Old June 25th, 2013, 11:22 AM   #1
quarterliter
Motorcycle(s): 2004 Ninja 250
Valve Adjustment
Im looking for a little more zoom up top I have sorted out my jetting and this is just something to give me a little extra. Should I set them as tight as recommended? How often should I check them if I do so?
Kevin
Old June 25th, 2013, 11:32 AM   #2
Red face
(Post deleted for helplessness).
Last futzed with by Motofool; June 25th, 2013 at 08:39 PM.
Old June 25th, 2013, 11:40 AM   #3
quarterliter
I already checked out that ninja250.org stuff Im just trying to get another opinion. From someone who races and has or has not noticed a difference. The wiki isnt always correct.
Old June 25th, 2013, 11:56 AM   #4
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
ummm, unless your racing I would leave the at spec. not worth the risk for minimal power gains, and the added maintenance. unless you don't mind tearing it apart over and over again.
Old June 25th, 2013, 12:02 PM   #5
quarterliter
I would have the valves set to minimum lash so still in spec. And I dont mind wrenching on stuff I actually enjoy it.
Old June 25th, 2013, 12:03 PM   #6
quarterliter
Lets put it this way I took the bike apart far enough to remove the airbox get rid of the backfire mesh, molding flash and finished everything including the intake runners with 2000 grit sand paper........
Old June 25th, 2013, 05:24 PM   #7
j98sprint
Motorcycle(s): '02 Ninja 250, '98 Triumph Sprint 900, '69 H-D Sportster XLCH 900
You won't feel the difference.
j98sprint is offline   Reply With Quote
Old June 25th, 2013, 05:32 PM   #8
dude, leave the valves at the loose end of spec. Starts are so much easier with looser valves. If you're looking for minimal zoom up top, swap cams with a bike made from 1988-1992.
Would you do your valve adjustment? Bigballsofpaint 2008 - 2012 Ninja 250R Tech Talk 30 July 24th, 2013 09:04 PM
Valve adjustment ?s Jewtoys 2008 - 2012 Ninja 250R Tech Talk 5 August 1st, 2012 08:47 PM
valve adjustment little fish 1986 - 2007 Ninja 250R Tech Talk 8 November 4th, 2011 10:10 AM
Valve Adjustment-Really Tight adjustment screw? mikesova 1986 - 2007 Ninja 250R Tech Talk 5 May 2nd, 2010 04:57 AM
anyone want to help with a valve adjustment? diablo250 Group Rides and Local Events 2 March 28th, 2010 02:00 AM
