceleration is quite noticeable with the 14/45 compared to 14/43. The bike doesn't seem to want to bog as much when taking off and the revs don't drop nearly as much when shifting between 1st and 2nd. |
March 19th, 2013, 08:49 AM | #21 |
The A Team
Ive got a long uphill out of a 4th gear corner where it sits and bogs, want to click 5th sooner,
My qstars tells me Im only getting up to 127.14kph in 5th at my braking point my cbr was getting 132kph with -1 front. But the Ninja is over 1 second faster laptime already as its faster on the more flowing part of the track. I'll get the 47 as well and try both at Easter as its tuning saturday/race sunday. cheers choneofakind, I like riding 250's and the ninja has its strengths over the cbr, mainly in having a wider rev range to play with, may as well make the best of it. (and grow a set and just ride that little bit harder as I get familiar with it) |
March 19th, 2013, 09:16 AM | #22 |
March 19th, 2013, 10:00 AM | #23 | |
The A Team
USA has lower(shorter) gearing. |
March 19th, 2013, 10:52 AM | #24 |
March 19th, 2013, 04:58 PM | #25 |
Bass Master General
This is interesting, I was thinking about performance mods for my bike, since I have a UK spec bike, of which I assume to be the same as french and german giving the manual's languages, I must have a 43 tooth rear sprocket, given the speed limit here is a strict 35mph tops and the landscape is mainly hills and valleys, I am probably better to upgrade to a 45 tooh rear sprocket for more torque as i'll never reach anywhere near top speed, and if I did choose to go to the UK or france touring i'd still be capable on the motorways.
March 20th, 2013, 02:46 AM | #26 | |
i have 2 cats. one in the y section at the front, and one in the muffler. In NSW, holders of learner and provisional motorcycle licences are not permitted to ride a motorcycle with an engine capacity exceeding 660ml or a power to weight ratio exceeding 150 kilowatts per tonne and which do not appear on the Approved motorcycles for novice riders list. nothing about or to do with lower or higher gearing |
need gearing help!! | caliking | 2008 - 2012 Ninja 250R Tech Talk | 6 | April 7th, 2014 12:04 PM |
Gearing | jaybo | 2013 - 2017 Ninja 300 Tech Talk | 12 | January 18th, 2014 08:12 AM |
Need help with gearing for PIR | Racingredhead | Ninjettes At Speed | 2 | April 10th, 2013 04:30 AM |
Stunt Gearing | ninja250 | 2008 - 2012 Ninja 250R Tech Talk | 63 | October 29th, 2011 05:04 AM |
Reverse Gearing | Clearlynotstefan | General Motorcycling Discussion | 11 | April 21st, 2011 06:16 AM |
