February 11th, 2014, 01:57 PM | #1 |
TWF Racing needs a stock fork: Cartridge Kit R&D
In 2012 I paid Zoran to make some go-fast parts for my formula class SV. One of the things he's known for is stuffing a set of GSXR cartridges into the stock SV forks to give you a fully adjustable suspension. The set I had worked very well and I kick myself for swapping to the inverts.
I've since traded off that bike for 2 others, one of them being a Ninja 250. I emailed Zoran once again to see if he's building those kits for the little ninja. He said he hasn't but he could do it. He just needs a stock fork to do the deal. The price for a full set of cartridges installed in the forks would be $700. You'd just send your set out to him and he'd handle it. I'm currently working with Cyclemall in Tustin and will be doing some R&D with them on a cartridge they plan to build from scratch. I found this out only after I talked to Zoran. What this means is Zoran's deal is on the table for anyone looking to take advantage. I'm not sending my forks out to him since Cyclemall is going to help me out. If anyone on here wants to take advantage, contact Zoran through his website: http://www.twfracing.com If you ask around the racing scene you'll find he's well known for making the SV go fast. I'm guessing he'd do the same with the Ninja if he turns his attention to it. Now that the SV classes are nearly formula across the U.S. I'm betting more riders will be racing the Ninja to save money, hence more need for these cartridges. |
February 12th, 2014, 08:31 AM | #2 |
Fighting Texas Aggie '05
would this be a stock gsxr cart in the fork housing or include reworking the stack?
February 12th, 2014, 09:37 AM | #3 |
The stack would be modified as well as the cartridge so that the assembly functions for a much lighter chassis that has more flex. You don't have to provide the GSXR parts either. He will provide everything. He will just need your stock forks.
February 12th, 2014, 11:00 AM | #4 | |
Join Date: May 2012 Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike) Posts: 748
Also, how would he handle the compression side since the adjusters on the top of the caps handle rebound and the compression adjustments are at the bottom? Would he have one fork control compression and the other fork control rebound? And to do that would that mean for compression control he removes the rebound valve and stack; and for the rebound control would he remove the compression valve and stack? I would really like to hear more details about this too
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear |
February 12th, 2014, 11:52 AM | #5 |
on my SV the left fork did compression and the right fork did rebound. big piston style
Best bet is to email Zoran and ask him all of your questions. I'm not the guy who does the conversion, he is. I just know it worked very well on my stock forks and it's a legal mod for supersport rules. |
June 24th, 2014, 11:11 PM | #6 |
Any word he is doing this still? I know Zoran/TWF does a good job and is a big part of the AFM. Id be interested if this was still available!
June 25th, 2014, 07:42 AM | #7 |
No one had the balls to send their forks out so I did it. He now has the means to do cartridges on the 250. I have the first set in my Ninja and I love them. Raced (And Won) at WERA during their Autoclub round last month.
June 25th, 2014, 11:13 AM | #8 |
Sounds good thanks for sharing! Is there anything I should know about the cartridges? I'll be contacting Zoran shortly.
WTB andreani fork cartridge kit | chugs | Items Wanted | 0 | February 15th, 2014 10:47 PM |
[RoadRUNNER] - Öhlins Fork Cartridge Kit for Harley-Davidson Touring Models | Ninjette Newsbot | Motorcycling News | 0 | December 18th, 2013 10:30 AM |
[motorcycle-usa.com] - Öhlins FKC 101 Fork Cartridge Kit for Baggers | Ninjette Newsbot | Motorcycling News | 0 | August 28th, 2013 01:50 AM |
[sportrider - latest stories] - Öhlins USA Announces New Front Fork Cartridge Kit Ap | Ninjette Newsbot | Motorcycling News | 0 | October 6th, 2010 11:10 AM |
