Old December 17th, 2014, 12:03 AM   #41
cjhickey12
cjhickey12's Avatar
Motorcycle(s): 2002 Ninja 250R
Originally Posted by MrAtom View Post
I don't think you're supposed to cover the rear brake.
I like to have my foot in position incase i need to hit it
cjhickey12 is offline   Reply With Quote
Old December 17th, 2014, 01:35 AM   #42
BoBO
BoBO's Avatar
Motorcycle(s): SC28 Fireblade
Originally Posted by cjhickey12 View Post
Hello guys,
Anyway bottom line, I am comfortable on this bike, I respect it, and I'm not a reckless person. I am also a relatively big guy 6 foot 240 pounds. Would you recommend a liter bike in the spring? or should i stick to a 600?
Anyways hope everyone is riding safe and enjoying themselves
A liter bike will be too much bike for you. And if you weight 240lbs, the 250 is surely too small for you. I'm pretty sure if you behave & get more experience, the 600 would be perfect for you. You could even get away with a CBR500R, CBR 650, and many more sport touring bikes. The 250 is a great starter bike, and will help build your skills for faster bikes. You gotta ask yourself what you want out of a motorcycle and how much you are willing to pay for that certain make & model. That will ultimately determine your future bike.
94 900RR
04 BMW Z4 2.5 M Package
01 R170 AMG Sport Package
BoBO is offline   Reply With Quote
Old December 17th, 2014, 01:35 AM   #43
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Originally Posted by cbinker View Post
height only matters when you are looking to stand on podiums in the elite classes.
Old December 17th, 2014, 11:45 AM   #44
adouglas
adouglas's Avatar
"Hitting" the rear brake might not produce the result you're looking for. Do some homework on highside crashes.
Think about it... when you're under heavy braking, what's happening to the rear tire? It's unweighting, which means it's easy to lock. Locking the rear can be dangerous and lead to a highside as the rear locks, then regains traction.
Look at your front brake. Now look at your rear brake. Why is the front so much bigger? Why do supersports have two HUGE front brakes but one tiny rear brake? Which end of the bike do you think does most of the work? In short, where is the vast majority of your braking power concentrated?
Next time you ride, try stopping using only the rear brake. What happens? (Hint: Leave LOTS of room.)
Now try doing a similar stop using only the front brake. What happens?
Do you think you can stop safely using only the front brake?
Are you aware that many track riders and racers use the rear brake seldom, if at all? Watch some racing footage... the rear tire is often OFF THE GROUND under heavy braking.
Bottom line: The rear brake is indeed there for a reason -- it settles the chassis and can shorten stopping distances somewhat -- but it should not be "HIT" as a rule.
Old December 17th, 2014, 11:52 AM   #45
cjhickey12
cjhickey12's Avatar
Interesting points man, so for slowing down into turns and slowing down softly when I have plenty of room(the only 2 times I'm using just the back brake), is it best to just use the front lightly? Or engine brake?
Old December 17th, 2014, 12:19 PM   #46
adouglas
adouglas's Avatar
Front brake is where it's at.
Your brakes can do WAAAY more than you think they can.
You should be in gear for the drive out of the corner before you roll on, so there will be some engine braking too.
Old December 17th, 2014, 12:49 PM   #47
Worldtraveller
Motorcycle(s): Ninja 250 (trackbike), CBR600RR, GS500F
Welcome, I would suggest a track day or two before you try to move on.
You might discover how much more there is to your bike than you think.
Worldtraveller is offline   Reply With Quote
Old December 17th, 2014, 01:33 PM   #48
Panda
not an actual panda
You're almost ready for the interstate. Def get a liter bike.
Old December 17th, 2014, 01:42 PM   #49
adouglas
adouglas's Avatar
H2.
It's the new 'busa.
People ask "Why would you need 300 horspower?"
Why wouldn't you need 300 horsepower?
Old December 17th, 2014, 03:07 PM   #50
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
brake pads are cheap, engines are expensive
if you mess up your downshifts to use the engine to slow the bike down you can blow the engine.
therefore the front brake is where it's at, downshift as you're slowing down. Many times you don't need to brake before a corner but just roll off the gas a bit because you aren't going that fast. Just remember not to turn in and add throttle at the exact same time, that's begging for a lowside.
Head to the track sometime to really practice your skills with people who know how to teach you based off of what they see you doing (mid-ohio is the best for this that is remotely near you)
also sidenote: don't cover your rear brake, if you accidentally press it at the wrong time you're screwed and it also doesn't let you weight the peg properly. Cover the front instead with 2 fingers. I ride like that 75% of the time on the streets because it cuts down your reaction time significantly.
Old December 17th, 2014, 05:13 PM   #51
cjhickey12
cjhickey12's Avatar
Thanks guys, will change up how I ride as it sounds to be much safer. Cheers for not sticking with bad habits
Old December 17th, 2014, 07:27 PM   #52
eddiekay
eddiekay's Avatar
Motorcycle(s): 300, WeeStrom
Read all the reviews of all the bikes you can find and read the V Strom 650 reviews.
Old December 17th, 2014, 07:49 PM   #53
greenaero
Motorcycle Hypermiler
greenaero's Avatar
Motorcycle(s): 1999 & 2005 Kawasaki Ninja 250R's
Welcome Chris, Lots of great advice hear for you.
235 MPG Hypermotorcycling to a better tomorrow
greenaero is offline   Reply With Quote
Old December 17th, 2014, 09:10 PM   #54
Snake
Snake's Avatar
Hello and welcome.
Old December 18th, 2014, 08:54 AM   #55
Panda
not an actual panda
H2.
QFT.
Wiser words...
Old December 18th, 2014, 09:56 AM   #56
Ghostt
Ghostt's Avatar
I would park my H2 right next to my Bugatti Veyron, and Challenger Hellcat
violente et ignorantia
ZX-2R BLOG
Wanting to accessorize! shelei09 General Motorcycling Discussion 15 January 24th, 2013 06:17 PM
Wanting iPhone 4 YMCMB Items Wanted 3 October 6th, 2012 10:37 AM
Am i strange for wanting this as my next car. rusninja Off-Topic 46 October 29th, 2011 12:10 PM
New rider, wanting to get 250... price ok? Vip3rV333 General Motorcycling Discussion 18 November 15th, 2010 09:22 PM
Wanting to Tackle Canyons! ARc Riding Skills 56 March 11th, 2009 07:21 PM
