November 18th, 2013, 11:47 PM | #801 | |
Join Date: Mar 2012 Motorcycle(s): Ninja 250r 2010 SE Posts: 573
My leg is still f***ed, calf muscle don't work atm. I think I might be able to ride though, going to try and get it down the dyno on friday. Should be interesting. |
November 27th, 2013, 05:01 AM | #802 |
Board Member
@tubarney any news?
I finally got my parts in, but I am going to redo some mechanical checks before putting it back together. @Racer x have you done any work with slotted sprockets and cam timing? I am greatly considering moving my numbers but since I do not have unlimited dyno time I was hoping to get a good beginning number. |
November 27th, 2013, 05:50 AM | #803 |
MOTM - Sep '18, Feb '16
Adjusting can timing is something I have not done. I have the sprockets and tried moving the cams around a little. All I got was detonation or major power loss. So I took them off. The problem is my experience is with single cam engines. Having seperate intake and exhaust cams means you can not only change the over all timing but change the camshaft centerline.
I spoke with Brandon about this. He could tell from my videos I need to adjust this. I have all the parts but need to fabricate two things. First I need to mount a degree wheel to the crankshaft. I can weld a fixture to the bolt on the left side of the crank to mount the degree wheel. Second is a dial indicator. I need to drill a small hole in the cam covers. A pin to the dial indicator will go through the hole and measure the cam or valve spring top. Honestly I don't know. Also I don't hava a clue where to set the cams. Once I get all the components together I will start a thread. Brandon has generously agreed to help me learn this black art.
November 27th, 2013, 06:11 AM | #804 |
Valve guide seals getting replaced. Dyno should be on Monday
November 27th, 2013, 06:21 AM | #805 |
Board Member
Let me know what you come up with.
Drilling the cam caps should not be a big deal, but mounting the degree wheel will be fun. from there you can check piston to valve clearance and cam timing numbers. Knowing/finding the best number is the hard part. I was hoping to work with brandon on this as well. |
December 4th, 2013, 09:57 PM | #806 |
Back together and working.
Just got to sort out the lean condition, popping out of exhaust. I'll try and get it on a trailer to the dyno. Really don't want to melt a ring or some bs while riding it down there. |
December 5th, 2013, 05:48 AM | #807 |
Board Member
I currently have mine at 65 pilots, Y50 needles, 120 mains and 230 main airs. I also bought one up/down on the mains right away.
What are you at? |
December 24th, 2013, 08:49 AM | #809 |
Not sure which jets are in there atm. Will find out once its done.
Now kawasaki have changed the valve cover gasket ( or Nev has given me the wrong one) because spark plug gaskets are not sealing. I mean they arent even close. Once I figure out whats wrong ill get it tuned and post some results. |
December 29th, 2013, 10:02 PM | #810 |
65 pilot, 118 main, YY5 Jet needle (7 clip) on 2nd clip from bottom
Its starts and runs ok, Good enough to get to dyno (10 mins away). Rolls Royce's Hylomar couldn't seal the spark plug gaskets but Threebond 1211 did. Just going to be a massive pain in the ass removing the valve cover. As soon as Dyno re-opens I'll take it down and see what this thing can do. |
December 30th, 2013, 04:59 AM | #811 |
Board Member
Good luck. Cant wait to hear the results.
January 6th, 2014, 08:59 PM | #813 |
Board Member
So...I am re-evaluating my motor. Couple questions in my mind:
1) do I change up to JE 13.5:1 pistons, still 265mm (+2) bore? 2) with that change do I run stock cams as I do not believe that I will have the p/v clearance? decisions...decisions....I am contemplating this due to my last dyno run, @cuong-nutz problems with the wiseco pistons and recommendations from Brandon. Thoughts? |
January 7th, 2014, 05:26 AM | #814 |
I have run higher than that. Go for it. This aint the really nice 250 ninja build . Its the ultimate.
January 7th, 2014, 05:50 AM | #815 |
Board Member
LOL
I suppose you're right. I wonder about the clearances at that point so I think that I will buy the stock cams and throw those in first. I run pump 93 all the time anyways so the comp will make no $$$ difference to me. |
January 7th, 2014, 06:44 AM | #816 |
I had to shim my spark plug up some. But other than that I had no problem with 13to1 JE with.010th off the top of the block. I ran 110 octane fuel with that and went 112 mph.
January 7th, 2014, 08:29 AM | #817 |
dirty boy
MOTM - Apr '14
A few pages back there was this talk about using exhaust valves for the intake? or other way around to get some performance gains or something? What ever happened with that? Can someone give some info on if it is worth it? problematic? ect...
January 7th, 2014, 09:02 AM | #818 |
Join Date: Apr 2013 Motorcycle(s): 2004 Ninja 250 Posts: 465
Without paging thru all the text, I thought I remembered it being about using an exhaust cam for the intake, not the exhaust valve?
January 7th, 2014, 10:06 AM | #819 |
Join Date: Dec 2011 Motorcycle(s): Ninja ex250 1990 Posts: 761
I think it was running two intake cams
1990 250F. ex300 motor swap, 15/42 gearing, flush side markers, newgen intergrated front fairing, rear integrated turn signals, DB Touring Bubble, zx600 rear shock, Custom DanMoto Exhaust |
January 7th, 2014, 11:11 AM | #820 |
Yes, run two intake cams.
Go big! I think the troubles I'm having might be my fault or just my bad luck. Hindsight, I would have probably just went with JE.
January 7th, 2014, 11:25 AM | #821 |
Board Member
January 7th, 2014, 11:34 AM | #822 | |
What if you threw a EX300 crank in....
January 7th, 2014, 11:34 AM | #823 |
January 7th, 2014, 12:38 PM | #825 |
January 7th, 2014, 12:50 PM | #826 |
Just about there Chone
January 7th, 2014, 12:51 PM | #827 |
But where is the fun in that?
January 7th, 2014, 12:52 PM | #828 |
I use NGK CR10E. I used a .020 th copper washer. Not a big deal.
Yes 2 intake cams gives 1mm more lift on the exhaust. But according to Brandon the timing is off. I am working on putting together the parts to adjust can timing.
January 7th, 2014, 01:03 PM | #829 |
January 7th, 2014, 01:09 PM | #830 |
How much adjustability can you get from the factory EFI system?
January 7th, 2014, 01:44 PM | #831 |
No idea. Never used it. Biggest benefit to factory fuel injection over aftermarket in my eyes is replacement parts.
I mean there's people who use power commanders to adjust for exhaust/intake/engine mods on loads of bikes. At some point, the limits are your injectors (minimum pulse length and flow rate). I don't know specifics on the 300's FI system though. |
January 7th, 2014, 02:56 PM | #832 |
I need to be able to adjust ignition timing and fuel mixture. If the factory stuff can't than it goes in a box with the turn signals.
January 7th, 2014, 05:46 PM | #833 |
January 7th, 2014, 05:54 PM | #834 |
Board Member
I had a lengthy discussion with a tech at je. He confirmed that the piston reliefs are the same for the 12.5:1 & 13.5:1 pistons. The difference is in the dome height. The 13.5:1 piston is .100 taller. This means that I should be ok with piston to valve clearance. However the plug still haunts me...but I think that if a run a Cr8e plug as the stock motor intended I would be ok.
January 7th, 2014, 06:54 PM | #835 |
January 9th, 2014, 07:33 PM | #836 |
Board Member
13.5:1 pistons on their way. I will need to replace all the bearings so I am upgrading. This is due to the piston dome clearance issue just like @cuong-nutz had.
January 14th, 2014, 06:47 AM | #837 |
@Racer x, do you have the APE adjustable cam gears? http://ape-store.com/shopsite/page34.html
January 14th, 2014, 07:12 AM | #838 |
Yes. And I have a dial indicator and a deg wheel. I have a way of attaching the degree wheel to the crank using the flywheel puller. But I have to work that out.
There will be a need to drill a hole in the cam cap to allow the dial indicator to measure the cam movement. Once I get this stuff all together. I will ask Brandon to help me learn about split cam timing. With out all this they are useless.
January 14th, 2014, 07:35 AM | #839 |
Totally understand. I was thinking of scribing/etching degree marks on the stock cam gears to learn when the valves are lifting and closing. As for the degree wheel on the crank, I thought about using a magnet to hold the wheel to crank bolt but your flywheel puller idea sounds better.
http://www.factorypro.com/tech/tech_...ning_proc.html http://www.iskycams.com/degreeing.php
January 14th, 2014, 12:10 PM | #840 |
The deg wheel must be fixed very securely. And I still need to turn the engine over. So a bolt is not good.
The difference between good and bad is so slight. Just forget about fudging it. This is where then power is going to come from. We need to retune this engine to make power above 13000 to get 40 + HP.
Shin's 250r Build Thread | Shintoxica | 1986 - 2007 Ninja 250R Farkles | 3 | August 22nd, 2013 11:10 AM |
My 250R Race Bike Build | icbm | Pictures | 5 | August 16th, 2012 11:06 AM |
Is the ninja 250r the ultimate beginner bike, or should I settle for something else? | Mulholland | General Motorcycling Discussion | 188 | April 15th, 2012 09:28 PM |
[topix.net] - Freestyler Josh Borne guest stars on Discovery's Ultimate Car Build Off | Ninjette Newsbot | Motorcycling News | 0 | June 25th, 2010 07:50 AM |
I want to buy or build an 08+ 250R racer. | Seanslides | Ninjettes At Speed | 20 | March 1st, 2010 07:34 AM |
