June 22nd, 2011, 07:52 PM | #281 |
B-Town Ninja
Join Date: Feb 2011 Motorcycle(s): Black 2013 Ninja ZX6R ABS Posts: 609
I've been using 93 since I got the bike (2,823m) because I thought it was better for the bike *facepalm*
Maybe that's why I was 'maxing' around 55mpg while I know others get up to like 65.. granted I am not very right hand friendly. Either way, going to burn up this tank of 93 and switch over to 87 as you fine people have recommended. Thanks for the advice and saving me some cash (I should do the math to see how much I've wasted using 93)
Downgraded to a 2013 636. Previous owner of a 2010 250r --------------------------------- My moto-vlog YouTube channel http://www.youtube.com/bloomingtonninja |
June 22nd, 2011, 08:32 PM | #282 |
KThanksBye
Join Date: Mar 2011 Motorcycle(s): 2006 zx636r Posts: A lot.
----> My Youtube! <---- Unregistered, watch my youtube page! |
June 23rd, 2011, 10:19 AM | #283 | |
Join Date: Jan 2011 Motorcycle(s): 2014 Ducati Panigale 899 Posts: 325
Ok, I really don't get your logic but I applaud you for thinking outside the box! |
June 23rd, 2011, 10:58 AM | #284 |
ModMy250.com
I switched on my BRT map and am using 91 now that it's in the lower $4 range. It's an extra 70 cents for an increase in performance so I don't find it all that big of a deal. It really sucked driving a turbocharged car though. The difference in cost really adds up when you have to fill up 16 gallons.
The www.ModMy250.com guy |
June 23rd, 2011, 11:30 AM | #285 | |
Jigglin' your Jiglets
MOTM - Apr '13
I plan on riding my bike about 6000 miles per year. Add on that hefty 91 price tag and thats an extra $18/year that I will be paying. If you read my earlier post, I'm also going to run a tank of 87 to see if there is a difference. And for shits and giggles I'll run a tank of 100 too. |
June 23rd, 2011, 11:38 AM | #286 |
ModMy250.com
Higher octane is formulated to prevent pre-detonation. This can cause the fuel mixture to not ignite at the correct time and leave unburnt fuel in the exhaust. It's why 87 is recommended. I run an advanced ignition map with 91 and even I can smell the unburnt fuel. I never could smell it with the 87, but the 91, I can definitely smell it when I come to a stop. I think it's because the BRT low ignition map is stock and only changes when the bike gets into the upper RPM band. Not getting a complete burn translates to lower performance and mpg. I definitely would not put 100 in there.
June 23rd, 2011, 12:17 PM | #287 |
MOTM - Apr '13
I will try 87 and report what I find. As for tanks with 91 I'll post the mileage I've gotten.
From dealer to home with few stops 77.2mpg Riding around city with many more stops 48.8mpg, 48.2mpg |
June 23rd, 2011, 12:23 PM | #288 |
ModMy250.com
Cool. I think 87 will give you even better MPG
June 23rd, 2011, 01:08 PM | #289 |
MOTM - Apr '13
We will see. I'm going to go burn the rest of my 91 tank fill up with 87 and ride down to hollister for my 600 mile service. If I get over 77mpg there and back then we will have a clear winner.
And I've never smelt gas when riding my ninja |
June 23rd, 2011, 01:12 PM | #290 | ||
The issue with 91 octane is that the gas companies promote it as though it's a 'premium' product, when it's not. It's either the right fuel grade for your vehicle or it's not. Quote:
June 23rd, 2011, 01:39 PM | #291 |
ModMy250.com
Most likely because you still have a catalytic converter. Mine is gone
June 23rd, 2011, 03:44 PM | #292 | |
MOTM - Apr '13
So I rode around until I ran out of gas and then walked my baby over to the gas station and filled up with 87. I wanted the tank of gas to be all 87 with as little excess 91 in there as possible. Let the testing begin |
June 23rd, 2011, 03:56 PM | #293 |
ModMy250.com
Unburnt gas isn't an issue if you have a cat is right, environmentally speaking. However, unburnt gas also means you are not getting full combustion. That means your engine is not burning fuel as efficiently as it should. This translates to lower MPG and performance. Hope that explains it better than the first time. I'm not out to prove you wrong. I'm just trying to say that 87 would be better for an engine that does not have any timing advance. Heck, I keep thinking to myself that maybe 89 wouldn't be ok to use. I just have no way of monitoring knock, so I'll just stick with the safe bet that even if my engine runs a little rich, it's better than too lean.
June 23rd, 2011, 04:12 PM | #294 |
You need to average mileage over several tank fulls, because it's impossible to fill to the exact same point each time you refill. Little things like slope, bike lean, lighting conditions that affect your ability to clearly see the fill level, etc, all impact mileage calculations.
June 23rd, 2011, 04:41 PM | #295 |
Norwegian dude
Join Date: Aug 2010 Motorcycle(s): Ducati 748 Posts: 120
June 23rd, 2011, 04:44 PM | #296 | |
MOTM - Apr '13
As far as throwing away money, I paid $130 for 2 loaves of banana bread and a small banana bread cake at a Children's Miracle Network bake sale run by the Rite Aid I used to work at. I only throw away money when its worth it |
June 23rd, 2011, 05:42 PM | #298 | |
6000 miles / 50 mpg = 120 gallons per year Here in the bay area, the difference between 87 and 91 is always at least 30 cents, so 120 * .3 is at least $36/year, right? An when pricing really gets up there, I've seen it differ by as much as $.40 per gallon.
June 23rd, 2011, 06:08 PM | #299 |
Join Date: Aug 2010 Motorcycle(s): Blue 2010 Kawasaki Ninja 250r Posts: 170
I dont know about the US but here in canada we have up to 10-15% ethanol especially in our high-octane grades. Ethanol raises the octane rating but as we all know you get less energy out of an ethanol burn and thus less MPG.
There is one grade of 94 here that is ethanol free. sorry, to answer the opriginal question I put 94 ethanol-free whenever I can otherwise I put whatever the highest they have is. For the extra couple buck to protect against the possibility of pinging and pre-det i figure I may as well. If I cant afford the extra couple bucks on a lil bike that gets such good MPG, maybe I should drive it less. The difference between 87 and 94 here is about 25c / liter I believe (about 80c / gal) |
June 23rd, 2011, 06:18 PM | #300 | |
June 23rd, 2011, 07:41 PM | #301 | |
MOTM - Apr '13
June 24th, 2011, 07:52 AM | #302 |
Join Date: May 2011 Motorcycle(s): 2011 Ninja 250r Posts: 91
Thank you to everyone for this thread. I've been putting 93 in my bike as a habit (since my car requires it) and didn't realize it could be negatively affecting the performance. I'm going to make the switch to 87 and see if I notice any difference.
MTGATT |
June 24th, 2011, 10:38 AM | #303 |
Cranky Old Fart
Join Date: Apr 2011 Motorcycle(s): 08 DRZ400SM Posts: 189
I just use whatever is recommended. I only use exxon, their speed pass system is great for lazy old people like me who don't want to get their wallet out or go through the tedious task of standing up.
June 24th, 2011, 10:43 AM | #304 |
Join Date: May 2011 Motorcycle(s): 06 Buell Uly, 05 VStar 1100 Posts: 577
I use 87, ever one in a while I'll put some fuel booster into all my bikes and cars though.
June 24th, 2011, 04:44 PM | #305 |
MOTM - Apr '13
The test results are in
I filled up with 87 right before I left for hollister. Rode the highways and freeways all the way there with no stopping. Had my service done and rode back on the same route. Pulled up to the gas station with 100.1 miles on the odometer. I expected to be putting in about 1.5 gallons... and then the gas just kept coming. It filled up with 2.521 gallons. 100.1/2.521 = 39.7mpg. That's absolutely terrible. What could possibly be the reason for this. When I ride around in the city i get 48mpg but on the highway with 87 I get 39.7mpg Is my ninja leaking fuel or something?? On my trip there and back I was riding in 6th gear at around 10k rpm/75mph. With the first tank of gas (91) I got 77mpg on the way back to my house from hollister. 87 should have given me the same results. I'm thinking there is something very wrong with my poor ninja. Help? |
June 24th, 2011, 06:12 PM | #306 |
Keep track of it for a few more tanks. The differences are larger than would be explained by differences in bike performance, so make sure that you truly are measuring it the same way each time (resetting the trip meter, dividing by the number of gallons put in as you fill it up to the same level each instance).
June 24th, 2011, 07:04 PM | #307 | |
June 24th, 2011, 07:28 PM | #308 |
MOTM - Apr '13
I am making sure to fill it the same way each time. I use the same pump at the same chevron, place the lip of the rubber on my gas tank and push in all the way. Then I let the auto-shutoff determine the level of the gas.
I just went and rode in some backroads with no stops and I got 51mpg with 87. I'm thinking that the wind resistance on the freeway is what killed my mileage. I'm going to start manually filling the tank rather than letting the auto shutoff determine the level. This way I can raise the level of gas to the same visible spot each time. Now what I'm really wondering is how the balls I got 77mpg in the first place. It was my first time on the bike so maybe I was so timid with the throttle and shifting that it really improved my mileage. Idk... I need to try to replicate that high mpg. |
June 24th, 2011, 07:36 PM | #309 |
that's the problem. you need to "manually" fill the tank to the same spot every time you fill to get accurate readings.
June 24th, 2011, 07:51 PM | #310 |
MOTM - Apr '13
The auto shutoff will take it to the same level as long as you place the pump in the same position.
However it cuts off nearly a half gallon short so I'll just fill it myself |
June 24th, 2011, 07:58 PM | #311 |
not all auto shutoffs are calibrated the same... more so if you're using different stations.
so, again I ask you, how have you been filling the tank... manually or with the auto shutoff? if manually, are you filling to the same reference spot in the tank at each fill? |
June 24th, 2011, 08:00 PM | #312 |
MOTM - Apr '13
But as I said I use the same station and the same pump each time. Before I was using the auto shutoff. The last tank I filled I did it manually up to a visible and repeatable spot. I will continue to use the manual method since I can squeeze an extra .5 gallons in there.
With the auto shutoff When I filled up, my fuel gauge read 3/4 full lol... |
June 24th, 2011, 08:04 PM | #313 | |
June 24th, 2011, 08:08 PM | #314 |
MOTM - Apr '13
not quite. I allowed the pump to go through its auto shutoff and then recorded the amount of gas I had put in. I then calculated my MPGs. Then I finished filling up the extra .5 gallons. So the crappy mileage is still a mystery.
June 24th, 2011, 08:10 PM | #315 |
best bet is to do as Alex suggested and keep track of the next few tanks and see if the numbers stabilize.
June 24th, 2011, 08:10 PM | #316 |
B-Town Ninja
I'll try and do a test as well. It won't be perfect at all, but should give at least a ballpark figure to see if it makes a noticeable difference.
Since I have about half a tank of 93 left and I'll be taking a 4 hour road trip this weekend, I'll do as follows: 1. On the way to Chicago: Ride I-65 N at 70mph for 100miles using the rest of my 93. Once off I-65 N and for the rest of the weekend (will ride well over 200miles over weekend), get rid of ALL the 93 and switch to 87. 2. On the way back to Bloomington: Ride I-65 S at 70mph for 100miles using 87. At these speeds, I'm sure winds will make a big diff on mileage, but this is the only way I can really try it without scaring myself running on E (which, btw, is when I have over 1 gallon left).
June 24th, 2011, 08:13 PM | #317 | |
MOTM - Apr '13
June 24th, 2011, 08:16 PM | #318 |
B-Town Ninja
Honestly have no idea... it's from Marathon haha. I'll check to see if the pump says anything about that before I leave tomorrow.
June 24th, 2011, 08:17 PM | #319 |
I use 87. It runs fine and I have no reason to spend more on expensive gas than I have to. I don't plan on messing with ignition advancement in the near future, although tempting, but if I did i would look into higher octane fuel.
btw I've averaged about 63 mpg consistently give or take 1. and that's combined city/highway/twisty backroads. last summer, I was averaging about 66-68 mpg since I had stock jetting and I wasn't ready to ride like I ride now. |
June 24th, 2011, 08:26 PM | #320 |
Join Date: Jun 2011 Motorcycle(s): 2009 ninja 250r Posts: 75
excuse me for being nieve, but what is 87, in australia we have 91, 95, 98. 91 being the standard and 95 and 98 being the premium, before they started putting ethenol in I never had a problem using standard in my 4x4 which has fuel injection. until lately now it gets valve ping all the time, so I found I have to use premium where ever I can, (my wife keeps putting the cheap stuff in) drives me mad. But I am presuming that because the ninja is still on carbs that may be why we dont have problems with standard fuel. I did get told not to use BP because they add a lubricant to the fuel which is good for cars but not for bikes. Our measuring system may be different because we are metric and that may be what the stickers mean if it is labeled by Kawasaki. I laugh hearing the argument of fuel efficiancy for a motorbike here because I have only just started riding because the price of fuel in my 4x4 has just been getting too expensive so the savings I have now are just huge compared to what we are talking about here.lol
[topix.net] - Officials stunned as 94-year-old uses his funeral money to run for parl | Ninjette Newsbot | Motorcycling News | 0 | December 13th, 2012 08:40 AM |
[topix.net] - Run with Nuns hits the streets to raise money for children | Ninjette Newsbot | Motorcycling News | 0 | October 23rd, 2011 06:40 PM |
take the money and run.. | greatwhiteninja | Off-Topic | 4 | August 4th, 2011 01:49 PM |
[crash.net - WSBK] - Haslam: We'll give twins run for their money | Ninjette Newsbot | Motorcycling News | 0 | April 8th, 2010 05:00 AM |
[crash.net - WSBK] - Haslam: We'll the twins a run for their money! | Ninjette Newsbot | Motorcycling News | 0 | April 8th, 2010 03:30 AM |
