Old March 31st, 2012, 03:46 AM   #1
GiGs
Quick question regarding fork seal job
Hi all, haven't posted here in a while (I don't feel as though I have much I can contribute...it's mostly all been covered ) but I have a quick question in regards to my fork seal job.
I am going to be replacing the fork and dust seals with a kit from eBay (All Balls Racing .... anyone heard of it / used it ??), I have been reading the service manual and all the posts related to fork seal jobs on this forum.
The manual says you should replace a and z and everything in between (which I personally see as slightly un-neccesary), some say you should just replace the snap rings and the fork and dust seals...others say bushings also (saw RacerX say it's a good idea to replace the upper bushing....)
My question is, what is necessary if everything is in good condition ?
GiGs is offline   Reply With Quote
Old March 31st, 2012, 06:55 AM   #2
jasle
Motorcycle(s): 09Ninja250, Ducati Monster 800ie, Harley FXSTS,Rebel 250,CR144,KX85,RM85L
It is never a "bad" thing to replace the bushings or sliders or clips.
that being said it is not always necessary to do them. The thing is people often do seals very infrequently, usually don't do them until all the fork oil is gone and they are a big problem. When this happens yes, you should most likely replace the bushings.
You can see how much slop in the lower to upper part of the fork. if they clunk forward and backward then you MUST replace the bushings else the seal will still leak.
Thanks to: , DUNLOP, WHOOPIE RACING, 995 PAINTWORKS, South Austin Motorcycles
jasle is offline   Reply With Quote
Old March 31st, 2012, 07:38 AM   #3
k-os
Motorcycle(s): 1988 Honda Hawk NT650, 1989 Honda Hawk NT650, 1997 GSXR750 Track Bike
If you've got your forks apart check the teflon coating on the bushings. If it's not worn down or chipped off anywhere you shouldn't have an issue re-using them.
k-os is offline   Reply With Quote
Old March 31st, 2012, 05:39 PM   #4
GiGs
Excellent, I completely understand - thanks for making it clear
This forum is probably the best I have ever used, big thanks again guys !!
Leak on right fork seal AmyF 1986 - 2007 Ninja 250R Tech Talk 17 July 11th, 2014 09:29 AM
Fork Seal is Stuck eddyble 2008 - 2012 Ninja 250R Tech Talk 7 October 21st, 2013 04:14 AM
OEM Brand New Fork Oil Seal, Dust Seal (08-12) capriccio Motorcycle-related 3 June 9th, 2013 05:11 AM
Fork Seal Leaking broken neck 2008 - 2012 Ninja 250R Tech Talk 16 June 2nd, 2013 11:40 AM
Leaking fork seal? EthioKnight 2008 - 2012 Ninja 250R Tech Talk 12 March 6th, 2012 09:20 PM
