Old November 15th, 2014, 02:52 PM   #1
tac12345
Motorcycle(s): Ninja 250r 09 SE
Another tire thread - rain version
Hello everyone,
I am planning to use my ninja 250 only when it's raining outside, and will use my 636 when the weather is great.
Anyway, I was wondering what tire would be the best under rain condition. I have ridden the sport demon alot, they are great! but I was wondering if the bt-45 would be better ? or any other brand?
I want to stay away from any rain race tire.
Thanks for you imput guys, always appreciated
I would like to stick with the stock size for front 110-70 17 and 130/140 -70 17 for the rear.
tac12345 is offline   Reply With Quote
Old November 15th, 2014, 02:59 PM   #2
Michelin Pilot Streets advertise the best wet grip in the category.
http://motorcycle.michelinman.com/ti...-street-radial
At last, there is a radial structure for 250 cc’s and over which combines good overall performance with optimal handleability over time². It comes out top of its category¹ for grip in the wet ensuring a safer ride and its sporty look is set to be a hit.
1 : Test conducted in September 2012 at the DEKRA test centre on wet surfaces comparing MICHELIN Pilot Street Radial tires vs Bridgestone Battlax BT92 Radial Bridgestone Battlax BT90 Radial tires in sizes 110/70 R17 54H - 140/70 R17 66H and Pirelli Sport Demon tires in sizes 110/70-17 54H - 140/70-17 66H. Results may vary depending on motorcycle type and operating conditions.
It's getting pretty solid reviews so far on this site, though I haven't heard much one way or the other about wet grip.
Old November 15th, 2014, 03:25 PM   #3
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
I feel the same grip in my michelins in the rain that I do in the dry. It's astounding. They're set up very well for riding in the wet and they last forever, definitely the tire you're looking for.
Old November 15th, 2014, 03:52 PM   #4
dino74
dino74's Avatar
I've ridden both the BT-45 and DR2s at the track in the rain. Both performed well and I'd vote for DR2 since they have excellent dry grip as well.
CVMA #55
Old November 15th, 2014, 04:56 PM   #5
Sirref
Private Joker
Sirref's Avatar
MOTM - Mar '14
DR2 has the best dry grip in the class and it's not close, I'm not sold on their wet grip though but if you tracked them in the rain successfully you can speak towards it more than me.
Old November 15th, 2014, 05:06 PM   #6
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
go with tires that wick the most water.
TEAM ALFALFA
www.apexassassins.com
Old November 15th, 2014, 06:04 PM   #7
Love the grip of the DR2's, but not a fan of their wear rate. Haven't played with them much in the rain, so can't comment on how well they'd work. The tread design of the DR2 hints that there is less drainage than less track-friendly tires, but sometimes compounds can surprise in how well they work.
Old November 15th, 2014, 10:11 PM   #8
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Disclaimer - I am not a tire expert by any stretch of the imagination.
I've ridden Bridgestone BT-45s, Michelin Pilot Streets, and DRIIs in hard sustained rain. The Bridgestone front had maybe 8k while the rear was less than a thousand, the Michelins were both brand spanking new (well, couple hundred into their life), and the DRIIs had maybe 3k front and rear.
Of those, the only one's that stepped out on me were the DRIIs, caused while gentle braking and downshifting. Happened twice on the same ride, so may have been my technique combined with slick road.
The Bridgestones were ok, nothing overly noteworthy. I did slow down considerably given the sheer amount of water on the road but never had cause to question my tires. Navigating Eastern traffic and interstates felt neutral.
The Michelins, either through their ability or my supreme trust in them, felt glued to the road. I took them on I-5 north through California and once I reached the curves around Shasta, I felt planted enough to maintain a steady speed. My bike behaved to me as if it were on dry road, regardless of how much water was sheeting across.
The more I ride on them, the happier I am with the Michelins.
<-- Linky
Not your normal wider tire thread Jinx250 1986 - 2007 Ninja 250R Tech Talk 6 June 23rd, 2011 09:05 PM
Another tire thread JCCJMM_ 1986 - 2007 Ninja 250R Tech Talk 21 February 25th, 2011 07:36 AM
[sportrider - latest stories] - Sidi releases new Gore-Tex® version Adventure Rain b Ninjette Newsbot Motorcycling News 0 November 21st, 2010 11:00 AM
Another tire thread. wellcraft 2008 - 2012 Ninja 250R Tech Talk 24 June 10th, 2010 06:39 PM
ANOTHER tire thread sixstring 2008 - 2012 Ninja 250R Tech Talk 15 March 20th, 2010 07:01 PM
