Old March 8th, 2012, 01:55 PM   #1
rph12
Motorcycle(s): 2005 Ninja 250
Turn signal mounting plate replacing...HELP
So, long story short...someone hit my bike with a basketball the other day, cracking the front right turn signal mounting plate and leaving the turn signal hanging. I already got the replacement part, but I can't figure out how to take the old plate off to put the new one on. It seems like you have to pull the whole wire out and string it through the new one then run it back. Can anyone confirm this? And if so, I can't seem to find a DIY guide for this type of project.
Thanks all
rph12 is offline   Reply With Quote
Old March 8th, 2012, 02:37 PM   #2
/moved to pre-gen tech
Old March 8th, 2012, 02:55 PM   #3
Jono
Jono's Avatar
Sounds about right. Just unplug the old wires and put on the new signal and plug it in. Simple as that.
By the sounds of it, I bet your 'damaged turn signal' was fine. They are made to pop out of the mount on impacts. You can just pop it back in there. Mine has come out of the mounting bracket twice and both times I could just pop it back in.
Old March 8th, 2012, 06:24 PM   #4
rph12
It would not pop back it. My main question is "how do I get the wire out/back in?". That's the part I don't understand.
Old March 8th, 2012, 06:34 PM   #5
EsrTek
EsrTek's Avatar
Motorcycle(s): '13 300
When I replaced mine, I took the fairing off, removed old broken one
ran wire through hole and routed new one in place on inside of fairing
remounted fairing and connected signal quick connect
Old March 8th, 2012, 09:48 PM   #6
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
The signal consists of a plastic mounting plate, a rubber inner stalk, then the bulb housing itself. The rubber inner stalk is clamped to the opening in the mounting plate with a metal plate held in place with a screw. Removing that screw and clamping plate reveals another metal plate that the screw inserts into. The wiring harness threads through that inner plate. Down inside the rubber stalk is another small metal plate that holds the plastic bulb housing onto the other end of the rubber stalk.
Contrary to popular belief, the turn signal is *not* designed to come off in a crash. It's designed to be flexible so that minor bumps against walls, etc, won't break the signal housing. It's not uncommon for the rubber inner stalk to actually tear in a crash. If it comes out without tearing then the reassembly process is to remove the metal plates in the fairing-end of the rubber stalk, insert the rubber stalk back into the mounting plate, then insert the metal plate and clamping plate, followed by the retaining screw. Then the assembled turn signal is reinstalled on the fairing.
Looking for pregen left front turn signal and mounting parts tanghonglai Items Wanted 3 August 4th, 2013 04:44 PM
Opinions on turn signal mounting offrdjeep87 2008 - 2012 Ninja 250R Tech Talk 2 July 27th, 2012 12:58 PM
WTB: Turn Signal/License Plate Bracket for 09 Ninja 250 + More UjaasG35 Items Wanted 3 May 16th, 2012 05:03 PM
Replacing Turn Signal Bulbs zCasanova 2008 - 2012 Ninja 250R Tech Talk 4 January 1st, 2012 01:06 PM
I need help replacing my turn signal on my ninjette! venmichaels 2008 - 2012 Ninja 250R Tech Talk 8 August 12th, 2011 10:46 PM
