Old June 14th, 2013, 09:40 PM   #1
walty87
walty87's Avatar
Motorcycle(s): 2012 ninja 250
confused on part number for headlight relay
cant figure out if i'm looking at the right thing, and I don't want to accidentally order the wrong part again
do I want:
27002A
RELAY-ASSY
27002-1091
or
27002
RELAY-ASSY
27002-1086
i'm thinking the 27002a is the actual relay and 27002 is just the black rubber piece? idk.
help!
Thanks :]
walty87 is offline   Reply With Quote
Old June 14th, 2013, 10:15 PM   #2
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
27002
edit: or a SPST relay would work if you need it asap
Old June 14th, 2013, 11:12 PM   #3
walty87
walty87's Avatar
Originally Posted by Asspire View Post
27002
yay the $40 dollar one! haha. thanks man.
spst relay could be bought at radio shack? then what wires would connect to it? all the wires that are going into the headlight relay?
Old June 15th, 2013, 05:54 AM   #4
27002
Would this one work?
http://www.autozone.com/autozone/acc...er=203873_0_0_
Would any SPST NO (Normally Open) automotive relay rated 12 volts / 10 or more Amps work as a substitute?
If so, the grey wire goes to post 30, the blue-yellow wire goes to post 87.
The yellow-red and the red wires connect to post 85 and 86 indistinctly.
http://www.the12volt.com/relays/relays.asp
Old June 15th, 2013, 07:20 AM   #5
DaBlue1
DaBlue1's Avatar
do I want:
27002A
RELAY-ASSY
27002-1091
or
27002
RELAY-ASSY
27002-1086
help!
Thanks :]
RELAY-ASSY 27002-1086
Check this out. http://www.suncoastcyclesports.com/s...nja-250/Detail
Old June 15th, 2013, 07:41 AM   #6
walty87
walty87's Avatar
I'm no expert but I can't think of reason why it wouldn't. I'm going to try it maybe, unless someone else chimes in!?
Will order. Used shouldn't matter right?
Old June 15th, 2013, 07:46 AM   #7
DaBlue1
DaBlue1's Avatar
.....Will order. Used shouldn't matter right?
Ask about their return policy. A new one from Kawi is only a few dollars more.
Old June 15th, 2013, 04:18 PM   #8
Asspire
Asspire's Avatar
just get new, you don't wanna go thru this twice (or you do, I never like use parts).
the one motofool posted would work, generally most automotive relays are rated at 40 amps, which is enough for what you want to do.
I'm actually on my forth relay for my horn and fog lights, the vibration of these bikes just kill them. make sure you reuse that rubber sleeve if you can.
Old June 17th, 2013, 10:27 AM   #9
walty87
walty87's Avatar
Does the one from autozone have to be 40 amps!? Found one that 30 amp 12 volts and has 6 pins. Would that work
Old June 17th, 2013, 10:32 AM   #10
30 A will be fine, your lights use about 5 A.
That sixth pin is not necessary and likely will interfere with the plastic female plug in your bike.
Old June 17th, 2013, 10:35 AM   #11
walty87
walty87's Avatar
I can break off the 6th pin then right
Old June 17th, 2013, 10:42 AM   #12
Yes, you could.
Old June 18th, 2013, 09:24 AM   #13
walty87
walty87's Avatar
so the relay i got from the auto parts store doesn't fit on the female housing.
Any way to get those wires out of the female housing? i really don't want to break it apart..
Old June 18th, 2013, 09:54 AM   #14
The female housings normally have a little lip or hook that allows the the tabs get in but not come out.
Using a small flat screwdriver, sometimes I have been able to press that little lip to hook down to liberate a tab while pulling the wire out.
A third hand is helpful.
How the towing of the bike went?
Old June 18th, 2013, 10:03 AM   #15
walty87
walty87's Avatar
Was a piece of cake. Had my girl bring my truck, ramp and straps. Got honked and yelled by idiots while chilling on the side of the highway while waiting. Had a guy w/ a brand new cbr 500 in the back of his lifted 4x4 truck stop and ask if I was alright. Also had a highway patrol check on me and asked if I felt safe lol. It was a boring wait, but I had this forum going on my iphone so all was good
I've been trying to get the damn tabs out with a screw driver for hours now. I cannot do it! Maybe I need a smaller screw driver
New blinkers, did all the wiring but confused with load independent relay flasher Donut 2008 - 2012 Ninja 250R Tech Talk 4 May 11th, 2014 04:58 PM
08 Ninja 250 : Other Issues due to Headlight Circuit Relay abhijitz 2008 - 2012 Ninja 250R Tech Talk 1 February 26th, 2013 05:41 PM
2008 250 Headlight Relay brittany88 2008 - 2012 Ninja 250R Tech Talk 2 August 5th, 2012 08:12 PM
LED flasher relay part number 808derek 2008 - 2012 Ninja 250R Tech Talk 7 April 30th, 2011 08:59 PM
Faulty Headlight Relay? youowemeadollar 2008 - 2012 Ninja 250R Tech Talk 2 July 29th, 2010 08:22 AM
