Old July 19th, 2016, 11:49 AM   #1
Cra1g
Cra1g's Avatar
Motorcycle(s): 2014 Ninja 300 ABS, 2007 Yamaha FZ6
Couldn't find a good how-to video for a pregen Ninja 250 fender eliminator, so I made
https://youtu.be/xOwyelf8Cew
I've seen written tutorials on how to relocate the turn signals into the empty ponds, but most of them were half-assed with most of the details taken out, so I decided to kinda just figure it all out myself and make my own how-to video. Hope this helps those looking to do this!
Cra1g is offline   Reply With Quote
Old July 21st, 2016, 12:08 PM   #2
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
Heatshrink and electrical tape are made for insulating, not really securing. I suggest crimping/soldering your connections to avoid problems in the future.
I prefer not to destroy good parts if I don't have to. Instead of cutting the wires off the old turn signals, just put new bullet connectors on the new signals so they plug in like stock, and you can sell or go back to the stockers if you need to. My 500 (and I think my VN700) uses an odd-ish 2.5mm bullet, rather than the sizes you find at every autoparts store.
You can get 1156 bulb sockets that have the ground wire attached (just like the power wire), so you don't have to bother with trying to attach a wire to the outside of the socket. https://www.amazon.com/dp/B00AKX8MSO is one example. You might be able to use one with tabs and just put some notches in the reflector hole to mount it, rather than having to glue it.
If you wanted to get more creative, you could use a dual-filament 1157 socket. You could then use them as turn signals and running lights, to make yourself a tad more visible. You'd have to keep the red lights for that though, or go with a switchback red/amber LED.
In case you forget to label the wires, green is left and gray is right.
Old July 21st, 2016, 01:04 PM   #3
spent_too_much
spent_too_much's Avatar
Nice overall video. Great voice over to explain what you were doing. I agree with InvisiBill, about alternatives to cutting wires. Good work!
Old July 21st, 2016, 02:04 PM   #4
Cra1g
Cra1g's Avatar
Thanks for the feedback, InvisiBill. Yeah, I was hesitant to cut the wires since it's the point of no return.
I'm going to leave them as just turn signals for now, but definitely going to get clear lenses with amber bulbs, although the only ambler bulbs I could find were a bit higher wattage. I might get some LEDs instead..
Where can I get bullet connectors to fit the current wiring harnesses?
Old July 21st, 2016, 03:16 PM   #5
InvisiBill
InvisiBill's Avatar
I got mine from Eastern Beaver in an order with other stuff. I'm sure there are other sources out there, and EB isn't the best place for just a small order of those (since he's in Japan and has a minimum order). Looks like Cycle Terminal has them too. Google turned up some RC car forum threads, and suggestions to check eBay.
Old July 23rd, 2016, 01:43 PM   #6
Jaytibba
Motorcycle(s): 1993 ninja 250ex
Cool video man. This will defiantly be the next thing I do to my bike
Jaytibba is offline   Reply With Quote
Old July 25th, 2016, 09:46 AM   #7
Jaytibba
What about the license plate light? Isn't that something you need in order to be street legal?
Old July 28th, 2016, 08:02 AM   #8
In many to most states... yes.
Old July 28th, 2016, 08:30 AM   #9
Cra1g
Cra1g's Avatar
On the pregen, you can bust out a small bottom portion of the taillight lense to shine some light down onto the license plate. If I get pulled over for it, I'll take the time to do it, but I'm leaving it for now.
On my Ninja 300's fender eliminator, I'd have to wire in new lights to shine onto the plate, which I haven't looked into yet :/
For what it's worth, most of my friends don't have plate lights, and some of their plate setups are super illegal, but they've all gotten away with verbal warnings, so I'm not too concerned about it right now.
Old August 26th, 2016, 09:46 AM   #10
Petrolh34d
Motorcycle(s): 2004 ninja ex250, 1996 Honda cbr900rr
Fwiw I ended up reusing the lamp sockets from the turn signals an reused the oem bullet connectors with some heat shrink. Cost me a total of $0!
Petrolh34d is offline   Reply With Quote
Old August 26th, 2016, 10:52 AM   #11
Cra1g
Cra1g's Avatar
That can work too, although just getting new sockets is easier and costs $5 tops.
Old December 1st, 2016, 05:32 PM   #12
Nu2Street
Motorcycle(s): 2006 Ninja 250R
I am very interested in doing this to my 06 ninja 250, but the video is no longer available. Are there any pics available. Thanks.
Nu2Street is offline   Reply With Quote
Old December 1st, 2016, 05:34 PM   #13
Nu2Street
What holder was used for the registration plate. I can easily move the turn signals to the pods.
Old December 1st, 2016, 07:06 PM   #14
Cra1g
Cra1g's Avatar
****--my bad! I deleted the YouTube channel that I uploaded the video to and forgot about this video..
I just used a couple of right-angle corner brackets to hold the license plate on. You can get them at pretty much any hardware store for less than $1 for a pair.
Old December 2nd, 2016, 08:55 AM   #15
Nu2Street
Thanks. In interested in seeing what the back of your bike looks like. Did you cut the plastic wheelwell / fender just under the seat? I see there is a seam overlap there where it attaches to the frame. Just not sure how much I want to remove.
Old December 2nd, 2016, 09:31 AM   #16
Cra1g
Cra1g's Avatar
I ended up converting my 250 into a streetfighter so I can't show you what it looks like anymore. Basically the fender and the wheel well are one piece, so you have to use a jigsaw and separate the two, and then install the wheel well portion back in.
Old December 2nd, 2016, 09:34 AM   #17
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
To true re heat shrink & electrical tape. But avoid soldering of electrical terminal ends on wire. It causes vibration fractures, which is why all auto connections are crimped only !
[motogp.com] - Viñales: “I couldn’t find a proper feeling” Ninjette Newsbot Motorcycling News 0 September 15th, 2015 02:30 AM
Fender eliminator kit for 2011 Ninja 250 tihomirbg Items Wanted 0 December 29th, 2014 09:31 AM
Is this a good buy? (Exhaust + Fender Eliminator) AeroXtasy Items Wanted 4 February 6th, 2012 05:34 PM
FS: Competition Werkes fender eliminator for '08 Ninja 250 ManyCavies Motorcycle-related 0 April 25th, 2009 08:49 PM
