Old July 12th, 2021, 04:02 PM   #1
Idealhobbies
Motorcycle(s): 2007 Ninja 250, 2003 Yamaha Vstar 650
Carb issue?
I just had the carbs redone and valves checked. I also changed the Air and Fuel filters.
Ok... the issue...upon receiving, it was idling at about 1K rpm. I adjusted the idle ever so slightly to get it to 1500 rpm. When riding it, in 6th gear at 50-60 mph when I approached a curve, I let off the throttle and it acted like it was running out of gas...hick-up. I gave it gas and it hesitated and picked back up. It did it several times. Also, it seems like it does not have the power it should in 6th gear. up to about 5000 rpm she pulls....but after that, she creeps up. Now I admit to being 220lbs so I'm not sure if it's me.
Idealhobbies is offline   Reply With Quote
Old July 13th, 2021, 02:26 AM   #2
Jim Moore
Jim Moore's Avatar
Motorcycle(s): 2000 Ninjette, 98 CBR600, 98 VFR800, 2000 BMW R1100RS, Kymco Movie 150
You may have a carb issue, but you gotta keep that thing higher in the rpm range. No way it's gonna pull from 5000 rpm, especially with a heavy guy on it. There's nothing wrong with being up near the redline, all the time.
Jim Moore
Jax, FL
Jim Moore is offline   Reply With Quote
Carb issue Detrailers 1986 - 2007 Ninja 250R Tech Talk 11 December 3rd, 2019 12:39 PM
Another carb issue malignity 2008 - 2012 Ninja 250R Tech Talk 5 April 1st, 2017 06:03 PM
Yet another Carb issue Foxrider64 2008 - 2012 Ninja 250R Tech Talk 7 October 2nd, 2013 09:38 AM
Carb issue zach 2008 - 2012 Ninja 250R Tech Talk 4 May 24th, 2013 10:54 AM
carb issue. justin_ninja 1986 - 2007 Ninja 250R Tech Talk 8 January 19th, 2013 07:16 PM
