Old December 5th, 2012, 07:42 PM   #1
EMSRacer07
EMSRacer07's Avatar
weird squeal
Hey guys.
Cant seem to pinpoint this annoying noise. It sounds like a vacuum leak but when warmed up sounds like a squeal.
When I try to pin point it when it starts making the sound, it sounds like its coming from the oil filter :/. I thought it might be from the coolant lines but everything is fine. Vacuum lines are all fine. Battery isnt making the noise. Noise isnt coming from the crankcase breather either.
And the sound is more towards the back. Maybe around transmission or oil pan. But everytime i look i cant find anything that will be making that noise. This is with motor running and in neutral. Makes the sound in gear but I can hear it more when I am stopped in neutral.
Any ideas? Maybe the filter is moving? idk
Old December 5th, 2012, 07:47 PM   #2
Stick your ear as close to the TB's as you can. Those air screws make a little puffing noise when air gets sucked by. It's possible that one of them is squeaking a little.
Old December 5th, 2012, 07:53 PM   #3
EMSRacer07
EMSRacer07's Avatar
nope not even in that area, first place i looked. its literally under the bike. Sounds like the alternator or someplace in the oil pan. And only does it when the bike is warmed up
Old December 5th, 2012, 07:56 PM   #4
Weird. Well that's all I could think of off the top of my head. Sorry Byron.
Subscribed for reading material.
Old December 6th, 2012, 12:22 PM   #5
Lychee
sail away
Lychee's Avatar
A trick I have used when trying to locate odd noises back in my AE86 days is to poke a long screwdriver onto suspect areas and put your ear to the end of the handle. Locational noise would be amplified by contact with the screwdriver. You can also use a small hollow metal tube. They make car stethoscopes like this for this exact purpose.
Edit: It also helps to rev the engine and see if the pitch of the sound changes.
Old December 6th, 2012, 03:23 PM   #6
sounds like one of the trans bearings has a damaged ball maybe?
is there any play in the output shaft?
Old December 6th, 2012, 03:53 PM   #7
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
Could be something in the oil pressure relief spring assembly.
Old December 6th, 2012, 03:58 PM   #8
Joshorilla
Bass Master General
Joshorilla's Avatar
Does it sound like this? If so it's the noise of a resonance within the gauge cluster caused ultimately by the speedo cable, you will need it stripped, re-built and re-lubed.
You can diagnose the noise by tapping the speedo hard with your hand, if the noise changes in pitch when you hit it, like tapping someone on the back when they are saying aaaaaaaahhhhhhhhhhhhhhh then that's it.
Old December 6th, 2012, 04:01 PM   #9
i think he said it happens when he is holding still idling it on stands which means the speedo cable isn't moving right?
Old December 6th, 2012, 04:02 PM   #10
oh!!! did you recently adjust your valves? did you remember to reset the cct?
Old December 6th, 2012, 04:41 PM   #11
Joshorilla
Bass Master General
Joshorilla's Avatar
My bad, I have to admit I just read weird squeal, and thought "Aha! I had/have that!"
Old December 7th, 2012, 07:33 AM   #12
DaBlue1
DaBlue1's Avatar
Not sure how you EFI system is set up, but could your fuel pump or relief valve make noise if it were bad or subject to temp changes?
Old December 7th, 2012, 11:36 AM   #13
EMSRacer07
EMSRacer07's Avatar
maybe a bit. Possible where the sound is coming from. Its rather the transmission or lower end of the block. Its hard to pinpoint
Ill try the screw driver trick.
Old December 7th, 2012, 11:37 AM   #14
EMSRacer07
EMSRacer07's Avatar
yeah and plus I dont have a speedo . And yeah it happens and is louder more when bike is at a full complete stop.
Old December 7th, 2012, 11:38 AM   #15
EMSRacer07
EMSRacer07's Avatar
noise isnt coming from either of them though. Literally put my ear next to them while it was running. Def not them.
Here's a weird one... misfitsailor Help 4 August 17th, 2014 07:48 PM
Weird :/ reabo 2008 - 2012 Ninja 250R Tech Talk 16 April 12th, 2013 03:55 AM
Squeal sound EL_Morono 2008 - 2012 Ninja 250R Tech Talk 37 December 13th, 2012 03:30 AM
[topix.net] - Kunekune pig Jonah Hog is ready to hear the tyres squeal on his owner B Ninjette Newsbot Motorcycling News 0 January 26th, 2011 02:10 AM
The Ninjette Squeal smcbride11 General Motorcycling Discussion 1 May 20th, 2009 08:27 PM
