Old June 30th, 2021, 11:03 PM   #1
NinjaWI
Compression tested adapter?
I'm experiencing an odd problem with a compression tester I bought from Harbor Freight. The base of the 10mm adapter is larger than the sparkplug base and won't go into the recess for the plug at the bottom of the well. I have bought another one from the same place and still only get about 3 turns in on the thread before the adapter base stops it from going further. Anyone else ran into this issue? Is there a specific set of adapters people are using?
So far I've tried:
https://www.harborfreight.com/deluxe...-pc-64917.html
https://www.harborfreight.com/quick-...ression+tester
NinjaWI is offline   Reply With Quote
Old July 3rd, 2021, 11:52 AM   #2
crimsondragon
Motorcycle(s): 2006 Ninja 250
https://www.amazon.com/Performance-T.../dp/B00SDGVWQO
This is the set that I use. I haven't tried harbor freight compression testers but they should still be able to thread on. You might have some dirt or carbon on the spark plug threads. I recommend you chase them with a thread chaser prior to buying anything else.
crimsondragon is offline   Reply With Quote
[motorcyclistonline] - MC Tested: Shoei X-Fourteen Full-Face Helmet – Crash-Tested Wi Ninjette Newsbot Motorcycling News 0 March 1st, 2016 01:10 PM
JE High Compression Piston Kit (13.5:1 compression, 356cc displacement) Timpo 2013 - 2017 Ninja 300 Tech Talk 8 October 12th, 2015 07:21 PM
Koso Oil Temp Sensor Adapter & Water Temp Sensor Adapter StaylorT 2008 - 2012 Ninja 250R Tech Talk 10 January 24th, 2014 12:38 AM
What is compression Racer x 2008 - 2012 Ninja 250R Tech Talk 22 March 15th, 2013 02:44 AM
Compression tester headshrink 2008 - 2012 Ninja 250R Tech Talk 9 June 17th, 2011 08:10 PM
