Old September 1st, 2011, 08:39 AM   #1
james250ninja
james250ninjette.newbie
james250ninja's Avatar
Motorcycle(s): 1986 ninja 250
Smile carburetor bolts
anyone know the size of the carburator bolts. they are the ones that bolt down the black covers that the needles are under
james250ninja is offline   Reply With Quote
Old September 1st, 2011, 09:59 AM   #2
LoD575
LoD575's Avatar
Motorcycle(s): 2012 Ninja 250, 2006 Ninja ZX6R-636
Run a search, that is where I found the specs for them. Can't recall the length and thread pitch but they are 4mm.
LoD575 is offline   Reply With Quote
Old September 1st, 2011, 12:20 PM   #3
Gorilla25
Dakine...
Gorilla25's Avatar
Motorcycle(s): 2009 Ninja 250R (Sold) | 636 (hopefully soon)
M4-.7 ....or 4mm ..pitch:.7t
Gorilla25 is offline   Reply With Quote
Old September 2nd, 2011, 01:53 PM   #4
Momaru
Momaru's Avatar
Originally Posted by Momaru View Post
I mangaged to find some at my local hardware store, under 'metric pan head screws.' You could order some online (below) but you'd be overpaying a bunch + waiting on them to arrive.
Size (obviously) depends on which screw it is you mangled. I'll assume it's on the top of the carbs holding the black cap that covers the needle/diaphragm since you're working on the needles, so those are 4mm x 18mm screw. I recommend getting a few of that size as well as a few 4x14 screws, which fit the float bowls for changing main jets if/when you plan to. We use a 0.7 thread pitch on both kinds of screws; the 0.7's I got fit just fine, but I've got an '08
If this isn't it, check the spec sheets @ http://www.kawasakipartsnation.com, Ronayers or the Kawasaki home site, 'under carburetor' or 'carburetor parts'
Thread
Search = your friend
Proud member of the Blue Army
Carburetor - what maintenance? LemonSlice! 1986 - 2007 Ninja 250R Tech Talk 4 July 17th, 2013 09:48 AM
7 fairing bolts and 3 windscreen bolts for pregen. Monkeytofu Free stuff! 5 November 29th, 2012 11:03 AM
Carburetor Diaphragm kingkang204 Motorcycle-related 4 September 21st, 2011 07:20 PM
WTB PreGen Fairing bolts and other misc bolts xlatinox Items Wanted 1 June 8th, 2011 05:32 AM
Carburetor Heads Up Jakester9500 1986 - 2007 Ninja 250R Tech Talk 14 March 31st, 2010 09:44 AM
