August 31st, 2009, 07:28 AM | #1 |
Join Date: Jun 2009 Motorcycle(s): Black 2009 Kawasaki Ninja 250R Posts: 153
15T Front sprocket is greeaaatt!
finally got around to attempting the install of my 15T front sprocket yesterday for the 2nd time. first attempt i only had a ratcheting wrench = complete fail
i went out to buy a breaker bar, longest one i saw was i think 14in i put that 27mm sucker on there and went at it... fail... for over 30min... i put a metal bar above the swingarm to keep the wheel from moving and held down the front brake while i stood on it from the front i looked absolutely ridiculous, and i live in a condo with an underground garage.. imagine heading to your car and seeing a little asian dude jumping up and down on the front of his bike holding it tight... i bet theyre hiding their little girls from me now so yeah, i know i should have bought a 3ft pipe and got more leverage, but i was stubborn.. it FINALLY came off after jumping on it enough, though it fell off a few times and i was scared of stripping that guy. man was i sweating. im a pretty strong guy (i think) for my size and that sh*t was a PITA!!!! adjusted the chain and tightened it back on (first to get it to about 80ft/lb which is the max of my torque settings, then by standing on the breaker bar again lol but with much less force). just in case, i bent the washer back around the nut took a nice long 3 hour ride and MAN, what a nice difference. i actually was cruising in 5th several times and didn't know it!! VERY VERY happy with the mod. but word of advice, when the guys in teh DIY replies say use a pipe.. USE ONE!! it would have saved my leg and i probably wouldnt have lost 2lbs in water weight.
Black 09 Ninja 250R|Shogun Crash Kit|Woodcraft Full Rearsets|Proton Flush LEDs|De-Snorkeled|Shimmed|K&N|Red Rim Tape|ProGrips|Puig|10K HIDs|15T Front |
August 31st, 2009, 07:38 AM | #2 |
Join Date: Aug 2009 Motorcycle(s): 2008 Ninja 250R Posts: 98
Did it look the Factory had put red locktite on the shaft threads when you got it off or worse yet , the dreaded "gray" ?
August 31st, 2009, 07:41 AM | #3 | |
dirty old man
Join Date: Nov 2008 Motorcycle(s): Blue '08 Ninja 250 Posts: A lot.
now that would have been a sight. How did the sprocket change affect the acceleration, gas milage etc.? nb
Death tugs at my ear and says, "Live, I am coming." -Oliver Wendell Holmes, Sr., poet, novelist, essayist, and physician (1809-1894) www.friendsofsanonofre.org |
August 31st, 2009, 07:59 AM | #4 | ||
as for gas mileage, i did fill up right before and then calc it to be at 56.3mpg after the swap. my last fill, i had it at about 55.8mpg. but considering i did ride it differently after the swap, both to test accel and also comfort, i think its within a small enough margin of error that it did not hurt nor help mpgs. also read the comments made on the sprocket swap DIY, it gives a good insight as to why it really wont do much for gas mileage, but it can hurt accel if you go further with a rear swap like a 15/43 setup
August 31st, 2009, 08:10 AM | #5 |
Join Date: Aug 2009 Motorcycle(s): 90 Suzuki gsx600f Katana, 03 Buell XB9R Posts: 868
With a mechanical holder, you don't need loctite so there might not have been anything on it.
August 31st, 2009, 12:54 PM | #6 |
Join Date: Jul 2009 Motorcycle(s): F650GS Dakar, FJR1300, Ninja 250R Posts: 47
I really hope you didn't put much force on that breaker bar!!! 94 ft.lbs is 94 lbs of force at the end of a 1 foot long lever. Not that much more than the 80 ft.lbs of your torque wrench.
August 31st, 2009, 01:37 PM | #7 |
i dont believe i did, what i actually looked out for after tightening it to 80ft/lb, is for the nut to move a few more mm, that was it, then i bent the washer back around it just in case. with it tightening maybe 2-3mm more than 80ftlb, i was pretty sure i was just under 90, which i doubt will hurt
August 31st, 2009, 05:52 PM | #8 |
I would've sprayed that bolt down nice and good with WD-40, let it soak in that for a few minutes, repeat a couple times, and then try it again... and you can get an 18 in. breaker bar at Home Depot (Husky brand) or Sears (Craftsman). My stubborn axle bolt came right off after WD-40 treatment and breaker bar... and it's torqued at 110 Nm...
But anyways congrats on the upgrade, I'm really tempted to try it myself... do you notice significant loss of pull at the lower end of the RPM range (is there any to lose??? lol) |
August 31st, 2009, 06:04 PM | #9 |
my hubby was wondering why I was laughing so hard until I had him read your visualization... too funny!
August 31st, 2009, 06:17 PM | #10 |
Join Date: Apr 2009 Motorcycle(s): 2014 Z250 Posts: A lot.
why not change the back sprockets out if the front one is such a pita to get off?
August 31st, 2009, 09:58 PM | #11 |
self wrencher
Well when I swapped mine to 15 last year, I used an air gun and zapped it off in 1.0238 seconds so I didn't think much of it until I read your post. Now I'm scared of it
Posted via Mobile Device |
September 1st, 2009, 10:58 AM | #12 |
Join Date: Jun 2009 Motorcycle(s): 2008 Kawasaki Ninja 250R Posts: 29
Where did you buy you sprocket at? do you have to change out the rear's as well?? I can't find online. Please help with part number and resource. I want the 15/44.
Thanks alot. |
September 1st, 2009, 11:12 AM | #13 |
sprocketcenter.com, you dont need to do the rear, mine is just 15/45 right now, but i will be going to a 15/43 later. website just has it listed as "520 steel front sprocket - kawasaki ex250" $19.95
September 1st, 2009, 01:37 PM | #14 |
Thanks, I thought the rears have to be changed due to the new ratio in front...???
September 1st, 2009, 01:42 PM | #15 |
sorry, whats the benefits of just changeing the fronts with out the rears. It is supposed to make the gears taller rite?
September 1st, 2009, 01:48 PM | #16 |
if u lower rear along with 15t, it will lower rpms through the gears even more but also hurt acceleration more. take it in steps to see what u like. im gonna hang with 15t for now, but plan on getting a 43t for rear later. if i miss the 45t, ill switch back
September 1st, 2009, 03:47 PM | #17 |
I'll do the front first like you said. Ordered part just now.... Thanks for the info....
15t front sprocket loose | Lewis3845 | 1986 - 2007 Ninja 250R Tech Talk | 2 | March 10th, 2014 02:07 PM |
Suggestions for a 15T front sprocket? | tsdexter | 2008 - 2012 Ninja 250R Tech Talk | 7 | June 21st, 2013 03:31 PM |
15t Kawasaki OEM front sprocket | rainking | 2008 - 2012 Ninja 250R Tech Talk | 2 | April 25th, 2012 05:53 PM |
15t front sprocket swap! | play2pwn | 2008 - 2012 Ninja 250R Tech Talk | 3 | October 17th, 2011 09:17 AM |
15t jt front sprocket and now noise? | greatwhiteninja | 2008 - 2012 Ninja 250R Tech Talk | 25 | August 30th, 2011 08:34 PM |
