Old July 12th, 2021, 09:34 PM   #1
bigBug
bogs at 6.5k rpm
I have been chasing this problem for a while now and so far I was able to go off of previous posts, but couldn't find a post that discusses this issue.
I have two things that created issues for me. Background:
  1. I fixed a little rust in the tank with por 15. The rust spot kept clogging my carburetor so it had to be done, but I didn't block any tubes and I think I may have blocked something inside the tank. After cleaning the tank it ran fine a month. After that started to have problems. At first it was water in the tank. I emptied the tank and dried it. Refilled with gas and it was fine. Then the battery had loose terminal. Replaced the battery. Then I started having bogging. issues.
  2. I had a loose battery terminal that may have cause electrical issues. Probably not.
Current problem:
My bike is I think starving fuel around 6.5k rpm, it stutters and seems like it will die. But when I throttle more or roll off the throttle it comes back.
Things I have tried:
I was reading a thread in the morning about ventilation in the tank and got to test the bike with the fuel cap open and it made no difference. Does that mean I have ruled out my gas tank problem?
Tested the charging system and voltage stay around 13.5-14.7v from 1k rpm to 8k rpm.
What has made a difference in the past is replacing the fuel filter. I replaced
the fuel filter and ran without bogging for two days then the bog came back.
Now I don't know what is causing the problem. It runs perfectly, idles good. Just dead around 6.5k rpm.
bigBug is offline   Reply With Quote
Engine Bogs at High RPM notunderweight 1986 - 2007 Ninja 250R Tech Talk 47 December 30th, 2020 07:25 PM
Bogs from 2000 to 2500 rpm higear223 2008 - 2012 Ninja 250R Tech Talk 40 August 5th, 2015 05:57 PM
2009 Bogs Between 3500-4000 RPM Hatter 2008 - 2012 Ninja 250R Tech Talk 2 March 26th, 2015 09:39 AM
Just cleaned carbs - now stuttering at low RPM, fine at high RPM Ohio 2008 - 2012 Ninja 250R Tech Talk 20 August 5th, 2014 10:30 PM
Bogs down when accelerating, max 5-7k RPM Jeffro2749 1986 - 2007 Ninja 250R Tech Talk 17 August 25th, 2013 09:03 AM
