Old September 8th, 2014, 05:54 PM   #1
Ninja Bob
Certified Slacker
Ninja Bob's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R SE
Unhappy What is this thing called?
Long story short: I had a mechanic tighten the chain because I didn't have the right tools. Apparently he didn't tighten this part enough, cause it apparently came loose, turned, and got murdered by the sprocket. We were able to straighten the bolt, but I need to replace this cap. And like, by the end of the week. Cause I'm supposed to be going on a road trip. x_x
Ninja Bob
Ninja Bob is offline   Reply With Quote
Old September 8th, 2014, 05:58 PM   #2
Ninja Bob
Certified Slacker
Ninja Bob's Avatar
@Ducati999
I noticed this when I went to make that repair we talked about. I don't know if the issues are related. He said he checked multiple times to make sure this part was tightened correctly.
Ninja Bob
Old September 8th, 2014, 07:29 PM   #3
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
http://www.kawasaki.com/SITE/VIVEHIC...rchModel=EX250 (in the Swingarm section)
"Chain Adjuster Cap"
That's what the nut threads against to tighten the chain. Once it's pulled tight, you tighten the axle nuts to hold it in place (so the adjusters aren't holding it in normal operation, just getting it into position initially). After tightening the axle, the adjusters might not be perfectly tight due to a tiny bit of movement, but they shouldn't be that loose either - that indicates that the axle was pulled back further while it was being tightened if the adjusters got that loose. I'm no expert, but I wouldn't trust a mechanic who screwed up that bad on something that simple.
And just to explicitly state it, there should be a washer and two nuts on the adjuster as well, just in case those are missing. It looks like the cap is in line with the nuts/studs that bolt the sprocket on. If that's what messed up the cap, you should check those for damage too. Better to find it now than way down the road when you go to change the sprocket...
Technically, once the wheel is adjusted to the right distance and the axle is tightened down, you don't actually need the adjusters.
Old September 9th, 2014, 04:57 AM   #4
Ninja Bob
Certified Slacker
Ninja Bob's Avatar
Thank you.
Ninja Bob
what are these called? Finesse 1986 - 2007 Ninja 250R Tech Talk 11 July 21st, 2014 08:55 PM
First Post! - What is this called? Where can I get it? Brian 2008 - 2012 Ninja 250R Tech Talk 12 November 28th, 2013 09:13 AM
What is this called? mariorivera830 2008 - 2012 Ninja 250R Tech Talk 8 June 3rd, 2013 08:45 AM
What is this called? zCasanova 2008 - 2012 Ninja 250R Farkles 5 April 4th, 2012 03:20 AM
what's that part called? mz_twee General Motorcycling Discussion 2 April 2nd, 2012 11:40 PM
