Old May 10th, 2017, 06:32 PM   #1
Lil_Green_Demon
Winging It In Life
Lil_Green_Demon's Avatar
Motorcycle(s): 2010 250R; 2011 250R (sold)
Rear brakes stopped working
I checked Google for an answer but didn't find anything similar to what I'm experiencing, as others end up having overheating issues.
It's cold in Southern California right now, so it's an overheating issue & the rear caliper is cold to the touch, even after riding on the highway for 20 mins.
The brakes were working perfectly fine this morning, but I noticed they weren't braking effectively on my way home around 12 pm. I rode again just now to work and they weren't working at all. Front brakes are fine, though.
I've checked the connections, but I didn't identify anything specifically wrong.
Any ideas before I rush the bike to a mechanic tomorrow?
Lil_Green_Demon is offline   Reply With Quote
Old May 10th, 2017, 06:56 PM   #2
Lil_Green_Demon
Winging It In Life
As I'm looking at it more, I get a feeling the caliper isn't supposed to be at this angle: http://imgur.com/a/lV0xA
Old May 10th, 2017, 07:15 PM   #3
Right, when it's about to fall off, braking efficiency declines.
Old May 10th, 2017, 07:55 PM   #4
Lil_Green_Demon
Winging It In Life
Well, holy ****. I'm taking it to the dealer tomorrow then. Any idea why this would happen? I've owned the bike for 8 days now and I don't remember if the caliper was sitting correctly when I bought it. I wish I had taken pics from multiple angles.
Old May 10th, 2017, 08:17 PM   #5
Z1R rider
Z1R rider's Avatar
MOTY - 2018, MOTM - Oct '16
If the rear wheel was off for any reason, I'd guess it wasn't reassembled properly.
Old May 10th, 2017, 08:40 PM   #6
Right. I'd like to see it in person. It's rotated way out of position because the channel in the caliper mount that's supposed to be located by the swing arm isn't, but I don't see why the pads have come out of the disk if it rotated around the axle.
It's just academic though, putting it back together properly should be an easy fix.
Old May 10th, 2017, 08:45 PM   #7
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
where did you get the bike? they are likely responsible for that messed up caliper.
TEAM ALFALFA
www.apexassassins.com
Old May 11th, 2017, 12:35 AM   #8
Lil_Green_Demon
Winging It In Life
I bought it used from a college freshman last Monday. Damn. It only lasted 9 days before going bad on me.
Old May 11th, 2017, 04:56 AM   #9
Z1R rider
Z1R rider's Avatar
Did you check the brake fluid level? The way it's kinked around it may have cracked the hose, most likely where the end fitting crimps onto the hose.
Old May 11th, 2017, 05:36 AM   #10
ninjamunky85
Que Buenos Son!!!
ninjamunky85's Avatar
MOTM - Nov '14
Wow!
Old May 11th, 2017, 06:21 AM   #11
I don't know that anything has gone bad at all. As Z1R rider said above, it's most likely just that the parts are out of place because of improper assembly when the wheel was installed. Even if something was damaged as a result, those parts are not expensive on the used market.
Old May 11th, 2017, 06:24 AM   #12
taz
taz's Avatar
MOTM - May '17
Old May 11th, 2017, 07:02 AM   #13
Lil_Green_Demon
Winging It In Life
Fluid level seems fine.
So to fix this, should I remove the caliper, bring it back to the correct position and tighten the bolts there?
Old May 11th, 2017, 08:00 AM   #14
You need to understand how it is supposed to go together. There is a channel in the caliper bracket that should be held in place by a protrusion on the swing arm. This keeps the caliper bracket from rotating like it did. I expect that you need to remove the rear wheel, get things in position, and install them correctly, then tighten the rear wheel. There may be a spacer or spacers out of position, but I don't know for sure because my 250 is a pregen.
Verify that everything is intact, nothing is broken or assembled out of position, and in any case, if you are unsure of what you're seeing in the repair manual in the section on how to install the rear wheel, you should get someone with experience to help you.
Old May 11th, 2017, 09:34 AM   #15
Z1R rider
Z1R rider's Avatar
Old May 11th, 2017, 09:51 PM   #16
Sort of, like Triple Jim said:
1. remove rear axle
2. remove rear wheel note position of spacers
3. rotate brake-caliper bracket so that its slot is over the stub on the inside of the swingarm
4. re-install rear-wheel being careful not to disturb the caliper bracket
5. re-install rear axle
Old May 12th, 2017, 09:02 AM   #17
Lazarus
Lazarus's Avatar
Motorcycle(s): 2008 Ninja 250
^ this. Its a little difficult to do with only one person but its not impossible.
Lazarus is offline   Reply With Quote
Old May 12th, 2017, 11:34 AM   #18
I find putting my foot under the rear-wheel and "toe-ing" it up and down helps position the wheel while I shove the axle through. Or you can make some ramps out of blocks of wood to roll the wheel up into position.
Old May 12th, 2017, 11:35 AM   #19
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
Not difficult to do solo at all. Have a rear stand. Use a piece of 2x4 under the tire to help guide the wheel back in place so the axle can easily slide back in.
OP, to fix your problem, you MUST remove the rear wheel off the bike. Or at least slide the axle out enough so that that black grove in the rear caliper can go back on the INSIDE of the right swingarm.
If you've never worked on a bike before, maybe it's best to bring it to a shop. Should be no more than $50 bux to get that fixed.
Or if you have the time and you're willing to learn, look at youtube videos of how to change a rear tire and you should see the process of removing the rear wheel and reassembling the rear wheel (with the brake caliper in the proper position).
Riding it like I financed it.
Old May 12th, 2017, 12:01 PM   #20
Lil_Green_Demon
Winging It In Life
I paid a local mechanic $85 to fix it just now. I feel a bit gypped but at least the caliper is back in place.
Next time, I'll take it to a mechanic who works on all bikes and hopefully not be charged so much. This mechanic advertises as a cruiser mechanic. He wouldn't adjust the rate and still charged me for the full hour, even though it took him less than 20 minutes to get the job done. His shop, his prices. I have to respect that.
Still, I can't complain too much.
2011 Kawasaki Ninja 250R (Bought - Apr 22, 2011; Sold - Feb 17, 2015)
2010 Kawasaki Ninja 250R (Bought - May 01, 2017; Current)
Old May 12th, 2017, 12:30 PM   #21
I hope you were able to watch how he got things back in the correct position.
Old May 12th, 2017, 12:52 PM   #22
Lil_Green_Demon
Winging It In Life
Unfortunately, no. The area where he was working was facing away from where customers had to sit.
Old May 12th, 2017, 12:57 PM   #23
You definitely need a new mechanic, or better yet, learn to do the work yourself.
Old May 12th, 2017, 10:07 PM   #24
Lil_Green_Demon
Winging It In Life
Yup. I can do basic things, like oil changes and I just did the coolant flush on Tuesday, but more complicated work worries me. I'll have to try, though. It'll save money long-term.
Old May 13th, 2017, 12:26 PM   #25
Flying
Motorcycle(s): 2010 Ninja 250
Whoever you bought it from certainly didn't play with legos as a kid....
Old May 13th, 2017, 03:05 PM   #26
cadd
cadd cadd cadd
cadd's Avatar
Motorcycle(s): 300
MOTM - May '15
My shop charges $40 to change the rear tire ($20 if you carry the wheel and new tire in for him). This is 1/2 the work of changing the rear tire. You gotta find a new shop. For future reference, if you're comfortable changing the oil and coolant, this should be within the same skill level needed. Just gotta watch youtube videos!
Old May 13th, 2017, 06:05 PM   #27
MrAtom
MOTM - July '15
Same here. I was recommended a shop by a local rider who had a very well-taken-care of bike and he knew what he was talking about. Good way to find a good shop.
Throttle Stopped Working brandonrhdoes1630 2008 - 2012 Ninja 250R Tech Talk 3 August 29th, 2015 12:54 PM
12v stopped working rasta 2008 - 2012 Ninja 250R Tech Talk 8 January 25th, 2014 01:17 AM
Tach stopped working? beta7 2008 - 2012 Ninja 250R Tech Talk 1 July 4th, 2013 09:31 AM
Blinkers just stopped working coluk33 1986 - 2007 Ninja 250R Tech Talk 8 May 6th, 2013 09:13 PM
tach stopped working -.- ajaygraci 2008 - 2012 Ninja 250R Tech Talk 23 March 31st, 2012 10:55 PM
