Old March 25th, 2014, 12:49 PM   #41
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
Yes. At 45 deg BTDC the cams are free floating. You can remove the tentioner and rock the cams back and forth to check.
Worlds fastest 250 ninja
Last futzed with by Racer x; March 25th, 2014 at 02:02 PM.
Old March 25th, 2014, 12:56 PM   #42
headshrink
headshrink's Avatar
Originally Posted by Racer x View Post
Yes. At 45 deg BTDC the cams are free floating. You can remove the gentians and rock the cams back and forth to check.
I've never found the spot there was literally no tension, but I follow what you're saying. I've got to check mine sometime this week to troubleshoot that dead cylinder, so I'll make a point of giving this a try. I've usually had no problem tapping the caps with a screwdriver handle or closed fist to release them. However, I can tell it's quite a delicate job. My sympathy to all those this didn't go well for. Usually this would be me, but so far I've been lucky on this one.
Old March 25th, 2014, 02:49 PM   #43
Racer x
Racer x's Avatar
I guess the main thing to avoid is having the lobes pointing down on the left or #1 piston. Its the cocking angle that will break the cam.
Camshaft questions 86,87 vs 88+ Rollingmenace 1986 - 2007 Ninja 250R Tech Talk 5 May 20th, 2014 11:49 AM
camshaft profiles micoulisninja 2008 - 2012 Ninja 250R Tech Talk 30 February 12th, 2014 04:01 AM
Camshaft Chain Inspection indr 2008 - 2012 Ninja 250R Tech Talk 18 February 2nd, 2013 08:29 PM
Photo of stock camshaft tubarney 2008 - 2012 Ninja 250R Tech Talk 2 January 24th, 2013 05:09 PM
Intake Camshaft jpatt87 Items Wanted 14 January 19th, 2012 08:55 AM
