July 23rd, 2009, 11:47 PM | #1 |
Join Date: Dec 2008 Motorcycle(s): 09 ninja 250 Posts: 42
keihin cr carb group buy
Im looking for a couple (4 to be exact) people to go in on a group buy with me. the HARD RACING site sponsor from another 250 site said he would hook us up if we did a group buy. what im trying to buy is:
im just trying to get a little extra UMPH from my ninjette. yes yes "maybe you should just buy a bigger bike" but why would i want to sell this awesome bike which i bought for fairly cheap , and turn around and spend $9000-11000 on a new bike? for 400 big ones or less you can get that extra little something some of you are craving for without moving up in cc's. so there it is , anyone up for a group buy?????? |
July 24th, 2009, 01:03 AM | #2 |
Über n00b
Join Date: Dec 2008 Motorcycle(s): Triumph TT600, Honda NS50F, Kawasaki ZZR-250 (sold) Posts: 225
If I still had my 250 I'd probably be in for this, but alas I don't.
Didn't know there was a carb alternative for the bike, awesome. I miss mah 250. |
July 24th, 2009, 01:16 AM | #3 |
Join Date: Feb 2009 Motorcycle(s): 2009 250r SE, 2015 FJ-09 Posts: 171
gonna need some dyno charts for me to consider this
July 24th, 2009, 03:22 AM | #4 |
MOTM - Sep '18, Feb '16
Do the CR carbs have a choke or cold start device ? Some racing carbs don't . I want to use them for the street.
July 24th, 2009, 04:17 AM | #5 |
Join Date: Nov 2008 Motorcycle(s): Ninja 250R 2009 Posts: A lot.
July 24th, 2009, 06:34 AM | #6 |
Join Date: Jun 2009 Motorcycle(s): 08 Candy Plasma Blue Posts: 125
id just be interested in seeing how much of a gain these give. i wanna keep the 250 for as long as possible
Real HIP HOP is not on the radio | SHIFT the MC | 3,100 Channel Views & Rising | Updated April 18,2010 |
July 25th, 2009, 02:03 AM | #7 |
I might be interested depending on the price. Looks like I might have to get new carbs anyway...
July 25th, 2009, 04:05 AM | #8 |
the orignal price is 425-435 i forget , BUT with the group buy well get a discount. As for the dyno chart the site sponsor said their locating a dyno , so the chart will be up as soon as they find one i guess.
July 25th, 2009, 09:11 AM | #9 |
MOTM - Mar '13, Jun '14
If they don't double the horsepower I'm not interested.
July 25th, 2009, 10:47 AM | #10 |
July 25th, 2009, 10:50 AM | #11 |
I'm out.
Getting married next weekend, can't afford to spend that much extra right now |
July 25th, 2009, 11:08 AM | #12 |
Join Date: Jul 2009 Motorcycle(s): 2008 Ninjette 250R, 2006 Ninja 650R, 2001 Aprilia SR50 Posts: 24
Well going to fuel injection on this bike actually makes a net LOSS in HP in Europe...so I would assume changing carbs won't see much of a increase...
where you will see increases if you REALLY want them would be in: porting and polishing the head balancing/blueprinting the motor racing camshafts shaved or thinner head gasget for increased compression but none of these are really worth doing on this bike... maybe the increased compression and maybe the camshafts... |
July 25th, 2009, 01:04 PM | #13 |
IC2(SW)
July 25th, 2009, 06:03 PM | #14 |
July 25th, 2009, 07:31 PM | #15 | |
Join Date: Mar 2009 Motorcycle(s): '09 Blue Kawasaki KLE650 Versys, '95 Ducati 900SS/CR (undergoing track conversion) Posts: 287
I have thought of spending the money for the CR carbs, but out of the box, the gain is going to be minimal. They will give you the best bang if you run a full exhaust, some good cylinder head work, and a way to adjust the timing to cope with the extra air and fuel. Until then, I will save my money up for all of that at once. |
July 25th, 2009, 07:44 PM | #16 |
Well Factory Pro sells a 5+ degree advance woodruff key which takes care of the timing advancement...and while I assumed the loss in horsepower in Europe was from the Euro 3 emissions stuff, what it shows is that even with that taken off, FI would show us how the best fuel mix would be...so even with a good carb setup, the power gains from fuel/air would hit a ceiling because of the small motor...
more power could only really come by moving the rev ceiling higher...I would guess... |
July 25th, 2009, 09:40 PM | #17 |
The Sportisi Master
Join Date: May 2009 Motorcycle(s): 2008 Ninja 250 Posts: A lot.
Well as I have posted on the other sites about this. Unless you are racing you SHOULD NOT BUY THIS! Bogs down in lower RPMS when you open the throttle it opens and you get way to much fuel. Your idle needs to be at about 3500 to not have any problems with them.
Sportisimoto USA is born. |
July 26th, 2009, 10:22 AM | #18 |
Join Date: Apr 2009 Motorcycle(s): 2009 Ninja 250r Posts: 379
yea no way fuel injection would provide less power, unless it was poorly made.
I dont see where the increase would come from? we already can provide a good ammount of fuel with stock carbs.. This sounds like something that should be paired with other mods (turbo?). Even on the mag where they bump the power up to 35hp, i dont think they replaced carbs (could be wrong) Posted via Mobile Device |
July 26th, 2009, 10:59 AM | #19 |
The Sportisi Master
No they didn't upgrade the carbs. I don't believe they were available when they made their maxton runs. Our carbs are sufficient but someone will always buy something like this even when it is not needed because they have money burning a hole in their pocket. This is great for on track usage but using it for a strictly street application does not make sense in anyway shape or form.
Sudco Keihin FCR31 Ninja 250R Carb Kit | fastbyjb | Motorcycle-related | 10 | October 15th, 2011 10:07 AM |
Sudco Keihin CR31 Carb Performance Kit | streetsquid | 2008 - 2012 Ninja 250R Tech Talk | 4 | September 13th, 2011 01:21 PM |
[motorcyclistonline] - Sudco Keihin FCR Performance Carb Kit for KTM 950 V-Twins | Ninjette Newsbot | Motorcycling News | 0 | April 4th, 2011 05:00 PM |
