Old June 30th, 2013, 02:39 AM   #1
deeno415
deeno415's Avatar
Motorcycle(s): 2006 Kawasaki EX250(Bright Yellow)
Won't start... :( HELP!
Ok... I tried looking at different threads and had no luck finding a solution. Maybe you guys can help me out...
My 2006 Ninja 250 stalled on me when I was on the freeway. I think it was because I ran out of fuel. I looked inside the fuel tank to see if I had some fuel in there and there was a little bit (but not much). Anyways, I tried starting the bike and it would crank, but not turn over. I continued to try to start it and finally NOTHING! I mean, it won't even crank! I pushed my bike in the emergency lane for about half a mile until I was off the freeway. All in 100 degree weather in Pleasanton, CA. UGH!
My question is: By attempting several times with the ignition button, did I kill the starter?
Luckily, I had a friend that was close by help me 'bump start' the bike to get it to a gas station.
I had to 'bump start' the bike after the fill up and rode it back 40 miles to San Francisco.
So why can't I start the bike the normal way? What the EFF did I do to my bike?
Anyone? Please help...
deeno415 is offline   Reply With Quote
Old June 30th, 2013, 04:00 AM   #2
tubarney
You most likely drained your battery.
How long did you push the starter button for?
Old June 30th, 2013, 07:56 AM   #3
Originally Posted by deeno415 View Post
.........My 2006 Ninja 250 stalled on me when I was on the freeway. I think it was because I ran out of fuel. I looked inside the fuel tank to see if I had some fuel in there and there was a little bit (but not much). Anyways, I tried starting the bike and it would crank, but not turn over..........
Di you turn the petcock to reserve?
Check this out:
http://faq.ninja250.org/wiki/Troubleshooting
Old June 30th, 2013, 10:09 AM   #4
sLick415
Dead battery
sLick415 is offline   Reply With Quote
Old June 30th, 2013, 10:20 AM   #5
+1
Old June 30th, 2013, 10:20 AM   #6
/moved to pre-gen tech, OP has a 2006. (with a reserve setting on the petcock)
Old June 30th, 2013, 10:45 AM   #7
GREY NINJA
Motorcycle(s): 2002 ninja 250
If you jump start it and it starts, then battery need changing
GREY NINJA is offline   Reply With Quote
Old June 30th, 2013, 01:43 PM   #8
deeno415
deeno415's Avatar
I was an idiot and continued to press it over and over again until it no longer would crank. ( I was desperate to get out of the 100+ degree weather and off the freeway).
Old June 30th, 2013, 01:46 PM   #9
deeno415
deeno415's Avatar
Check this out:
After I walked half a mile, in 100+ degree heat, and got off the freeway I did switch over to reserve and bump started my bike to get it to a gas station.
Old June 30th, 2013, 01:50 PM   #10
deeno415
deeno415's Avatar
Originally Posted by sLick415 View Post
Dead battery
So my battery is shot? I tried to start the bike this morning and could hear a click from what I'm assuming is a relay or solenoid. It's only one click (not a repetitive clicking). It won't even crank. Is it just my battery? Can the battery be saved by charging it or do I need a new one? I checked the voltage on it and I got a reading of 12.6...
Old June 30th, 2013, 01:52 PM   #11
deeno415
deeno415's Avatar
BTW... thanks for your guys help! I know I rather be out riding right now too...
Old June 30th, 2013, 02:07 PM   #12
So my battery is shot? I tried to start the bike this morning and could hear a click from what I'm assuming is a relay or solenoid. It's only one click (not a repetitive clicking). Can the battery be saved by charging it or do I need a new one? I checked the voltage on it and I got a reading of 12.6...
http://faq.ninja250.org/wiki/How_to_...attery_is_dead
You are welcome
Old June 30th, 2013, 02:09 PM   #13
PEN25
Motorcycle(s): 2001 ex250
your battery maybe fine, but when was the last time you replaced it? btw put in an external fuel filter that is clear so you can visually see the fuel.
PEN25 is offline   Reply With Quote
Old June 30th, 2013, 02:25 PM   #14
deeno415
deeno415's Avatar
I bought the bike used and I'm assuming it is the original battery. Previous owner didn't have any service records...
I did get a reading of 12.6 when I tested the battery. However, I tried starting the bike and all I would get is a click when I pressed the start button. No starter crank... no other sounds... just a 'click'. What else could it be? I'm kinda a newb to motorcycles and its mechanics. Is there anything else I should check?
Old June 30th, 2013, 03:54 PM   #15
GREY NINJA
Old June 30th, 2013, 07:28 PM   #16
PEN25
after letting it charge it should read around 13.8v if it doesnt come up to 13.8 and you have good fluid levels then the battery needs replaced. i have a battery minder and it can revive some batt's but most replace theirs about every 3 or 4 years if not every year if they dont start it on the off season
Old July 1st, 2013, 12:13 AM   #17
deeno415
deeno415's Avatar
I'll let it sit with the battery charger and hope that it starts up tomorrow... keeping my fingers cross until then!
If I get no change in status, what should I proceed on checking?
Old July 1st, 2013, 01:36 AM   #18
GREY NINJA
If that do not work time for a new battery
Old July 1st, 2013, 07:34 PM   #19
deeno415
deeno415's Avatar
Dead battery
So I forgot to charge the battery last night...
So, I decided to just jump start the bike.
I connected the booster cables... switched everything on... and NOTHING!
I couldn't jump start the bike!
Why can't I start my bike??? My other question is: Wouldn't a battery kinda recharge itself if I rode the bike over an hour?
Please help...
Old July 1st, 2013, 07:43 PM   #20
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
Did you check the battery voltage before connecting?
Did you check connections?
If the Charging system works properly, yes. We will need more info to diagnose.
Please help...
If battery reads 12.6 after recharge, battery is "ok". Next, check fuses, especially the main fuse. Also make sure you have proper connections at battery and ground.
Do any lights come on when in ON position?
Have you installed any thing electrical on the bike recently?
Old July 1st, 2013, 08:06 PM   #21
deeno415
deeno415's Avatar
The next day after this incident is when I checked the battery voltage and got a reading of 12.6v...
I checked all the fuses (including the one on the main relay) and connections... all seem to be ok.
When I turn the bike on, the indicator lights come on along with the rear tail lights, but not the headlight.
I have not installed anything new on the bike...
Old July 1st, 2013, 09:24 PM   #22
Asspire
Asspire's Avatar
headlight will come on when engine is turned over. Start with checking starter relay.
Old July 1st, 2013, 09:28 PM   #23
deeno415
deeno415's Avatar
How can I test the starter relay? When I try to start the bike, all I hear is a single click. No crank whatsoever...
Old July 1st, 2013, 09:40 PM   #24
TBC
TBC's Avatar
Motorcycle(s): 2004 Ninja 250F
New battery...
TBC is offline   Reply With Quote
Old July 1st, 2013, 10:05 PM   #25
deeno415
deeno415's Avatar
Originally Posted by TBC View Post
New battery...
Everyone says new battery... but even if the battery was bad, wouldn't I be able to jump start the bike??? Or at least get a crank with the booster cables connected?
Old July 1st, 2013, 10:07 PM   #26
deeno415
deeno415's Avatar
Someone please explain to me as if I was a _______
Old July 1st, 2013, 11:28 PM   #27
deeno415
deeno415's Avatar
Is it possible I fouled the spark plugs?
Old July 2nd, 2013, 01:51 AM   #28
GREY NINJA
No because your engine will still turn over, try to jump it from the starter......connect the red/POSITIVE CABLE TO THE NUT ON THE STARTER( look at picture) and touch the other to a ground
Old July 2nd, 2013, 02:23 AM   #29
deeno415
deeno415's Avatar
GREY NINJA: So you are saying instead of connecting the booster cables to the battery, I should connect the positive directly to the starter? Or do you mean directly connecting the positive from the bike battery to the starter? Couldn't I also just connect a jumper to the posts of the starter solenoid to get the bike to crank?
Also, the picture of the starter is so small... do you have a bigger picture?
Old July 2nd, 2013, 08:24 AM   #30
GREY NINJA
Jump from car battery (do not run the car battery) and put the positive clamp directly on the starter nut and the neg. on the frame or any ground on the ninja...I just took my starter apart to fix it
Old July 2nd, 2013, 05:59 PM   #31
PEN25
12.6 is a sign of a low battery. but could also be symptomatic of a dead cell. it you cant get that battery up to above 13volts time for a new battery. its possible the fuse blew when you attempted to jump it. just be warned your motorcycle probably wont charge much even after riding for an hour.
Old July 2nd, 2013, 06:01 PM   #32
Jred
Motorcycle(s): Several
12.6v is not a sign of a low battery.
Jred is offline   Reply With Quote
Old July 2nd, 2013, 06:22 PM   #33
PEN25
sorry dont know what i was thinking except i was thinking of a car battery. 2.1volt per cell on a motorcycle compared to 2.3 for car battery.
Old July 2nd, 2013, 07:49 PM   #34
deeno415
deeno415's Avatar
So I've tried jumping the bike, both by 1)connecting the booster cables to bike battery and rear brake lever, and 2)directly to the starter bolt. Couldn't get my bike to jump either way... just strange to me even if the battery is a goner.
I was able to bump/push start my bike again just because I felt I needed to ride it... (and I did for 2 hours).
Still can't start my bike the normal way!
What else do I need to start checking while I wait for the new battery to arrive???
Old July 2nd, 2013, 07:54 PM   #35
PEN25
did you check the fuses http://faq.ninja250.org/wiki/How_to_check_the_fuses
Old July 2nd, 2013, 08:03 PM   #36
deeno415
deeno415's Avatar
I checked all the fuses, including the main fuse and they all checked out fine. This was before I tried jump starting the bike... I'll check them again and make sure I didn't blow any fuses.
If the fuses are fine, is there anything else I should check?
Old July 2nd, 2013, 08:25 PM   #37
PEN25
wiring. when you try to jump it does it even make the clicking sound? if not its possible your starter solenoid is bad. if you hit it with the jumper cables and it does nothing its you starter
Old July 2nd, 2013, 09:56 PM   #38
deeno415
deeno415's Avatar
I get a single click, not the repetitive click... I'm gonna try putting a jumper from the posts of the solenoid to see if it cranks.
Old July 3rd, 2013, 01:51 AM   #39
GREY NINJA
I had that same problem
Old July 3rd, 2013, 07:35 AM   #40
tc.young
Motorcycle(s): '89 klr 650, '00 250r
one click might mean the connection between the main wires and the battery are not getting enough contact. try loosening it, wiggling it and tightening the cables to the battery.
tc.young is offline   Reply With Quote
Won't start Espinoza07 1986 - 2007 Ninja 250R Tech Talk 6 September 14th, 2014 08:07 PM
Help!!!!!!!! - bike won't start auntymunga 2008 - 2012 Ninja 250R Tech Talk 5 August 18th, 2014 06:54 AM
bike won't start... nebraskan 2008 - 2012 Ninja 250R Tech Talk 4 May 11th, 2011 01:48 AM
Ninja Won't Start!! Tintkng 2008 - 2012 Ninja 250R Tech Talk 3 March 7th, 2010 12:18 PM
Won't start Momaru 2008 - 2012 Ninja 250R Tech Talk 15 August 9th, 2009 09:48 PM
