March 26th, 2011, 06:17 PM | #1 |
So, where's the reverse?
Lubing the throttle cables
So I'm starting to put together a "to do" list for maintenance items to complete to get my bike ready for the upcoming riding season. One of these items are lubing the clutch and throttle cables which the maintenance schedule says should be done every year. There's a DIY on here for lubing the clutch cable and it seems simple enough, however, there isn't one for the throttle cables (at least I haven't seen one). Has anyone lubed the throttle cables and have any tips on how to approach this? Is it as simple as opening up the control pod and lubing them from there?
March 26th, 2011, 06:30 PM | #2 |
lube the throttle cables the same way as you lube the clutch cable. you will need to disconnect them from the throttle tube to do a thorough job. while you have the cables off, lube the barrel ends with some grease when you reassemble.
Lubing Cables | FvnnyL3tt3r1ng | 1986 - 2007 Ninja 250R Tech Talk | 7 | October 11th, 2012 04:13 PM |
Technique for lubing cables | n4mwd | 1986 - 2007 Ninja 250R Tech Talk | 18 | December 17th, 2011 07:15 PM |
How do I adjust the throttle push-pull cables? | wtfh4xx | 2008 - 2012 Ninja 250R Tech Talk | 1 | August 10th, 2011 05:45 AM |
Need help with throttle cables. | ak_907_ak | 2008 - 2012 Ninja 250R Tech Talk | 4 | April 2nd, 2009 02:47 PM |
Throttle Cables... Do we really need 2? | kkim | 2008 - 2012 Ninja 250R Tech Talk | 23 | December 10th, 2008 08:47 AM |
