March 26th, 2021, 10:37 AM | #1 |
Join Date: Mar 2021 Motorcycle(s): 2010 Kawasaki Ninja 250R, Posts: 12
Speed sensor?
Hi! My recently purchased 2010 fuel injected 250R shoots an FI light sometimes past 8500 RPM.
I used the code reader (yellow cable thingy) and it drops 24 and 25, which seems to be the speed sensor, open or shorted cables. I detached it from the bike, thoroughly cleaned it, used contact cleaner on all contacts, and the light still shows most times the engine goes past 8500 RPM. Any idea about diagnosing it? Checked my service manual and it doesn't specify any procedure or check, it only says to buy a new speed sensor. Thanks! |
March 28th, 2021, 09:37 AM | #2 |
Could a loose chain cause it? I'm still waiting on a rear lift so I haven't put it to spec still, and the upper part of it touches the swingarm when stationary
April 7th, 2021, 03:40 AM | #3 |
Also, the light only shoots when going past those rpms while in motion. Does anyone at least know what does said speed sensor do? I can't find any info on the Internet, and I'm not keen on rolling around with a FI light on
May 1st, 2021, 11:25 AM | #4 |
Update: I finally got my license, longest 6 months ever!
Upon finally being able to extensively driving it, I've found the clutch to slip on 3rd to 4th gear upon full throttle after shifting, and it also being extremely noticeable if I let off the gas, give it gas, let of again and roll it up again.. Is there any way clutch slipping could throw said error? |
May 4th, 2021, 06:19 AM | #5 |
So, I´ve read about the speed sensor, seems like it sends 4 pulses for each sprocket rotations and when pulses aren´t equal to the actual speed of the bike it throws an error.
Could it have something to do? I've preloaded the springs with 4 spark plug washers and it slips way less now but it's still somewhat noticeable, and the FI light still turns on sometimes, it's less frequent now but still lights up sometimes on the high revs, especially if I shift going hard and give it WOT right ater shifting. Also, friction plates and springs are still in spec (springs are kinda close to service limit but they'll have to hold up until new springs and plates arrive) |
[motorcycle.com] - 2015 Yamaha SMax Recalled for Speed Sensor Issue | Ninjette Newsbot | Motorcycling News | 0 | December 30th, 2016 12:30 PM |
Speed sensor for trailtech vapor | Singh2jz | Items Wanted | 0 | May 20th, 2014 03:47 PM |
[motorcyclenews.com - sport] - HRC introduces rear wheel speed sensor protector in Se | Ninjette Newsbot | Motorcycling News | 0 | October 10th, 2013 01:40 AM |
