Old May 13th, 2013, 11:15 PM   #1
anacron
anacron's Avatar
Motorcycle(s): Triumph Street Triple R
How not to noob out...
I've had my 300 for almost a month now, only been riding a few miles here and there (grad student, school, blah blah blah). So, I went out for my first hour long ride this evening and for some reason the bike felt a lot more lethargic and sluggish off the line. I live in Berkeley so I figured it was just me being in too high a gear at too low RPMs for the hills and, in general, me being sloppy with shifting.
Well... imagine my surprise when the issue turns out to be me being a complete f'in noob - I was riding the rear brake!
So I shifted my foot back a bit and on came a delightful surge of power
The rear caliper was nice and toasty after I was done. Oh well at least I didn't go down because of it and lesson learned. Maybe moving the brake pedal forward some would alleviate the issue.
anacron is offline   Reply With Quote
Old May 13th, 2013, 11:51 PM   #2
Aurodox
Motorcycle(s): -
Put the balls of your feet on the peg. Problem solved
Aurodox is offline   Reply With Quote
Old May 14th, 2013, 01:04 AM   #3
SteveL
old git
SteveL's Avatar
Motorcycle(s): BMW K1300S
Not just a noob problem a friend of mine was doing this on his new Yamaha been riding for years but a combination of big feet and not the best peg/ brake position for him easy done. He had more than sufficient power not to notice.
Steve
Some mistakes are too much fun to make only once.
SteveL is offline   Reply With Quote
Old May 14th, 2013, 02:28 AM   #4
Bentley813
Bentley813's Avatar
Motorcycle(s): 2013 White 300
I wear size 12 US riding shoes and have never accidentally hit the rear brake. That's strange. Once you get used to using the balls of your feet your ride will get better also. Between that and hugging the tank with your legs you will gain a lot more control of the bike.
Bentley813 is offline   Reply With Quote
Old May 14th, 2013, 09:44 AM   #5
anacron
anacron's Avatar
Yup, basically this was the issue. I was flat footing the peg and given the peg location on the 300 (45 degree angle at the knee) I kept resting the balls of feet on brake pedal.
Adjusted my position this morning and everything felt great, a little weird initially but much more comfortable (I found it easier to grip the tank this way). Just for fun, here's a picture!
Old May 14th, 2013, 11:20 AM   #6
Good safety tip.
How does the rear pad look, everything still a-ok?
Old May 14th, 2013, 11:29 AM   #7
inkyben
Motorcycle(s): 2005 ninja 250, 2008 zx10, 2003 r6, 2008 187cc drag bike.
Don't feel bad, I ran out of gas one day and didn't even check the tank until a coworker told me. I pushed my bike right by a gas station too lol.
inkyben is offline   Reply With Quote
Old May 14th, 2013, 12:05 PM   #8
iceknyght
Recalculating. . .
iceknyght's Avatar
Motorcycle(s): '09 250 (sold) '12 Ninja 650
^^ This.
jasontracewell.com
iceknyght is offline   Reply With Quote
Old May 14th, 2013, 12:14 PM   #9
anacron
anacron's Avatar
Originally Posted by Alex View Post
Good safety tip.
Yup, everything is still fine. I did a few emergency stops just to make sure and I didn't feel any slippage or loss of braking power.
Old May 14th, 2013, 12:18 PM   #10
OK - that's a good sign, but it still might be a good idea to get back there and take a peek at the pads themselves, that there is still plenty of meat left. Odds are they are fine, but it only takes a few moments to confirm.
Old May 14th, 2013, 12:35 PM   #11
............and check the brake fluid level as well.
It can boil when too much heat is generated by long time.
You should adjust the height of your rear brake pedal so it is comfortable to your ergo and kind of out of the way at the same time.
Old May 14th, 2013, 01:11 PM   #12
anacron
anacron's Avatar
Yup, all's well with the front and rear pads.
Fluid levels are fine. It was probably a good thing it was a short ride so other than the disc being a little hot there were no adverse effects.
I'll give the current setup a few more rides and if it still feels uncomfortable I'll go ahead and drop the pedal a little bit.
Old May 17th, 2013, 04:03 PM   #13
cookiebug79
n00b with the b00bs
cookiebug79's Avatar
Motorcycle(s): 2007 EX250, 2008 EX250, 2001 ZR-7S, 2010 ZX-6R
I would still bleed the rear brake. Even if the fluid level is ok, the fluid at the caliper end is likely degraded and brown. Your braking ability is reduced. But I'm overly anal about my brakes and use the super-expensive $20/bottle race fluid because it's waaaaaay better than the stock stuff.
cookiebug79 is offline   Reply With Quote
Old May 17th, 2013, 04:16 PM   #14
anacron
anacron's Avatar
haha! way ahead of you, I was going to make some time this weekend to do exactly that. Especially since it is the rear and much more maneuverable. Any recommendations on brand? I don't mind spending $20 for the fluid.
Old May 17th, 2013, 04:29 PM   #15
and when it boils, it creates a chain reaction of expansion pushing the pad harder causing more heat causing more boiling... eventually the caliper melts. dean had it happen at the track. theres photos floating around somewhere.
Old May 17th, 2013, 04:38 PM   #16
cookiebug79
n00b with the b00bs
Motul 600 is the good stuff!
http://www.topbrakes.com/itemDetails...Fcc-MgodcikALA
Old May 17th, 2013, 08:07 PM   #17
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
Love the pic. Congrats on the 300, great bike for sure!
Old May 17th, 2013, 08:11 PM   #18
koma22
koma22's Avatar
Motorcycle(s): Ninja 250R
Funny story. Bet you won't do that again.
BTW, what do you study?
koma22 is offline   Reply With Quote
Old May 17th, 2013, 08:52 PM   #19
anacron
anacron's Avatar
For sure, I'm being extra attentive of my foot positioning. I'm doing a PhD in computer science at - as you might have guessed - UC Berkeley.
Old May 17th, 2013, 09:24 PM   #20
koma22
koma22's Avatar
Cool beans, I am doing mine in astronomy up in Canada.
Old May 18th, 2013, 11:18 AM   #21
anacron
anacron's Avatar
Fun stuff!!
Stupid noob question from a non-noob LNasty 2008 - 2012 Ninja 250R Tech Talk 13 March 21st, 2015 10:47 PM
Noob here... TES77 New Members 21 April 28th, 2014 06:15 AM
NY Noob Ale Golem New Members 19 August 25th, 2013 05:51 AM
noob here, need some help marines2060 1986 - 2007 Ninja 250R Tech Talk 1 August 22nd, 2011 07:38 PM
Noob grandmaster New Members 5 December 12th, 2008 10:42 AM
