Go Back   ninjette.org > Marketplace > Motorcycle-related
Old August 16th, 2014, 08:47 AM   #1
Bigballsofpaint
Tokico/Brembo axial adapter GB - 250 & 300
Since Brad at SV Racing makes the tokico adapters for the same price (minus my GB discount), i dont plan on making more of them. Im not here to step on any toes, just provide parts that no one else makes at the moment. Im not a business with mouths to feed, so if you need a tokico go to his site. A few have bought them already with great results (although i like to think mine looks better )
But i will still make the brembo for those who want, i also still plan on doing the radial unit, so no worries there.
For the brembo you need a 65mm axial brembo caliper, with a 310mm rotor in mind. I dont expect many to be interested in this, but i have made it in the past so i leave the option open to you.
Price is as follows
1-4 members = 50 shipped
5-9 members = 45 shipped
10+ members = 40 shipped
Shipping internationally is significantly more, so far the canadians will need to pay an extra 15, and australians an extra 20. So if theres a group of you up there i recommend me sending to one individual, and then they can split it up to save on shipping.
Im also working on a radial unit, but that progress will be a little slower since i still need to mock things up and what not. It will also cost a little more.
Last futzed with by Bigballsofpaint; September 16th, 2014 at 07:24 AM.
Old August 17th, 2014, 10:32 AM   #2
howlinhoss
Motorcycle(s): Ninja 300
Posting to confirm my interest. Thank you!
howlinhoss is offline   Reply With Quote
Old August 19th, 2014, 05:38 AM   #3
Tedge
Tedge's Avatar
Motorcycle(s): '13 Ninja 300
In for one.
Tedge is offline   Reply With Quote
Old September 5th, 2014, 05:21 AM   #4
e30 gangsta
Motorcycle(s): ninja 300
In for one thank you.
e30 gangsta is offline   Reply With Quote
Old September 5th, 2014, 05:55 AM   #5
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
just to clear things up regarding the brembo set up. The rotor used was an bolt on Ara Shi rotor designed for the ninja250, it was advertised on ebay as a 320mm It looks like it is actually a 310mm rotor.
There are other ads on ebay for the same rotor that say 310mm so keep this in mind.
Old September 7th, 2014, 12:24 AM   #6
lukephua
That is correct! I too am going for the brembo set up. Here's the link I bought mine from.
http://www.ebay.com.au/itm/251170124...84.m1439.l2649
Not sure if it helps anybody though.
lukephua is offline   Reply With Quote
Old September 7th, 2014, 06:19 AM   #7
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
Originally Posted by Bigballsofpaint View Post
Works with stock sized rotor only, if you have an aftermarket 300mm rotor you need thinner nuts in the back, i can include those as long as you tell me beforehand.
Just wanted to point out that the Galfer aftermarket rotor I used is intended to be an OEM replacement and is stock sized, not 300mm, as far as I know.
Old September 7th, 2014, 08:45 AM   #8
Bigballsofpaint
Thanks Rebecca, i fixed it. I though stock was 300mm, ill just refer to it as OEM replacement from now on haha
Old September 11th, 2014, 09:36 AM   #9
e30 gangsta
I need one of these badly, Im a big guy and the front brake just isn't enough! Question when ordering pads are they the same pads as the ninja 300? Or we have to order pads for a gsxr? Thanks.
Old September 11th, 2014, 09:37 AM   #10
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
pads are specific to the caliper
Old September 11th, 2014, 11:09 AM   #11
tfkrocks
tfkrocks's Avatar
Yep you'll have to get different brake pads. It's a good chance to try some new ones though.
Old September 16th, 2014, 07:24 AM   #12
Bigballsofpaint
Updated first post, no longer making the tokico for people. But still can make the brembo and still plan to do the radial unit.
Old September 16th, 2014, 08:44 AM   #13
sharky nrk
sharky nrk's Avatar
Old September 25th, 2014, 01:25 AM   #14
mr2peak
Motorcycle(s): Hyper 821
I'm interested. Which bike do I source the brembo brakes and oversize rotor from? Need to price everything out before I commit.
mr2peak is offline   Reply With Quote
Old September 26th, 2014, 10:25 PM   #15
lukephua
For the brembo rotor, it will require a 310mm rotor like this one: eBay item number:271054402068
And for the Brembo caliper, I believe it's any 65mm bolt spacing RIGHT sided caliper.
Rotor costed me about $150?
Caliper will be about.. $100-200?
Pads another $50?
Depends if you want new or used caliper..
Old June 14th, 2023, 05:57 AM   #16
superkain
Motorcycle(s): k6 GSX-R 750, 2008 Ninja 250R
Price is as follows
I'm looking to pick up another couple brackets like this. Please, sound off anyone if you want to get enough people together to get another batch made!
superkain is offline   Reply With Quote
Old June 22nd, 2023, 01:09 AM   #17
punishum808
punishum808's Avatar
Motorcycle(s): Suzuki JPN Katana 750 , 1994 Suzuki Pro Stock Motorcycle , 2001 Ninja 250
I would be interested for a couple. Would be nice to see pics as to the application instead of just text.
punishum808 is offline   Reply With Quote
Old June 28th, 2023, 10:00 AM   #18
superkain
Welp, I sold the 300 and getting a 400. Hence, I have one of these brackets, stainless steel line, and a 636 master that I'm not going to use. If you want a whole brake upgrade package, let me know!
Old June 28th, 2023, 12:32 PM   #19
punishum808
Only interested in the bracket.
Brembo/Tokico Caliper adapter, 250 & 300 GB Bigballsofpaint Motorcycle-related 173 June 14th, 2023 05:56 AM
Koso Oil Temp Sensor Adapter & Water Temp Sensor Adapter StaylorT 2008 - 2012 Ninja 250R Tech Talk 10 January 24th, 2014 12:38 AM
