Old August 27th, 2009, 11:48 AM   #1
Rafalski
Motorcycle(s): Ninja 250R 08
Idle weird
B4 i could start up my bike it would hit my idle pre-set of 1.3k and stay there the whole time.
I had a mishap on a hill where after these happened but went away.
rev up to 2.4k then when dropping it would slowly lag at 2.0 then go back down to idle.
It would go slow. aka 8k revs going 20 in first.
Those problems went away. But now when i start up itl go to idle. then drop down to 1k and go lower.
How did that happen?
Rafalski is offline   Reply With Quote
Old August 27th, 2009, 01:10 PM   #2
describe the mishap on the hill. did you drop the bike? if so, which side?
Old August 27th, 2009, 01:22 PM   #3
Rafalski
No drop just couldnt get it going off the hill. gears grinded a bit because of me trying to shift when i couldnt take off.
Old August 27th, 2009, 01:40 PM   #4
okay, first, set the idle to 1500 rpm after the bike is completely warmed up (10-15 minutes of riding)using the black knob on the left hand side of the bike, below the black side panel. have you ever done that?
Old August 27th, 2009, 01:45 PM   #5
Rafalski
I set the idle to 1.3k like it said in the owners manual.
Like its always been fine. It would be able to warm up withought the choke. But now i have to use the choke to warm it up. Which is odd.
b4 it would turn on. go to 1.3k stay there and not move.
now it goes to 1.3k then drops to 1k
Old August 27th, 2009, 01:57 PM   #6
the bike should not idle at 1300/1500 when cold w/o choke. if it did, you had the idle misadjusted.
like I said in my reply, set the idle speed AFTER the bike has been completely warmed up. Have you done that? If not, try that first. (pg 104 of your owner's manual)
the idle spec is 1300 +/- 50 rpm, but most here set it at 1500 so it's easier to read/set on the tach.
Old August 27th, 2009, 02:03 PM   #7
Rafalski
Ive done that. When I first got the bike.
But when just turned on it would idle at the proper setting. Now it drops so not cool.
Old August 27th, 2009, 02:07 PM   #8
do it again... things change. if you can reset it back to the desired idle rpm with the knob, you should be okay, but do so only after the bike is completely warmed up.
Old August 27th, 2009, 02:25 PM   #9
Rafalski
Iight ill give it a shot later tonight then repost findings. Ill put it up to 1500
Old August 27th, 2009, 03:22 PM   #10
Raf, the actual number (1300 vs 1500) is not important. Setting the idle speed, only after the bike is completely warmed up, is key.
Old August 27th, 2009, 03:32 PM   #11
Rafalski
Ive done that. When I first got it. When its warmed up it idles at the normal speed.
b4 when i started it, it would idle up to the set speed and stay there withought any choke.
after that hill mishap. where the revs acted weird like i described.
when turned on it will go to idle then drop to 1k. Then when i give choke. let it heat up turn choke off it goes back to the idle setting.
Old August 27th, 2009, 04:38 PM   #12
sofo
sofo's Avatar
How long ago was the hill mishap and was the weather warmer then compared to now where you live?
sofo is offline   Reply With Quote
Old August 27th, 2009, 05:06 PM   #13
that's pretty normal behaviour. You're supposed to use the choke to start the bike when the engine is cold. it will rev high.. about 3-4k, so you gradually turn down the choke as the bike warms. after a few minutes, you should be able to turn the choke completely off and it should idle at your preset idle speed.
ambient temps can make a diff in idle speed. have the weather temps changed recently?
Old August 27th, 2009, 10:45 PM   #14
Rafalski
Week ago.
btw heres another hting today i kept it in neutral idling for a while.. talking to some one..
as i stayed there and it ran.. the idle went up even thought it is set at a certain number. is that normal?
Old August 27th, 2009, 11:17 PM   #15
istreefitty
sir posts a lot
istreefitty's Avatar
Motorcycle(s): '09 Black 250R
sorry to jack your post but I noticed that today my bike was idleing at about 1k rpms and I know that when I bought it it was set for 1300. Absolutely no mishaps but it hadnt been ridden for over a week before today. Is that normal, to just drop the settings?? thanks in advance.
A girl walks into a bar and orders a "double entendre"
So the bartender gave it to her
"once you go black, you never go back."
istreefitty is offline   Reply With Quote
Old August 28th, 2009, 08:28 AM   #16
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
agree on the temp change. Mine is 1500 rpm when warm, but on a hot day after some "spirited" riding it idles around 1750 for a while.
Old August 28th, 2009, 09:51 AM   #17
sofo
sofo's Avatar
Same here.
Old August 28th, 2009, 09:56 AM   #18
Same here.
yeah first time i noticed it i cut it back to 1500 at a red light, then of course on a cool day it was idling around 1200. i figure anywhere from 1300 - 1500 on an average temp day of after running a few minutes should be good.
Idle issues - Idle is different every time I start up. 106 1986 - 2007 Ninja 250R Tech Talk 6 November 13th, 2014 04:57 PM
Here's a weird one... misfitsailor Help 4 August 17th, 2014 07:48 PM
Weird :/ reabo 2008 - 2012 Ninja 250R Tech Talk 16 April 12th, 2013 03:55 AM
Idle jumps to 9000 rpm on choke then wont stay idle after off Shawn250 2008 - 2012 Ninja 250R Tech Talk 1 June 19th, 2012 06:45 AM
Weird Cold Starting Idle ajcadoo 2008 - 2012 Ninja 250R Tech Talk 9 March 6th, 2012 08:54 AM
