Old May 6th, 2010, 12:34 PM   #1
billybobjoeiv
billybobjoeiv's Avatar
Motorcycle(s): 2005 Kawasaki Ninja 250
Right Sprockets?
Hey,
Relatively new to riding and have to ride the bike up from college (FL) to home (OH). i did a 1100 mile trip earlier this year but didnt like the high RPMs so im switching the sprockets. Ive got a million things going on though at the moment and havent had much time for research on which ones to buy. Ive found these two though. Will these work for replacing the stock sprockets without replacing the chain? 15T front sprocket and 43T Rear.
http://www.motorcycle-superstore.com...50R-Parts.aspx
Thanks much!
billybobjoeiv is offline   Reply With Quote
Old May 6th, 2010, 12:42 PM   #2
billybobjoeiv
wow im tired.....
put it in the wrong year's forums. can i get this moved to -2007? haha...
Old May 8th, 2010, 06:45 PM   #3
/moved to pregen tech
Old May 28th, 2010, 04:53 PM   #4
longhorn
Sprocket Change
You can go to 15/41 with the stock 106 link chain. If you go to 15/38 you need a 104. I just did 15/41 and it works real fine. Just going to 43 is not really worth the effort. Remember 1 at the front = about 3 at the back.
longhorn is offline   Reply With Quote
Old May 28th, 2010, 09:31 PM   #5
03slime250
Motorcycle(s): 2003 ninja 250
whats the difference in changing only one or the other?
03slime250 is offline   Reply With Quote
Old May 28th, 2010, 11:28 PM   #6
longhorn
Sprocket Change Effects
If you want find all the effects of changing sprockets go to "gearingcommander.com" and look up Kawasaki/ZZR/250-YEAR. It will give you all you will ever want to know, and more, about the effects of sprocket changes. Simply put: one tooth at the front lowers the gearing about 7% and 3 at the back by another 7% for a total of about 15%. This drops your revs at 60mph by about 1,100 - which is like having another whole gear above 6th. Of course the gaps between the gears are a bit bigger so it won't accelerate quite so fast but I don't notice it, and it makes 1st quite a bit more useable. I found my gas consumption went from about 70 to 78 ish mpg, but I am under 120# and ride like an old lady.
Old May 29th, 2010, 12:01 AM   #7
billybobjoeiv
ended up going with the 43 in the back. probably should have just done the 41, but i was worried about getting up hills without too much effort. im 195#. oh well. i like it. not screaming as loudly down the highway. although, the one time i tried it, i couldnt get it past 11ish thousand rpms in 6th on the highway. not enough power i guess with the sprocket change. at least on flat ground
Old May 29th, 2010, 09:30 AM   #8
longhorn
Right Sprockets
Your 5th is now the same as the stock 6th! Try WOT in 5th and see how it goes, 13,000 rpm should give you about 105.6 mph true, if you can get there.
Old May 29th, 2010, 02:15 PM   #9
billybobjoeiv
im not sure whats up with my bike. before the sprocket change, i could only get it to go up to 101 mph indicated, which is even less in true, at redline. what could the problem be?
Old May 29th, 2010, 02:29 PM   #10
Not a problem, that sounds about right.
Old May 30th, 2010, 04:59 PM   #11
billybobjoeiv
oh ok, thanks!
New sprockets min nin 1986 - 2007 Ninja 250R Tech Talk 21 May 28th, 2013 07:48 AM
Where to get sprockets? Graugaard 2008 - 2012 Ninja 250R Tech Talk 8 February 21st, 2013 07:38 PM
Sprockets, sprockets, ahhh sprockets?!?! shelei09 General Motorcycling Discussion 10 January 23rd, 2013 09:47 PM
how do my sprockets look reaperw 2008 - 2012 Ninja 250R Tech Talk 4 December 29th, 2011 10:20 AM
Sprockets again voodoomaster 1986 - 2007 Ninja 250R Farkles 13 April 8th, 2010 11:08 AM
