Old June 23rd, 2014, 07:08 PM   #1
melfice
yes, I'm famous.
melfice's Avatar
Motorcycle(s): 2009 Ninjette 250R
broken fairing nut
20140525_091559-1.jpg those two fairing screws closest to the turn signal have seem to have made their way to a broken status. The actual broken part is the rubber nut on the inside that the screw screws into. At the moment instead of the nut being attached to the fairing like it should be, I have to wiggle my hand under the dash and attempt to hold the piece in place to screw the fairings together. It's a pain. Btw it's happened on both sides, so 4 nuts total are like this.
Does anyone know of a way to repair or fix these, or is this how the bike was designed?
I cant wheelie and that makes me sad.
melfice is offline   Reply With Quote
Old June 23rd, 2014, 07:08 PM   #2
melfice
yes, I'm famous.
melfice's Avatar
TIA
Old June 23rd, 2014, 08:21 PM   #3
Order a bunch of M5 rubber wellnuts or a windscreen kit from eBay. You are going to find them rotted everywhere on the bike except the two exposed on the windscreen. Those two had a different part number, so this was very deliberate by Kawasaki. The crappy ones were used everywhere you couldn't see ("out of sight; out of mind") and rot regardless of temperature, environment, etc. Kawasaki later changed the part number later on to match those, so they were aware of the problem. Are your clutch cable boot and trip meter reset button rubber bits rotting too?
There are two under the rear seat, two in the undertail, four holding the lowers on, two holding the headlight in, and four holding the windscreen. Because two of the windscreen wellnuts should be fine, you need at least 12. No need to dig in to replace them all though. Just have them on hand so that you can replace them as you encounter them.
Old June 23rd, 2014, 09:28 PM   #4
Olie
New Old Guy
Olie's Avatar
Motorcycle(s): 2011 250R SE
http://www.partzilla.com/parts/searc...ING/parts.html
$3.11 a piece
Olie is offline   Reply With Quote
Old June 23rd, 2014, 09:37 PM   #5
Originally Posted by Olie View Post
Way too expensive. You don't need factory wellnuts, especially when they have already proven to be a problem. I got 8 of them with blue windscreen bolts for about $5 at Cycle Gear when they were on clearance for no other reason than they were switching the name from Motech to SpeedMetal.
Old June 23rd, 2014, 09:44 PM   #6
Here's 10 for $6:
http://pages.ebay.com/motors/link/?n...126892&alt=web
Old June 23rd, 2014, 09:52 PM   #7
Olie
New Old Guy
Olie's Avatar
My post was so he could see the parts break down. Where he buys them from is up to him.
Old June 24th, 2014, 02:48 AM   #8
melfice
yes, I'm famous.
melfice's Avatar
Awesome! Way easier than expected. You guys rock.
Old June 24th, 2014, 06:13 AM   #9
10 wellnuts with blue bolts and nylon washers for $3.48:
http://www.ebay.com/itm/1Set-Blue-M5...c7dffd&vxp=mtr
That's probably exactly what I got from Motech/Speedmetal.
Old June 24th, 2014, 08:33 AM   #10
melfice
yes, I'm famous.
melfice's Avatar
yeah i was glancing at some deals before i came to work today, i was thing i'd get a set of black bolts to offset the blue. and it wont hurt having extra bolts for my new set of wellnuts. thanks for all the help fellas
cracked fairing? broken tabs? plastic fix paint prep how-to as requested breebles 1986 - 2007 Ninja 250R Farkles 26 October 9th, 2013 02:55 AM
Removing cross-threaded and broken fairing bolt rmorse 2008 - 2012 Ninja 250R Farkles 9 May 24th, 2012 03:54 PM
Wanted! Broken fairing Kevin2109 Items Wanted 2 July 17th, 2011 08:36 PM
WTB Broken 88-07 Fairing geoff2k Items Wanted 5 June 19th, 2011 01:13 PM
fixing broken fairing??? Greg_E 2008 - 2012 Ninja 250R Tech Talk 8 August 23rd, 2009 07:47 AM
