Old September 10th, 2013, 09:22 AM   #1
areifel
areifel's Avatar
Changed oil filter & missing washer
Yesterday i decided to change the oil myself since i had the free time. My last oil changed was done at the local yamaha-kawi dealer that i purchased my bike from.
Upon removing the oil filter i noticed that there was no washer between the spring and the oil filter. Should i be worried about this? I have a lot of miles under my belt without that washer and i wonder if it cause any sort of negative wear. Unfortunately, since i had to have the bike back up and running by days end to go somewhere i reinstalled the filter and continued without the washer.
I even managed to strip the main oil filter bolt (it was a long/bad day) trying to untighten it. (I used 17mm but didn't remove fairing). Everything is back on and there are no leaks as of yet. I was just curious if i should be worried and just reorder the bolt and the washer and just change the oil again?
areifel is offline   Reply With Quote
Old September 10th, 2013, 09:47 AM   #2
Originally Posted by areifel View Post
......I was just curious if i should be worried and just reorder the bolt and the washer and just change the oil again?
The washer protects the bottom of the filter from the direct contact of the spring, but most filters are strong enough at that point and suffer no damage.
You could file the head down to 16 mm, but only if you did not use a six-point socket for loosen the bolt as you should.
missing the washer between my oil filter and the spring corralhollowkid 1986 - 2007 Ninja 250R Tech Talk 14 July 22nd, 2017 02:36 PM
WTS: 250R OEM oil change items (filter, orings, washer) Teh_K Motorcycle-related 4 March 24th, 2014 05:14 PM
Oil filter washer replacement? cuong-nutz 2008 - 2012 Ninja 250R Tech Talk 18 June 19th, 2013 10:53 AM
Oil Filter Crush Washer Slono 2008 - 2012 Ninja 250R Tech Talk 4 January 24th, 2012 07:14 AM
Missing oil filter washer JokerSeven 2008 - 2012 Ninja 250R Tech Talk 2 February 21st, 2010 07:23 PM
